Question about HP OfficeJet 6110 All-In-One InkJet Printer
Printer problem My HP 1020 is making a really loud clicking noise. My HP 6110 makews a loud clicking noise and I can't seem to get rid of it. It does not work when in clicking mode.
  • 1 more comment
  • Anonymous Oct 09, 2008
    I have same problem
  • pleasehelp1 Oct 10, 2008
    and so do I; just started yesterday. I turn on printer, it clicks for about 30 times, then flashes "Scanner faillure" Turn on again... no idea what to do
  • peter_the_po Nov 07, 2008
    YEs exactly the same problem ?
Mine does the same thing, it appears to be a scanner sensor that has failed. The machine starts by lighting up the scanner, then moving out of park position, then repeatedly trying to move it back into the parked position. It appears to be a sensor that is not working, and needs a part replacement.
Posted on Nov 09, 2008
  • egolding Nov 09, 2008
    More investigation: My problem seemed to be a dirty glass on the scanner bed. To fix: I unplugged the unit, removed the 3 screws above the glass, and the one screw on the right of the glass, but not the one to the left -- that just holds down a smaller piece of glass where the ADF scanning happens. I then popped off the silver trim piece around the buttons (the plastic part that tells which each button is.). On the keyboard, there is a locking button on the front right side of the button control panel that keeps the keyboard locked in place side to side. I pushed it up/back and moved the whole panel over to the left, and then lift it out and rest it in the paper tray so that it is out of the way. You are then left with two tabs (one on each side) on the front of the unit that hold the scanner onto the unit. I placed a flat screw driver under them and popped up the scanner. Be careful, I can see stress lines in the plastic where it almost broke... The top of the unit should be loose. Take it off, turn it over and set it on your workspace upside down. I kept all the cables plugged in. The glass was foggy and dirty, I removed the glass and cleaned with windex. I then put things back together in reverse order and my unit is working like new!
    Genius:
  • 1,605 Answers
Check all the papaer path are clear, and all the parts are in the correct place and installed correctly.
Posted on Oct 10, 2008
Hp 1018 printer making really load grinding noise and not printing
ok first try restarting your printer, then try uninstalling the driver for your printer off your computer, restart your computer and printer and then reinstall your drive for the printer, see if you get a replacement for your printer or a refund
Dec 01, 2014 | HP LaserJet 1018 Printer
I have HP laserjet 1018 printer and it makes noisy sound when it prints. But it prints fine though. What causes making this noise?
The noise is probably due to the print heads aligning and clicking. To try to make this noise a little quieter, clean and align the print heads.
Mar 23, 2011 | HP LaserJet 1018 Printer
Hp 2115 - clicking noise from carriage, can`t print test page
I have an HP 6110 is always has a grinding noise.No functions work. HP just want me to buy a new machine. They are bad quality 3 in one's. That is for sure.
Jun 28, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Noise from HP LJ 1020
Change the gears , coz when the machine load or when you are printing the roller turn, and those roller has gears at the ends so when they are died they give those sounds, open the cover and try to detect which gear make this noise and change it.
Mar 01, 2009 | HP LaserJet 1020 Printer
Scanner failure hp 6110 - Noise and stuck head
the error message refers to the hardware issue of the printer. Below is the document that i need you to follow to somehow resolve your issue.
CLICK HERE==>> DOCUMENT
Please let me know if the document that i gave to you resolves your issue.
thank you so much.
adonscott
Jul 19, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Makes noise
Click HERE for HP troubleshooting for your printer.
Jun 06, 2008 | HP Officejet 5610 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
461 people viewed this question
Ben Johnson
