Question about Minolta Office Equipment & Supplies
MINOLTA COPIER EP 1083 IMAGES TO DARK, NEW TONER, CHANGE PAPER
THE MINOLTA COPIER EP1083 IS SUDDENLY PRODUCING VERY DARK IMAGES. CHANGED OUT THE TONER, CHANGED PAPER, CLEANED GLASS, BUT ALL TO NO AVAIL.
THERE IS A USER CHOICE FUNCTION BUT I DO NOT KNOW HOW TO USE IT OR EVEN IF I SHOULD.
SO ANY SUGGESTIONS WOULD BE HELPFUL.
THANKS
BOB
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 191 Answers
What is your exposure lamp brigthness condition? checkyour upper high voltage adjustment , check your exposure lamp & bright it & clean your copier lens.thanks.
Posted on Oct 05, 2008
I have a Minolta CSPRO EP1083, it stopped making copies, the paper comes out blank. I put a new toner bottle in and the paper still comes out blank.
Problem on lower charger.Some times wire was broken .It has 2 wire one saparation wire and other high voltage wire may any one broken.Assemble new wire may be it fix problem.Other lower charger was damaged ,need new one .If you try clean all socket and dry.I hope your copier good working.
Aug 02, 2011 | Minolta EP1083 CS/PRO Copier
Dear sir my minolta problem the minolta is stoping after copier one paper please i needed the of 1083 including the problems and soulving for this copier
IS there toner in the machine or is it low if low you need to add toner if there is toner try doing an f8 adjustment
Jan 23, 2011 | Minolta EP1083 CS/PRO Copier
Date 18th May 2010 Dear Sir What is the
THEY ARE BASICALLY THE SAME MACHINE THE 1085 HAS MORE FEATURES.THOSE MACHINE ARE ABOUT 10 YEARS OLD AND PARTS ARE BECOMING HARD TO GET. I WOULDNOT BUY EITHER.GET A NEW DIGITAL COPIER AND YOU WILL BE ABLE TO PRINT FAX SCAN AND COPY AND PARTS WONT BE AN ISSUE FOR MANY YEARS
May 18, 2010 | Minolta EP1083 CS/PRO Copier
How do I install developer into my Minolta CS Pro 1083 copier?
Sir for developer will require you to remove the image unit then clean out the old developer and add new. Then run the service mode F8. Be careful of the drum keep it dark /covered. Recommened a technician for this
Apr 24, 2010 | Minolta EP1083 CS/PRO Copier
I have a Minolta EP 1083 the copies that it gives smudge
If fuser rollers are getting hot - you either lack pressure between upper and lower rollers Restart; remove/dump old developer - instal correct compatible starter reinstal imaging unit remove toner ctg. key in stop 0 stop 1 tec rep run F-8 mode runs apx. 2 min. exit svc mode If whats not fusing is gritty(starter) - other issues
Jan 19, 2010 | Minolta EP1083 CS/PRO Copier
Minolta ep 1083
i still think its your developer unit is causing this problem,do this take out the drum unit remove the developer unit and rotate the develper unit gears clock wise and look for void areas on the magnet roller where develpoer adhear .
hope that help
and check your fuser rollers ?
Nov 02, 2008 | Minolta EP1083 CS/PRO Copier
Minolta ep 1083
why is this still posted?
this was solved
Oct 30, 2008 | Minolta EP1083 CS/PRO Copier
PAPER FEED
you can disconnect the sorter.if that's all you need
Oct 16, 2008 | Minolta EP1083 CS/PRO Copier
Help please - my Minolta EP 1083 won´t work properly.
did you try to cleane the optic section ,make sure to remove the lens cover and clean mirror on the right side too underthe len cover,2 remove drum check and c if toner on drum?
Sep 24, 2008 | Minolta EP1083 CS/PRO Copier
101 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
