Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA D52W27D The Three Blinks of Death
Hello Willtab,
I have a RCA HDTV Model D52W27D. Similar to others' problems, the front light will light up and turnoff three times. However, twice now it has come back to life. It still blinks three times, but comes on after the third. This morning it did the three blinks of death so I gave it a minute and then tried pressing the DVD power button and it came on.
When the TV finally comes on, the picture and sound are fine.
I opened the DVD and removed the disk that was in it thinking that may have something to do with the problem.
Also, before the three blinks of death started, I noticed that at powering on, the TV was not starting on the channel I was watching the night before, but on channel 2.
I hope I've given you useful information to help me fix this problem.
Star Smith
Somerset, KY
star0200_2000@yahoo.com
  • 1 more comment
  • Star Smith Oct 07, 2008
    Update...I removed the DVD I had in the Built-in player and the TV now comes on like it should. It still starts on channel 3 however, that's not a significant problem. Still, any input from you is still very welcome.
  • Anonymous Oct 09, 2008
    WHen I try to turn on the tv ithe light comes on and then goes off 3 times but the tv never comes on
  • Star Smith Oct 17, 2008
    Is this something I could fix myself? If so, where can I find the circuit board schematics? Thanks you for the fix!
    Star
  • RCA Master
  • 5,138 Answers
Check 3 capacitors on deflection board cp150,cp111,cp114 most of the time this is the problem 2200uf16v /330 uf 35v /220uf 35v.
Posted on Oct 17, 2008
Ladywinn,
Is this something I could fix myself? If so, where can I get the circui drawings for the board? Thanks for the fix!
Star
RCA MODEL D61130 Three green blinks of death fix
Should be a damaged component at its horizontal output section circuit. Might be its horizontal output transistor. Replace it and check. Try this link. http://electronicshelponline.blogspot.com/ There are more than two thousand and five hundred posts. All are related to television and other domestic electronic equipment service help.
May 20, 2013 | RCA Televison & Video
RCA HD56WW66 green light blinks three times then nothing
install the RCA repair kit called the CP50, CP120 and CP114 repair kit from www.tvrepairworld.com the kit also contains the instructions on Cd
Apr 14, 2010 | RCA HD56W66 56" HDTV
My tv will not turn on
CK for Bad capacitors on your Deflection Board its the bottom board on left hand side cp150 cp114 cp120/ if (cp150)- 2200uf 16v is puffed up on top It is Bad replace all 3 capacitors 220uf 35v is the other 2.
Jan 02, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
TV WILL NOT POWER UP IT ONLY DISPLAYS 10 BLINKS
I fixed three of these TV's, one a few days ago.
All three sets had two bad capacitors.
The caps are on the main board towards the front of the set, on the left side.
One cap is 2200uf 16v, and is located inside of a "U" shaped heatsink. The other cap is 330UF 16V, and is outside of the heatsink, to the left of the heatsink. Both caps will look bulged on the top. You can probably get these caps at radio shack for a few dollars. I buy my parts from Mouser electronics.
If you can see that the caps are visually bad, then replacing them will probably fix the set.
Good luck,
Dan
Oct 20, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
POWER WILL NOT COME ON. BLINKS 3 TIMES WHENEVER I TRY.
Look at the upper left hand corner of the main board for two bad electrolytic capacitors. They will have a bulged top if bad.
- Dan
Apr 28, 2009 | Televison & Video
I have a model number D52W27D big screen hdtv will not power on tries three times then shuts off. Also if i push and hold power button, it flashes 9 times. How can it be fixed.
your set is going into shutdown for some undeterined reson the processor has detected a fault in one of about 25 cuircits. are you a tech. As a tech there are few thing i check. there is a special computer interface we use that reads error codes from the processor. but the only thing you can try is to unplug the set and try again in 30 minutes. in general common problems include what is known as the horizontal output transistor, flyback, but this involves troubleshooting it down
Apr 04, 2009 | RCA HD52W59 HDTV Projection Television
Tv's green light comes on then off three times
Check capacitors cp150 ,114, 120 ,if cp150 is puffed up on top it is bad.2200uf 16v and the other 2 are 220uf 35v.
Feb 11, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HD R56WH78 projection TV, picture just got ascew,
You are haveing form the sounds of it convergence problems. I see this all the time on this set at the shop. FIrst question in customer menu under setup do you have the convergence option if not consult the tips and tricks section under fl231 problem. if you do have this you may have other troubles the convergence is controled by three seprate boards.
Nov 08, 2008 | RCA HD52W56 52" Rear Projection HDTV
Rca model d52w19
blinking light indcate a processor shutdown.. the processor has detected a problem in safety circuits and shut down the set. common problem are flyback and horizotal ouptut transistor. the processor has a error log file. technicians can plug a specail computer and read those to determine problem
Oct 28, 2007 | RCA D52W19 52" Rear Projection Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
1,391 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
