Question about Mitsubishi WD-52725 52". Rear Projection HDTV
Timer light keeps flashing on front of tv Yes I have the same problem. TV will not turn on and timer light never stops flashing.
  • Mitsubishi Master
  • 8,617 Answers
Need to replace the capacitors on the DM module. You can get a repair kit for the V26 DM at the following link.
http://servicemanuals.vstore.ca/
Posted on Oct 11, 2008
Replaced lamp in Sony 50WE655 DLTV. Now green light comes on only a few seconds, then red light flashes 3 times stops and repeats. I was told to reste lamp timer, but TV will not come on to get to...
Recheck the tv installation of the tv projection Lamp make sure the installation of the tv projection Lamp it is properly install and tightly and correctly connections of all wires?Yes,make sure the tv Lamp door close tightly and the latch switch closed in it proper prosition?Yes,turn the tv on,if the tv now make alot of clickings noises and the tv LED light flashes.Mean the tv Ballast board it is also dead too and must be replaced,this Ballast board only job are to ignite the tv projection only.
Aug 16, 2011 | Sony Grand WEGA KDF-50WE655 50" Rear...
My Sony tv will not turn on. The standby/timer light keeps flashing red.
Problem with the Sony Trinitron KV-J16PF 20" TV The standby/timer light keeps flashing red
Jun 07, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a Mitsubishi WD-52725 DLP TV and green light (timer) is rapidly blinking after a power outage and set will not turn on. The bulb was replaced a month ago and it has worked fine since. Now it will...
Hello
make a System Reset process. To do this;
If the TV will not respond to either the remote control or the front panel controls and/or will not power Off, press the SYSTEM RESET button with a pointed item like the end point of a paperclip. The TV will turn Off and the TIMER light will flash quickly for about one minute. When the TIMER light stops flashing, you may again turn on the TV. The changes you made the last time the TV was on before you used the SYSTEM RESET button may be lost, however, the changes that were previously saved are not lost.
OK.
Apr 23, 2011 | Mitsubishi WD-52725 52". Rear Projection...
When i try and turn the tv on only the timer light flashes and keeps flashing for a few seconds then stops but the tv never comes on. What do i need to do? Is it worth fixing?
Yes,The LED light indicator"LAMP"flashes?The projection bulb on this tv have never been change about the last 1 1/2 or 2 years,and the tv been on at lest 4 or 5 hours in used a day?The projection bulb require changing,the bulb life span is over.
Jun 02, 2010 | Samsung HCM4215W 42" Rear Projection...
Flashing green light
Did you try this yet
SYSTEM RESET
turn on the TV again. Changes you made the last time
the TV was On before you used the SYSTEM RESET
button may be lost, however, the changes you made
previously are not lost.
POWER/TIMER Indicator
The green light is a multi-function indicator. This light
will flash rapidly for about one minute each time the TV
is plugged into the wall electrical outlet, when power
is restored after a power failure, or using the SYSTEM
RESET button. Do not attempt to turn on the TV again
during this period. Wait for the flashing to stop and
the light to turn off, before attempting to turn the TV
on. While the TV is powered on, the light illuminates
steadily. If the TV has been programmed to turn on
automatically using the Timer feature,
Sep 21, 2009 | Mitsubishi WS-65515 65" TV
Replaced lamp-orange lights still flash.....lame!
Yes, Turn On TV, press and hold Volume Down button on TV front and Split button on remote at same time for 6 seconds to reset lamp timer in TV.
Sep 19, 2009 | Panasonic PT-43LC14 43" Rear Projection...
My tv won't turn on, the timer keeps flashing
http://www.jyerdon.com/tv/
If it`s a 65513 mitsu, this will fix the flashing green light, most of the time, e-mail me with any questions, good luck
buranc@bellsouth.net
Dec 28, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Timer blinking all the time can't turn TV ON.
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Oct 29, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Timer light is flashing but tv wont turn on!
When the timer light stoped flashing the remote control would not turn on the TV. The next time the light quit flashing I held the power button in on the TV for about 5 seconds and it came on and has had no problems since then with the remote or the local TV power button.
Greg Allen
Aug 29, 2008 | Mitsubishi Televison & Video
Mitsubishi WD-52725 52". Rear Projection HDTV Logo
300 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
