I got a new dell ispiron, sony vegas downloaded, and im using a firewire to a usb port. but its not even poping up. idk what i need to load or anything. and im new to all this so try to dumb it down or send links to things i need please
SOURCE: canon vixia hv 30 not recognized by computer
This camcorder uses USB for pictures only. To access pictures, plug in USB cable, set the camcorder to Play and to Memory Card.
To transfer video you need a firewire cable and card. Actual cable will depend on connection your computer has, typically it will be something like this: FireWire_cables.jpg
Additionally, to transfer video you will need a video capture software and codecs, unless the software has the codecs (Nero does). Unfortunately all free video editing software I tried was unable to deal with HD. I had various levels of success with Windows Movie Makver, Ulead and Nero.
You may want to record video in non-HD, and see if you are able to capture that. If your computer can capture that but not HD, and you have the codecs installed, you will need to investigate your computer.
If all you need is a codec, here is a good free candidate: K-Lite Mega Codec Pack
It is of course very frustrating that Canon would include nothing with the camcorder to assist users with video caputure.
SOURCE: Cannot transfer from camcorder to computer.
make sure you are using 4 pin to 4pin firewire which looks like this:
http://www.pcab.co.uk/ebay/firewire%204%20to%204.jpg
After connecting,
Switch on the Cam.
Open Windows Movie Maker and import video from device.
SOURCE: Canon Vixia HV30 will not be recognized
Video transfer is only possible through Fire wire/ 1394/DV cable.USB can only sned pics to your PC
SOURCE: FireWire for camcorder mini dv
Go to this link. Click on "Frequently Asked Questions" and then click on the appropriate link (#4). Basically, once the firewire cable is connected, make sure that the camcorder is in the playback mode, is turned on, and you see "DV IN" on the LCD. If all that is happening, your computer/software should be able to "see" the camcorder and download the video.
