Question about Vivitek V37835 46 in. LCD Television
Vivitek 32 L32PL1A no picture, black screen
When tv is turned on, blue light comes on momentarily then turns yellow.  I know why the turn to yellow (no signal), but don't know why the black screen.  The other day, it came on for approx 3 minutes, then went black again?
Looking for solution
  • Anonymous Jan 11, 2009
    i have the same problem did u find a solution
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 191 Answers
Chek your power module.check your electrolytic capacitors both in the input & output side of the power module.
Posted on Oct 05, 2008
Why does my KD-32FS170 32" Sony Trinitron screen have blue hues
If you turn all of the color out of the TV, the picture should be black and white. If that picture is not a true black and white picture, the TV will produce a color picture that has that behind it. It takes the proper mixture of red, green and blue light to produce white. This is something that is done inside the glass picture tube.
In your case, one color (blue is stronger) and the others are weaker.
It probably had not been used for a while. SOMETIMES, the weaker colors will get stronger with use. Adjust the brightness and picture controls to get the closest you can to a black and white picture, and then add the amount of color that seems right to you. Use the TV and hope for the best. It will improve, but 2%, 10%, or 50%; I do not know. The proper repair is to replace the glass picture tube, which is not an option at this time. So, turn it on, play games, and HOPE for the best.
Dec 04, 2014 | Sony Televison & Video
My Dynex 32" LCD tv seems to turn on and off
The blue light merely indicates that power is getting to your TV. It has internal power supply problems.
Nov 30, 2013 | Dynex 32 in. LCD Flat-Panel HDTV
I have a vivitek 32 in. lcd hdtv.no picture
Tv have problem in power supply board.Check power board replaced the capacitors parts.Like puff up,burst up.Or replaced the whole power board,tries Shopjimmy.com,Ebay.com.
Jan 18, 2010 | Vivitek V37835 46 in. LCD Television
I have a 32 inch sceptre naga. when i turn on a tv, the blue screen appears for less than a second and then goes blank. the sound is still on. what could be the problem
mine does the same thing, before... it would come on when i turned it on & off. But now it blue screens then blank black. Blue means if it stays blue & i turn on my computer it will show all the computer stuff, i have not used TV yet.. But if you can get it to stay blue you can change things with the cc control, or swap..
If you find how to keep it blue let me know please..
Apr 17, 2009 | Sceptre X32BV-Naga 32 in. LCD TV
Syntax olevia lt32hv 32 inch lcd tv. power surge now no picture
The electronics are known to go bad with these TV's, and I'm looking to buy someone's junk TV that has a good screen, rather than have to throw it out.
(So if anyone is out there with a 532-B12 that isn't working, send me a message!)
Yours might be worth fixing - however I know sadly that parts are nearly impossible to get for these TV's, and the manufacturer is virtually impossible to contact.
If you DO manage to contact anyone (manufacturer or otherwise) who can source or supply parts, PLEASE do let me know - it's been nearly impossible for me, and I want to replace my cracked screen in my TV.
If you can't, please let me know - I'll gladly give you a few bucks at least to salvage the screen from your TV, to transplant into mine, rather than turning it into junk on your curb.
Jan 07, 2009 | Syntax Olevia LT32HV 32 in. HD-Ready LCD...
Vivitek tv
I have a 56" model that I have had a similar problem. My bulb burned out in <90 days. Warranty was 90 days on the bulb itself. When the TV picture goes out, the indicator LEDS blink on and off.
Here is what you have to determine:
1) First cover the left LED with a piece of paper so that you can't see it blinking. I don't know if your layout is the same as my TV. You may have to switch the paper blocking the LED.
2) Pay attention to the other LED and READ its' flashing code. In my case, the code was 2-3. It would flash 2 times, pause briefly, then flash 3 times. This meant code 23. That indicated the bulb was burned out.
3) If you look in the manual, It does have a code list of some sorts to tell you of the codes and their meanings. Hope this helps.
Nov 20, 2007 | Vivitek V37835 46 in. LCD Television
Vivitek V37835 46 in. LCD Television Logo
248 people viewed this question
Top Vivitek Televison & Video Experts
Jim Goldsmith
Jim Goldsmith
matt martin
matt martin
Are you a Vivitek Televison and Video Expert? Answer questions, earn points and help others
