Question about HP Office Equipment & Supplies
Set up scanner
How do I set up scanner
  • 905 Answers
Install software then restart the computer , once restarted plug the scanner in the computer and wait for it to see the scanner then after you should be able to use it
Posted on Oct 08, 2008
I have a alpha 9500ml cash register.Recently I bought a Royal scanner(model:PS700-USB),but the register doesn't respond with it.Now even I switch back to my old scnner, doesn't respond either. Why?
There are many settings for scanners. You must program the register settings AND the scanner. You need the big book of setting bar codes for the scanner to change any settings in the scanner. You usually need a special cable to convert scanner to register pinout. It can be a days work even for a technician. They are the probably the trickiest thing to get working on registers so it might be best to get a dealer to do it if you don't have all of the setup information for connecting that register with that scanner.
May 12, 2017 | Retail Supplies
Scanner lose settings over night
Check the PC shutdown time it can shut off in period if there is setting for it .
Jul 19, 2016 | Symbol LS 4278 Barcode Scanner
Scanner fails to format image
Turn off your scanner. Exit the Smart Touch program.
If XP, navigate to this path: C:\Documents and Settings\[User Name]\Local Settings\Application Data\Smart Touch\[Scanner Model]
Windows 7 or 8: C:\Users\[User Name]\AppData\Local\Smart Touch\[Scanner Model]
Delete the "Sys" folder. Turn on the scanner. Re-open Smart Touch. You will see the Sys folder repopulate in the root folder.
Mar 27, 2014 | Kodak i1220 Pass-Through Scanner
When start machine then display shows call for sevice F14
F14 Scanner unit FROM error
Was the main PWA replaced?
YES
Download the scanner total count value into the main PWA in the setting mode (08-388).
NO
Was the scanner unit or scanner control PWA replaced?
YES
Download the scanner total counter value of the main PWA into the scanner control PWA in the setting mode (08-389).
NO
1. Check if each connector between the scanner control PWA (CN6) and the main PWA (CN8)
is disconnected.
2. Check if each connector pin is removed or the harness is broken.
3. Check if any conductor pattern on the scanner control and main PWA is open- or shortcircuited.
4. Replace the scanner control PWA.
5. Replace the main PWA.
Nov 17, 2010 | Toshiba E-Studio167 Copier
When I scan with Symbol DS6707 I normally get letter b showing up after the scanned numbers. Please help!
There is probably an rule set on the scanner from the previous user. To be sure that you are not using any old settings. I would suggest to reset it to factory settings.
Connect the scanner to your Desktop PC. Download the Reference Guide for DS6707 at the page http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=8397807apdf Scan the Barcode Set All Defaults Scan the Barcode Erase All Rules
The scanner is now in factory settings and you can configure it as you need.
Oct 26, 2010 | Symbol DS6707 Barcode Scanner - P/N...
Batteries run down in a little over half a day in my new uniden BC72XLT scanner, is it batteries, charger or scanner?
its most likely the scanner. i had one that used up batteries pretty quick. my advice would be to get rechargeables, and get 2 sets of batteries so when one set runs down you can put the fresh set in the scanner
Jan 13, 2010 | Uniden BC72XLT Handheld Scanner
MS9535 BT Bluetooth Wireless Barcode Scanner Problem
Problem with Scanner settings .you have to load default setting to scanner from Configuration guide which comes with Scanner.
First Scan the Enter /Exit Configuration then select load defaults and at last scan Enter/Exit Configuartion.
Scanner will be o.k
Jul 07, 2009 | Metrologic Instruments MS9535 VoyagerBT...
Fi-5750C Fujitsu scanner can't change grayscale default setting
Photoshop is not an "advanced" scanning program. To get some "production" and value out of this expensive scanner you need a professional scanning program which also may control the settings of the scanner. Use PixEdit which utilizes the built-in jpeg compression in the scanner. Did a test scanning 10 pages A4 duplex fullcolor. Adobe Acrobat Pro used 4 minutes. PixEdit used 20 seconds. Guess Photoshop (in your version) would also scan uncompressed and not use this good scanner optimal.
Jun 26, 2009 | Fujitsu fi-5750C Flatbed Scanner
Setting Scanner and scale back to default settings
Print and scan the barcode below, this will set the NCR scanner/scales to defaults.
Dec 23, 2008 | NCR 7875
Scanning speed problem
The scanners rated speed is for black and white all error correction turned off. As soon as you start doing 24bit colour or grayscale or up the dpi the scanner will start scanning more slowly. I personally get abpout 60ppm with my error correction on black and white 200dpi. (300 dpi scans just as fast although 400dpi will slow down).
Sep 28, 2007 | Canon DR-9080C Path-Through Scanner
59 people viewed this question
Seeker5211
Seeker5211
