Question about Bose Lifestyle V20 System - black Theater System
Bose Lifestyle V20 - no video out, no response to remote control
Newly purchased Bose Lifestyle V20. Connected to TV via HDMI (tested input on the TV with DVD player and works fine). First power-on the display panel shows the language options but the TV does not display the menu as shown in the manual, and the remote control does not work - cannot select the language as expected. In fact, nothing works except the display panel :(
Checked the obvious things such as connections, batteries in the remote, etc., but to no avail.
Any ideas?
JV
  • 1 more comment
  • videosfun Nov 23, 2008
    i have the same problem,
    after letting system set overnight the system would come on but no video out on any source...HDMI,COMPONENT,COMPOSITE tried two different tvs with compostie.. nothing
    all Audio seems to work today just no video not even the system setup
  • leo2cool May 17, 2009
    Thank you teversole, I had the same problem with the video signal and switched it to 115V and it worked!
  • Anonymous Mar 24, 2014
    The picture will be fine at first and then will scramble for no reason. I have trouble shot every connection and know that the picture only does this when the xbox one is connected through the Bose.
Check the voltage setting on the power supply that connects the power cord to the media center. Mine was set to 230V. Changed it to 115V and the video starting working.
Posted on Dec 07, 2008
Bose lifestyle v20
Make sure the HDMI device (TV, Blueray player) is set up for audio output. Usually HDMI 1 is the only connection that has audio out. Also some TVa have to be configured for HDMI audio out.
Dec 07, 2013 | Audio Players & Recorders
I just bought my V20, I plugged it using a HDMI from my dvd to my v20 for the image, and a digital cable for the sound. My image works perfectly but I have no sound. I noticed that the light under my...
Hi - Don't know about the switching LEDs but there is no reason to be using both the HDMI cable AND a digital coax cable to the V20.
You should have a single HDMI (carries video and 5.1 audio) cable from the DVD to the DVD input in the V20.
Regards,
Mikeywaf
Mar 19, 2011 | Bose Lifestyle V20 System - black Theater...
No sound from rear/ surround speakers on Bose V20
Yes, very easy and cheap if you get it from the right place. Fiber Optic going from the output of the device to the input of the receiver. If your lucky enough to have an input/output fiberoptic in your tv, run the fiber from the device to the tv input, fiber the output of the tv to the receiver so not only are you getting the device full surround sound, but you'll also get better TV surround sound for those that are made with Dolby pro logic II sound. (pretty much all the newer movies and shows)
Jun 13, 2009 | Bose Lifestyle 12 System
Hi, I have an error 180 message in my bose lyfestyle V20
"Error 180" is either very bad (video board is defective) or just a temporary fluke and meaningless.. Best case-> the "error 180" could be fixed by a simple reset (unplug the DC power cable from the media center for about 30+ seconds). Worst case-> this will have to be sent to Bose for repair. Try re-seating any HDMI or component cables at the back panel as well. If you can see your system menu (by pressing 'system' on the remote) then the video board may be fine. If not, still reset it before determining anything else. Also, if the input device (DVD player) is connected with HDMI, and the output (the V20) is component.. this canl cause the error as well.
Jun 09, 2009 | Bose Lifestyle V20 System - black Theater...
The remote for Bose lifestyle V20 system does not work with Apple TV. I have component video coming out of the Apple TV into the Bose V20 system and then HDMI from the Bose V20 to a Sony Bravia HDTV. I...
I had the same problem, and called Bose tech support. They put me on track to the solution. The code you need is under AUX, Music Player, Apple where you probably looked already. The secret is that you need to "unpair" the apple remote first. If I remeber right, in apple TV you go to settings, general, remotes and unpair your remote. It still works, but is no longer the only remote that works.
Gerry
May 01, 2009 | Bose Lifestyle 20 System
Bose Lifestyle V20 Error 180
Below is solution from an earlier post, I'm trying it out now as I have the same issue, system bought in Jan 09. I have received and installed the latest update from Bose recently, now this. Will call Bose tomorrow to fix if they can't they will be getting it back.
We disabled the power cord from the back of the media console (where the HDMI cables connect) and left it off for a minute or two.
Powered the media console back on and it is working as expected.
Was told by the Bose tech that the common reason for this issue is due to the use of the HDMI cables that have a propritary security protocol that is used between the media console and the component it is attached to (ie TV, Cable/Sat, BluRay ...ect).
I asked if there was a BIOS upgrade if it was indeed a "handshaking" issue and was told there was not one (yet).
If one becomes available, it will be shipped via mail on a CD\DVD that can be used in a CD\DVD player that is connected to the media console using the HDMI cable.
Mar 01, 2009 | Bose Lifestyle V30 Home Theater System -...
Apple TV and Bose Home Theater
You should be able to connect hdmi from apple tv to bose v30 for picture and sound. You can also run component video to bose and a hdmi out of bose to tv. Just make sure your running hdmi out of bose system to tv if your tv supports hdmi if not use component video cable. Another way which isn't as good of quality is to run fiber optic from apple tv to bose v30 and hdmi straight to tv.
Nov 02, 2008 | Bose Lifestyle 30 System
System Info from Bose not displayed on Samsung TV
Unplug the power cord and plug it rght back in, I had this same problem and was troubleshooting forever.
Jul 19, 2008 | Bose Lifestyle V20 System - black Theater...
Bose Lifestyle V20 System - black Theater System Logo
2,597 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
