Question about CTX Optoma EzPro 610H Multimedia Projector
Optoma EzPro 610H No Display
I have the above projector. When I turn it on I have the bright white light but see no picture. What can I check in the unit? I can not even see the menu when I press the button. Thanks
  • fielstra Dec 22, 2008
    I just see a white screen when I hook the protector up tothe lab top and the menu buttons will not work.
  • blissbna Mar 04, 2009
    Same thing here. I think I may have let it run too long, but the vent wasn't covered. I fell asleep watching a movie so it ran all night. In the morning, it was all white on all the inputs(I do get audio though). I opened it up to check for anything loose but found nothing wrong. Any ideas? This is really putting a damper on my life! PLEASE HELP
3 Suggested Answers
realbat2
  • 68 Answers
SOURCE: Optoma Projector Only Displays White Screen
did u use your function key on your laptop?or did u configure your graphic card so that the output of your computer can be recognise by your projector?or do you try to use your contrast or brightness control at your projector?
Posted on May 12, 2009
projdoc
  • 2237 Answers
SOURCE: optoma ezpro 610h projector displays
over heating and/or bad fan. if the fan stops or slows down, replace it. try www.projectordoctor.com
Posted on Jan 12, 2010
I NEED TO FIND A BULB FOR THE ezpro-610
This is it (in the USA) http://www.myprojectorlamps.com/projector/Optoma/EzPro%20610.html
You mention CTX & Optoma. The link above is an Optoma lamp for the EZPro 610....also note there is a 610H
Feb 16, 2011 | CTX Optoma EzPro 610 Multimedia Projector
Image upside down
I'm on this site because my projector is down after swithcing out the bulb or I could jot down the exact steps for you. It's a very easy fix. When you push the menu button on your projector to get into settings, there is one that will allow you to flip the image. Sorry I can't be of more help
May 15, 2009 | Optoma / CTX EzPro 610H / 615H Replacement...
May 12, 2009 | CTX Optoma EzPro 610 Multimedia Projector
Optoma 716
on the projector, restart your laptop/computer, this will detect automatically. if not then try display settings to 800x600.
Dec 13, 2008 | Optoma (BL-FU180A) Projector Lamp for...
Optoma EzPro 610H Multimedia Projector Display is all white
Your projector is LCD based. That is, basically, a tiny panel is a computer monitor with a lamp behind it to shine through the panel and lense, onto the screen. This all white screen means the pixels of the LCD are all "deactivated" allowing all the white light through. This happens on computer monitors from time to time. I cannot find a blind reset, meaning there's isn't a method of holding down a series of buttons to "reset" the projector.
aside from calling support, as their manual is useless, I would recommend powering the unit off and then unplugging all cables, including power.
Press and and hold the power buttons for 20 to 30 seconds to see if it clears up your issue. Sometimes, after unplugging the unit and pressing the power button on the projector will briefly light the panel lights and then they fade. This may be enough to drain enough power to force the projector to reset to normal conditions.
If if that doesn't work, I'd recommend leaving it unplugged for a day or so and try it again. Beyond that, the controller board for the display may have failed. It shouldn't be the case, but it is possible.
However, I feel the unit needs a simple reset, which normally you'd do though the menses, which obviously possible.
Apr 02, 2017 | Optoma EzPro 610H Multimedia Projector
Optoma EP732H Projector - Image is Whitewashed
Hi tourblack
I wouldn't think that this is a lamp issue , as the lamp will make the picture fade away in brightness and wouldn't look white washed.
Check if the brightness is set to 50% and the contrast on 50% as well.
This could be a colourwheel that is in need of replacement.
May 12, 2008 | Optoma EP732H EZPRO DIGITAL PROJECTOR...
How can I adjust my screen as of now one side is high and one is low,please help
Hi dave4455_uk
You will see two feet on the bottom of the Projector that can be adjusted for height purposes.
Thanks for using Fixya !
Apr 29, 2008 | CTX Optoma EzPro 610H Multimedia Projector
EZPRO 610H...has a red shadow
this is ghosting, caused by interferance. cheaper cables tend not to have metal sheathing and those ferrite RF suppression thingees on the ends, which prevents this problem.
also, avoid running your signal cables next to power cables. If your cables are long (say more than 10m) this may also cause problems.
Nov 22, 2007 | CTX Optoma EzPro 610H Multimedia Projector
Projector problem
it has a faulty rca jack provable. You are lucky you have the computer jack. You can get a little vga to rca adapter i think.
Oct 14, 2007 | CTX Optoma EzPro 610H Multimedia Projector
CTX Optoma EzPro 610H Multimedia Projector Logo
323 people viewed this question
Top CTX Office Equipment & Supplies Experts
jasbo
jasbo
chinopuma
Level 1 Expert
Arora Singh
Arora Singh
Are you a CTX Office Equipment and Supply Expert? Answer questions, earn points and help others
