Laptop is not conecting on line
Ive just got a laptop of my sister so i know it works,but when i am trying to go on line at my own home its not letting me
  • 5,568 Answers
Was it being used in the same home with the same ISP?  If not, you might have to install the new ISP's software or at least change the dialed number. You should be able to ask your sister which service (ISP) she was using and ask her to give you her logon info (password and screen name) to try from your location. She can always make a change to her password afterward to keep you from reading her juicy emails <grin>
Posted on Oct 05, 2008
Yes some how my sister is on my home page
sign out sisters facebook login on facebook and then sign yours in.
Oct 13, 2015 | Compaq wireless Evo Laptop/labtop...
Can I scrub driver, get rid of vista and install my favorite which is XP home
One problem with downgrading operating systems is the risk of components not having drivers for the new os.
You might be able to check online to see if XP will run the drivers for your machine before trying it.
Jun 25, 2012 | Computers & Internet
Parked my car and when i went to drive home it wouldn't start , nothing totally dead. wouldn't start with a boost.
This happened to my sisters cavalier about a year ago. What you want to do is on the + side of the battery follow the red wire lead it should split in to 2 different wires a big wire and a small wire. The big wire should go down to starter and the small wire runs to a fuze box on the drivers side fender well behind the battery. Where the small wire conects to the fuzebox check that conection. On my sisters car it was broken there and would not allow power to get to the PCM, ECM and nothing worked. I hope this helps you out. If you have any questions let me no. goodluck, kyle
Apr 18, 2011 | 2001 Chevrolet Cavalier
My eeepc can't find any wireless network.. While intact my sister also using the same brand can connectautomatically to the internet
try and getting your sister to disconnect her internet connection on her netbook then you try conecting you wireless first then see whatt happens, then she can try it after.. i tryed it and it woked
Jan 07, 2011 | ASUS Eee 4G Notebook
Computer does not connect
NEW LAPTOP? Noticed a lot of post for same Laptop as same time.
If try to use wireless - you need to set-up wireless part of router and wireless part of laptop (Wireless Software).
Setup your network same it is on the PC.
Use Network setup wizard, if not know how in system manager, in the control panel.
Network Name is same on both, MYHOUSE is good.
The only thing different should be NAME, like SYS02,
PC would be SYS01, and IPaddress ( first 3 sections same as PC - Last section is indivual system - example follows:
PC = 192.168.1.40 then LT = 192.168.1.41
Suggest you hard wire laptop to router to verify network connection then work on wireless connection setup after you get connected thru hard line.
Mar 17, 2010 | Fujitsu Siemens AMILO Pro V2010 Notebook
My dell inspirion 6000 all of a sudden wont go online. (it reads the wireless modem and is connected. The wireless internet is working fine) Ive tried a number of obvious checks. any ideas? -jeff Ive...
Check the security settings manually in the wireless conection manger, when you search for wireless networks down bottem left has addvanced options, in here try a few differnt settings and it may sort your problem, i know its been wokring all along but could have chaned some thing there where it shouldnt have automatically. hope this helps in some way.
aoso make sure in network conections , and the wireless conection that the tcp ip settings are all automatic.
Dec 03, 2009 | Dell Inspiron 6000 Notebook
I need help fixing my sisters with my sisters laptop enter button
You're going to have to replace the keyboard... The Liquid has burned out the contact pad on the Enter button..
It could have as well ...reached the motherboard .. you should have it looked at, it will cause further damage.....
If Left On Motherboard... It Will Blow Capacitors And IC Chips, It eats away at the Solder...
Nov 28, 2009 | Samsung NC10-14GW Notebook
Ive got ms off home and student 2007 ive put it on
Yep if you have bought an OEM or personal license you can only install the software for one PC.
You will need a volume license (the least you can get is normally 5) to legally install or just buy another license on-line for the laptop. You will be able to use the same CD to install the software just need to buy the serial number.
Check out what you have HERE
Buy an new licence key HERE download just the key and save £20 you dont need that backup CD.
LOL
Sep 28, 2009 | Microsoft Office Professional 2007 Full...
I have the Targus wireless mouse amw10us. It just
Mine did the same thing, so I took it apart. The flip hinge in the receiver wore through the wire running between the plug & the little board inside. I'm shopping for a new mouse.
Mar 11, 2009 | Targus PAWM001U Mouse
Acer laptop dial up modem keeps droping conection
Who is your ISP?
If the thing works, I am not so sure your hardware is to blame, typically a hardware issue is at fault when it does NOT work, not when it 'sort of' works.
Intermittant issues are the exception to the rule, typically.
This could very well be the fault of your ISP.
Are you the only person using the line? Could someone be picking up the phone and dropping your connection?
If you post the type of Acer laptop you have and the type of modem this might help as well.
There is a freeware program called 'Everest Home Edition' that will help you determine your drivers and your hardware.
http://download1us.softpedia.com/dl/3a358408c0a5c9dc7d586737b9954f49/475f5362/100016369/software/system/info/everesthome220.zip
Hopefully this helps...
Dec 12, 2007 | Computers & Internet
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
