Question about Krups XP2070 10 cup Coffee Maker/15 bar Pump Espresso
Krups xp2070 did you ever find a solution to the blinking lights and lack of liquid on the xp2070?
  • 2 more comments
  • bungle74 Nov 16, 2008
    I can't seem to programme the machine to fill up my desired amount of coffee using the memory button on the espresso. I have followed the instructions to the letter and keep getting flashing lights and a beep after it has poured a very small amount of coffee into the cup. How can i fix this????
  • Richie Winte Dec 17, 2008
    the machine is garbage - made in china piece of ****.  ours doesn't work and is brand new
  • Anonymous Feb 07, 2009
    no water, just flash lights.
  • Anonymous May 02, 2009
    we follow the instructions to make a cup of espresso, the machine sounds like it's making it and then it stops and all the lights flash. No liquid ever comes out!
    New Friend:
  • 39 Answers
In my case the problem was a faulty flow meter. I replaced the flow meter and the unit now works great! The microcontroller expects water flow information to deliver the right amount of liquid. If the unit is not getting flow information it will stop and start blinking.
Posted on Dec 29, 2009
Need Manual for XP2070
http://www.krupsusa.com/Consumer+Services/Product+Support/Results/Manuals/ResultManuals.htm?SelectedService=Manuals&SelectedGuIDService={36EDBCD3-43C5-49F9-916A-09483F86C4FB}&SelectedProdRef=XP2070Click the link and click the Black and Green Icon to download.
Nov 19, 2011 | Krups Coffee Makers & Espresso Machines
Espresso function problem Krups XP2070
Most likely it starts the espresso but stops after a few second because the unit is not getting the water flow information or the unit is blocked. You will know that you have a blockage because not water will come out of the espresso filter but most likely you get some liquid during the 4-10 seconds it operates. My unit has the same problem and I fixed by getting a new flow meter. This unit is installed after the water tank and has wires (3) going to the the power module.
Nov 02, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
My Krups combo espresso/ coffee maker xp2070 will not turn on at all. No blue light when hit either start/stop button.
Do you have power to the control module? Can you set the time or is the display completely dead? Mine was completely dead and I replaced the power module and the display/control module.
Sep 13, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
Dead No power
Hello
You can get replacement parts here
http://www.belstar-electrics.co.uk/
they are very good and will help
Jul 24, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
It wont brew drip coffee
What are the simptoms? Once you pour the water and add the coffee it should start when you press the coffee button.
Jun 02, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
Krups XP2070 coffee machine - new - espresso side - water goes straight into the drip tray & not thru the filter. I have the exact same problem-that's why I'm on here looking for a solution!
You either have a blocked filter or defective valves. Try the unit without the filter to see if you get liquid out of the group. Most likely you have defective pressure valves (pair) which are not too expensiv to replace.
May 30, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
Krups XP2070 - expresso part - timing
It sounds like your flow meter is not working properly. Most likely it goes for about 5 seconds, stops and starts blinking with all the icons on. You can replace the flow meter and get it working again.
Dec 29, 2008 | Krups XP2070 10 cup Coffee Maker/15 bar...
XP2070 can no longer get the right amount of espresso when using ESE pods.
The amount of liquid is programmable but you have to have a working flow meter. Do you get the right amount when doing a single or double espresso? Read the instructions to reprogram the amount of liquid when using the ESE pods which are most likely single shots. If the memory functions does not work then most likely you have a faulty flow meter which is not too difficult to replace and costs < $20,
Aug 04, 2008 | Krups XP2070 10 cup Coffee Maker/15 bar...
This will most likely happen when the pressure valves become defective. Replacing the two valves (they come in pairs) should fix the problem.
Aug 03, 2008 | Krups XP2070 10 cup Coffee Maker/15 bar...
Krups XP2070 10 cup Coffee Maker/15 bar Pump Espresso Logo
794 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
cyfred
Level 1 Expert
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
