Question about Electrical Supplies
Honda EM 2500 Generator
Engine runs fine but does not give power from generator. Breaker is on. No power on either side of breaker.
  • 2 more comments
  • tkachance Oct 08, 2008
    I have the same problem!!! Almost brand new generator and I cannot get it to work. I heard coleman is going bankrupt
  • Anonymous Oct 25, 2008
    almost new same problem engine runs but no power
  • Anonymous Dec 23, 2008
    I have the same problem. It delivers enough power to run two fishouses but dosent kick up when you put a load like a microwave on it. I used it last winter and by manually kicking up the throttle it handles the load just fine, but it wont do it by itself.
  • Anonymous Mar 27, 2014
    I want to change the oil in a Honda gx 400 stationary engine, its an old engine taken from a generator .
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 44 Answers
Check out our testing video!
We hold parts too!
Posted on Oct 28, 2014
HH 2500...
BAD product for me!!!
Posted on Jul 26, 2010
  • 169 Answers
I posted a general tutorial on troubleshooting this problem here.
Rate me?
Carl
Posted on Dec 05, 2008
When I plug in a tool, it runs fine, when I plug it into my house with the breakers all off, it blows the breakers on the generator? My Honda 2200 watt works fine this way?
I think there is overload .kindly measure ur load of consumption. Do not run the generator set with high load it can be cause of circuit breaker Tripp off .
Oct 27, 2015 | Honda Electrical Supplies
I have a troybilt 7000 gas generator that trips the main output breaker when under a load after 5 minutes
1. Make sure that the generator limit is not being exceeded.
2. Try checking and raising the rpm. If the engine can not sustain the load from the generator, it can/will trip the breaker.
3. If the carb is dirty or the engine runs poorly it can trip the breaker. Tune up the engine, clean the carb, make carb adjustments to correct substandard running conditions.
Jan 21, 2013 | Garden
Porter Cable BSI550 W 5,500 Watt Generator With 10 Hp Engine No AC output
Sounds like the generator unit (sometimes called the generator head) has overheated and melted the insulation in the windings. This is the same as an electric motor "burning out", and if this is the case, then the generator is toast. If you happened to notice that the lights or fans were getting dim or slowing down before the breaker tripped (without the gas engine slowing down) then this is most likely the case and you generator is toast. But if the output just suddenly quit, then it is possible that some smaller electrical component has failed. In any case, it's not something external that you can easily reset or replace. Sorry for the bad news.
Jun 13, 2012 | Porter Cable BSI550 W 5,500 Watt Generator...
Generator first time used has beeen sittn aound for a while......starts up running find power turns on for a bit then the power stops producing???? engine still runs tho is it the compastor thats...
Your problem is with the electrical section of your product. Is it possible that your circuit breaker is flipping and cutting off the power? Have you tried plugging in to both of your outlets? Do both exhibit the same problem? All or nothing on all power outputs?
If it's not circuit breaker related, it means your Alternator or power inverter is at fault and that's shop time!
Nimsgame
Feb 15, 2011 | Coleman Powermate Proforce 2500 Generator
Faulty Generator
check for open armature (check continuity at slip rings). Also check that diodes are good (not opened). Engine RPMs should be at least 1800 or 3600 depending on alternator. Probably 3600 RPM (for 60hz).
Also check to see if you have a bad circuit breaker.
Dec 07, 2009 | Electrical Supplies
Generator runs, but produces no power
If it's still under warranty take it back to the retailer and tell them it quit working - don't offer any other information.
If you must fix the E/G yourself - On the generator there's a cover on the back; take the cover off so that the back of the windings are exposed. You should see 4 to 6 diodes mounted to the rotor and stator...those diodes are most likely burned out because of temperature failure, due to overload. You have to take them out to isolate them...they should read .6 Ohms one way; reverse the leads and they slhould read about 1.2 Ohms. If there shorted you'll read 0 Ohms and open infinety.
Anyway, replace those diodes and you should re-establish your field winding voltage which develops you A/C output.
Good Luck,
Mike...
Nov 22, 2009 | Coleman Powermate Proforce 2500 Generator
My honda gx160 generator keeps cutting out after 2 mins
Sounds like fuel flow is restricted.
Is the vent cap on the gas tank clear?
Pull the fuel hose off at the carb and let run into a container from the tank......is fuel flow good while filling a cup or two worth of fuel?
If not check filter at fuel switch or at hose connection at tank for restriction.
It takes about 2 minutes to use up fuel in the carb with engine running.
Sure sounds like a fuel problem.
Sep 06, 2009 | Master Heaters MASTER HONDA POWERED...
McCulloch fg6000mk: generator motor runs, no power.
You need to trace out the power wires the come out of the genset. They will end up on a breaker. With a volt meter measure both sides of the breaker. If one side has voltage and the other side doesn't, then your breaker is opened. Press the breaker in closed to see if it actually closes. If it don't then you will need a breaker. However, if no voltage is being produced, it is possible that the voltage regulator let go.
Apr 11, 2009 | McCulloch 13HP 338 Cc Portable Generator #...
Electrical Supplies Logo
2,713 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
