Question about RCA P52926 52" Rear Projection Television
RCA P52926 MY TV JUST STARTED RUNNING THROUGH THE CHANNELS AND WON'T STOP. WHAT DO I NEED TO DO TO RESOLVE THIS ISSUE?
  • Anonymous Oct 09, 2008
    my television works fine and then all of the sudden starts changing channels, sometimes it stops and works fine for a few hours. it also turns on in the middle of the night by itself, no ghosts that i know of lol
  • 50 Answers
MOST LIKELY CULPRIT IS A STUCK KEYBOARD---THESE U CAN'T CLEAN--MUST REPLACE THE PART--COST OF PART 25.00ISH--TUNICA
PS...YOU CAN UNPLUG THE KEYBOARD--YOU LOOSE MANUAL FUNCTIONS BUT WILL STILL WORK WITH REMOTE!!
Posted on Oct 29, 2008
My RCA E13344 Tv is connected directly to the cable wire (no cable box) on the menu i set the tv to cable tv and serch for the channels. After the serching is done the tv stops at channel 7 instead of...
I'm sorry for the difficulties you're experiencing in getting the few channels. I suggest that you unplug the TV to perform a power resetting and then perform auto programming to resolve the issue. Please let me know if the issue persists.
Dec 29, 2011 | RCA E13344 13" TV
52" rca comes on but flips thru channels and
Try here http://www.consumeraffairs.com/home_electronics/rca.html
Or Try here http://www.google.com/aclk?sa=l
Sep 26, 2011 | RCA Televison & Video
My Volume and Channel button won't work and so I have bout 2 remotes, neither of them have worked, one is the RCR311BR remote which has been noted to work for this tv. What else can I do
I have a 2000 model RCA P52923 and I had the same problem occur a couple of days ago. The sound hasn't worked for a couple of years, but the TV is connected to an RCA surround sound to resolve that issue. Most recently, while watching TV, it began to start scanning channels by itself. I shut it off and unplugged it for a couple of days, but each time that I turn it on, it begins to immediately start scanning each channel. Neither the remote, nor the channel buttons on the set are able to stop the scanning, and neither of them will perform any functions, including turning the set on and off.
Any advice would be greatly appreciated.
Mar 11, 2011 | RCA P52926 52" Rear Projection Television
My tv is showing the green light but the screen is still black. what should i do?
If your tv is RCA P52926 then it is rear projection tv that does not have a Lamp inside, this rear projection tv three picture tubes to make picture/ image on front screen.
I disagree with previous expert given info about Lamp in this tv.
Since tv is an old model so it might got problem in deflection circuit or power supply stop working properly that is why tv is not turning On to show you picture.
Local tv repair shop will help you to get it fix.
Aug 10, 2010 | RCA P52926 52" Rear Projection Television
My big screen tv keeps changing channels. when i set it on one channel
YOu channel changing button on the TV have pressed in, just try pressing the channel button in you tv so that it gets released..
This should solve your issue..
Please rate this solution if this solves your issue, or leave me comment ill help further
RNJ VINODKUMAR
Dec 17, 2009 | RCA P52926 52" Rear Projection Television
My tv won't stop changing channels by itself
I just fixed the problem very easy... The RCA have a front cabinet which is very easy to remove. I took it out and the only thing that is expose is the speakers and the sensor control. Is a little panel about 5" just spray it with dust spray and that what I did Is not changing channels by itself anymore. I save $3,000 I was about to trash it. Im happy I did that...
Dec 05, 2009 | RCA P52926 52" Rear Projection Television
Tv changes channels by itself
If it is not scanning for channels, get an RMA and return for servicing.
Mar 29, 2009 | RCA P52926 52" Rear Projection Television
MENU SCREEN POPS UP, TV CHANGES CHANNELS, TURNS SOUND DOWN
Yes. Its probably a stuck button on the TV's front panel. Try pushing or wiggling each button on the panel. It could be the channel up/down buttons or volume up/down, menu, etc.
When there is a button that is making slight contact, it keeps the microprocessor busy attending to the command its erroneously receiving from the offending button and may not allow other functions to work when this occurs.
It doesn't matter which button is stuck, any of the symptoms you describe can happen.
michtech
Feb 17, 2009 | RCA P52926 52" Rear Projection Television
Volume distortion only on tv setting
RCA HAD A CERTAIN MODEL SERIES THAT HAD A REALLY BAD DESIGN,,IT SEEMS THAT SOLDER CONNECTIONS STARTED BREAKING LOOSE AND DEPENDING WHERE THEY CAME LOOSE,,YOU WOULD HAVE PROBLEMS IN THAT CERTAIN CIRCUIT..TO DETERMINE IF YOU HAS THAT SERIES,,WE WOULD NEED THE CHASSIS # ON THE BACK...
IF THE CONNECTIONS CAME LOOSE IN THE VERTICAL CIRCUIT--THE PICTURE WOULD CLOSE UP ,,IF IN THE TUNER SECTION--YOU WOULD LOOSE CHANNELS ,,IF IT WAS IN THE AUDIO SECTION--YOU WOULD GET CRACKLYN SOUND OR NO SOUND
ONE THING YOU CAN TRY--PUT IT BACK IN THE TV MODE,,GENTLY TAP ON THE CABLE CONNECTOR IN THE BACK OF THE SET AND SEE IF IT CLEARS UP,,IF SO YOU HAVE THE CONNECTION ISSUE--WILL NEED A TECH..GOOD LUCK ..TUNICA
Oct 30, 2008 | RCA P52926 52" Rear Projection Television
RCA P52926 52" Rear Projection Television Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
