Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
Kenmore model c970-655632 LED Display is very dim
Do you know how i can increase the LED display on my kenmore model c970-655632 range? The LED display (clock and oven temp) works but the display is very dim and hard to see. Can you help?
Thank-you
Joe
  • Anonymous Mar 13, 2014
    broiler element is not working,tryed putting a new element but it's still not working. any ideas?
  • Anonymous Mar 23, 2014
    Oven won't heat up. The controls will turn on (make the clicking sound).
  • 943 Answers
Hi joe. thanks for the question . you replace the clock to repair your problem . i have seen this happen on a regular basis . thanks the appliance doc
Posted on Oct 05, 2008
How to fix a Kenmore oven that won't stay on
NOT HAVING ANY LUCK WITH MODEL #, SUGGEST YOU GET A TECHNICIAN TO TAKE A LOOK
Jan 30, 2016 | Kenmore Ovens
Clock light and temp.light fading out.what needs to be fixed
LED clock/temperature light fading an - Appliance Repair Forum
forum.appliancepartspros.com/oven...ranges.../650-led-clock-temperatur...
Aug 20, 2007 - 3 posts - ‎3 authors
The LED clock/temperature/etc control light has been becoming less ... needs to be replaced (board being the oven clock/erc/control board). Control pad temperature light out
Jun 15, 2014
Dim temp lights
Feb 7, 2014
Frigidaire range LED display is dim
Aug 28, 2009
Oven clock & light
1 post
Jun 21, 2009
More results from forum.appliancepartspros.com
Cheap Fix for a Dim Display on an Oven Control Panel ...
Nov 29, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
Range has a very dim display
I have a Jenn-Air double wall oven with a very dim display light. Replaced c3 capacitor 68uf 35w - with a 100uf 50w cost $1.60 closes size available at Radio Shack and works good as new. Requires soldering onto the circuit board. I price a replacement part for $276.00.
Mar 19, 2014 | Jenn-Air 27 in. Electric Single Wall Oven...
316080102 dim
Oven control board is not working # 316080102. You would need to get it repaired as it is no longer available for purchase.
I would recommend a fast, easy and affordable vendor named Partsimple.com. Partsimple has high level of expertise in control board repairing. many vendors do purchase from them then sell as if their own product.
I have also attached a direct link for reference.
http://www.partsimple.com/316080102-frg-r-12.html
Frigidaire Kenmore Tappan Range Control Board Repair Service 316080102
Jan 27, 2014 | Ovens
Display is dim
Hello Friends! This dimming vacuum display is either caused by a power supply failure with the control board, or a the filaments of the display themselves have started to wear-- similar to that of a bad light bulb. Either way, FixYourBoard.com can solve this problem. Contact them 512-355-1108 for more information. The photo below is from a double oven, but we repair single oven displays too.
Jan 16, 2013 | DCS WOS-227 Electric Double Oven
The led display lights have dimmed so much I can't read the. THis is a built in double oven - Kenmore. not sure of the model #
you will need the model # to get the correct control panel for this range . the display has failed and ony repair is to replace it . part # may be on control . and inside the control area there should be a tec sheet with this info .. mm hope this helped ..
Jul 11, 2010 | Kenmore Ovens
Not the right temp in the oven 100 degrees off
I have a kenmore gas range with digital display that will let me increase the temperature up to 35 degrees f*. It says to press BAKE for 6 sec., then use the number pad to increase or decrease then press START.
Hope this helps
Don
Jan 05, 2010 | GE Ovens
Dim LED on SC301 Thermador
local part whare house can sell you a "dim clock" kit for your machine i believe it contains a new display board as well new wire harness
Mar 14, 2009 | Thermador SC302T Electric Double Oven
Thermador model sc272t oven 2 doors have dim display
there is a dispay kit you can order from bosch to fix this problem. it will come with a new display board and power control which is located behind control panel as well
Nov 18, 2007 | Thermador SC272T Electric Double Oven
Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
2,084 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
