Question about Whirlpool Calypso GVW9959K Top Load Washer
HELP! I was washing a tablecloth and now it is stuck inside underneath the bottom part.  I cannot pull it out!  Please help!
  • renee07 Oct 09, 2008
    I have the same problem and my repair man came to repair the washer and said it could not be repaired because there are no parts for the washer anymore. Is he correct?
There are still parts avalaible for this washer. If you have the same problem, you will need nutater replaced. It will cost you around $90.00 with shipping. It is really easy to replace it byyourself. Good luck.
Posted on Oct 17, 2008
You need to replace your nutator, seal around it must heve been bended inside and left gap which caused to tablecloth get stuck. I just got mine replaced, if you have any question and need step by step instruction, leave your phone number that I can reach for help. My best regard.
Posted on Oct 05, 2008
How to get into a table i bought at a second hand store please help
Open the table, get a chair, stool or small steps, and climb in. Remember to pull the tablecloth over before closing the table.
Dec 03, 2017 | Computers & Internet
How to remove wrinkles from polyester table cloth?
After unfolding a new tablecloth, you'll quickly notice those pesky creases. Even after washing and drying the tablecloth, they may still be there and with wrinkles too. Before you iron a polyester tablecloth -- which if done incorrectly may burn, melt, stain or shrink the fabric -- try rewashing and drying it in a manner that reduces wrinkles and helps get rid of creases. Then, iron only if necessary.
Read more : http://www.ehow.com/how_10054670_creases-out-polyester-tablecloth.html
Jun 23, 2014 | Furniture
I have a 8 year old Bosch dishwasher model # shu3032uc /14. There is no water getting in. I put water in, turn the dishwasher on and the water drains out. I do not see any water under the dish washer.
I have covered this in several previous solutions for Bosch dishwashers. I have copied the text below from a previous request for help, rather that write the entire thing again.
If this doesn't help, please post back and I'll try to assist you further.
"It sounds like the flood protection system has been activated. This is most likely due to water in the bottom of the dishwasher (under the washing compartment) or it could be due to a faulty float or float switch.
The first thing to do is check the float inside the dishwasher. It's the dome/mushroom shape plastic part in the bottom of the wash compartment. Have a feel around under the dome and check there isn't anything trapped underneath it (maybe cutlery or a build up of waste). If something is stuck in there, simply removing it should be enough to get you running again.
If it's clean underneath try pushing the dome down gently in case it's just stuck in the up position. If it pushes down, lift it up and down a few more times, clean underneath it and make sure it drops down on it's own when you lift it and let go. If it falls freely, you're good to go.
If there's nothing under the float and it moves up and down freely, next check for water in the bottom of the washer. To do this, tilt the washer forwards then backwards to about 20 degrees. Obviously, if it's under-counter you'll need to pull it right out before doing this. If you see a pool of water on the floor then you have water leaking into the bottom of the washer!
There are several possible causes of this - some are simple and easy to correct - but you should do these checks first, then post back here for further assistance."
Please rate my solution if you find this helpful. Thanks
Oct 17, 2010 | Dishwashers
Pump keeps running, does not take in water and program does not move forward.
Please rate my solution if you find this helpful. Thanks.
Oct 13, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
My wirpool duet sport is leaking alot of water out of the detergent compartment whats wrong? Please help
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
A TABLECLOTH HAS DISSINTAGRATED IN THE WASHING MACHINE ZWF 1210W AND THE MACHINE WILL ONLY EMPTY VERY SLOWLY I HAVE EMPTIED A LARGE AMOUNT OF THE DISINTAGRATED COTTON FROM THE OUTLET IMPELLER CHAMBER BUT...
A lot of the table cloth is stuck under the agiator, you can pull it off and remove the table cloth material from the bottom, this is keeping the aigator from turning and allowing the water to drain, make sure you unplug the washing machine while you work on it.
Feb 13, 2010 | Zanussi ZEBF250W Bottom Freezer...
Simpson enviro 130 washing machine is broken down! Last time used it was stuck on spin, yet not spinning. Once i was able to open door i found the clothing had been thru a full cycle. Since this time i...
There is a small compartment in front bottom of machine where you undo the screw with a coin. Pull out the cylinder and look inside and you will probably find a coin or similar jamming it. When you take the cover off have a bowl underneath as you will get some water coming out.
Jan 19, 2010 | Zanussi F1045W Front Load Washer
Washer stuck in Drain mode, flashes same time, can't unlock control or pause/stop
ck to see if any water in drum if so possible pump clogged ..remove bottom panel pump will have clean out port with large knob turn counterclockwise ..expect flood if water inside but can't be helped if washer is on pedistal open drawer and try setting bucket underneath and have towels handy..after cleaning reinstall port cover and try again..if no water in tub try unplugging hold power button down 20-30 secs and reconnect still have problem door can be unlocked by removing bottom panel and pulling small tab just below lock assembly from underneath
Aug 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
59 people viewed this question
Dan Webster
Dan Webster
Sal De
