Question about Zanussi WJS1265W Front Load Washer/Dryer
Zanussi wjs1265w washer/dryer
Hello thanks for your suggestion to reset the machine by unplugging it for 5mins.I had the machine off for five days and did what you said aswell but unfortunately its still stuck in the 2second spin mode even if you try just to run the dryer without selecting any wash cycle.Can you suggest any other check i could do on the machine your help in this matter will be highly appreciated thanks awaiting your reply Abid.
  • 750 Answers
Hello
Welcome,
if this did not work for you,unfortunately you will need service now!
We have a list of good servicers on our site!
Huuum,
Please remember to leave a rating
Posted on Oct 06, 2008
Machine no power, power supply good, fuse in plug good machine will not turn on.machine type zanussi washer dryer 3 months old.
hello inside the machine theres is circuit board at the bottom there might be a glass fuse on the board which might have blown make sure the power is off before you check it good luck
shaun
Mar 18, 2009 | Zanussi WJS1265W Front Load Washer/Dryer
Nottaking the fabric conditioner
Zanussi washer dryer wjs1265w
This video will show you how to keep your soap draw clear and how to service the parts.
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question..
Jan 23, 2009 | Zanussi WJS1265W Front Load Washer/Dryer
Removing/replacing main drum bearing on a zanussi WDT1085
Yes you do need to remove the drum, it entails stripping the washer down, and it is normal practice to replace the complete drum half with the bearings pre-fitted..
It is not a job to undertake, unless you feel competent to do do it, as it entails al ot of work and time..
Good luck if you decide to proceed.
Plz rate my suggestions.
.Thanks.
Jan 03, 2009 | Zanussi WJS1265W Front Load Washer/Dryer
Zanussi ZJD 125 on a timer switch
No prob, the washer never draws the full 3kw at any one time.
Plz rate this solution.
thanks.
Dec 18, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
hi The door of the dryer is sealed with one or more gaskets to keep the hot air in the dryer from escaping and prevent the cool air in the laundry area from being sucked into the dryer. A deteriorated or damaged gasket greatly lowers the efficiency of the dryer. To check the gasket, hold a sheet of tissue paper near the rim of the door while the machine is running. If the door leaks, the paper will flutter. If the gasket or seal leaks, looks worn or warped, has chunks of material missing, or feels hard and nonresilient, it should be replaced with a new gasket of the same type.
Oct 25, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
OUR WASHER DRYER WONT WORK.
First try power off reset,.. unplug and re try
Jul 19, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Zanussi WJS1265W
Problem 1,
You can remove the entire drawer to clean it out it might be blocked.
Problem 2
Once again this might be the mother board, we had the same problem, easily replaced by a qualified engineer, it now works fine.
Oct 29, 2007 | Zanussi WJS1265W Front Load Washer/Dryer
Zanussi WJS1265W Front Load Washer/Dryer Logo
109 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
