Question about Whirlpool Duet GHW9150P Front Load Washer
Washer tub to lose and bits of melted plastic around tub and on my clothes
    Problem Solver:
  • 10 Answers
Broken drive belt ,losse plley spin brake fails to release, tran frozzen
Posted on Oct 08, 2008
Washer leaks but onlyu during drying cycle
the main drama i have with these lg washer/dryers is the drying vent blocks up with lint which causes excess heat build up around the heater and it often results in a small hole melting through the front tub under the heater vent where it joins to the plastic tub, it also results in water leaking out the melted hole when it dries but not during the wash as the hole is at the top of the tub, parts are relatively cheap for what they are but its a massive job to replace the front tub.
Feb 04, 2017 | LG WM3987HW Front Load Washer / Dryer
Burnt smell bits of plastic found inside
A WM1814CW does not have a built-in water heater, so I think your
load may have gotten trapped between the spinning tub and plastic
front tub cover..Roll back the gray gasket to expose and check the
plastic ring for signs of 'friction' burn..As long as the splinters are
trimmed away and doesn't leak water you should be OK..Watch your
loads..Don't Overload!
Aug 18, 2014 | LG WM1814CW Front Load Washer
Hole in Maytag Neptune front load washer door and flaking or melting of door.
I've owned the same Neptune since 1999 and had this problem happen to me twice, the first time the inside molded plastic door melted through in a circular pattern and had to be replaced. The fact that it was circular indicates that something was rubbing during the high speed spin. That something was a stiff bottomed duffle bag that was rubbing on the plastic door during high speed spin. The washer was full of other clothes that didn't allow the duffle bag enough room in the washer tub, hence it pressed against the plastic door. The second time it happened I got a circular groove melted in, but not through, the plastic door... caused this time by a small child's back pack. I would make sure "rigid" items have enough room to "float" in the tub cavity by not putting in other clothing that over packs the washer.
Oct 15, 2017 | Maytag Neptune Washing Machines
What is the agitator
The agitator is the large part inside a top load washer tub that moves the clothes around while they wash and rinse.
Sep 26, 2011 | Whirlpool Washing Machines
I have a maytag top load washer (Bravos quiet series 300) that has stoped working. it flashes a code of "F51". It did this before and the repair man opened it up and found small clothing items...
Press 2 metal tabs. About 6" from the sides on the front of washer. Plastic ring on top has tabs that need to be disengaged to disconnect the ring. Once ring has been removed the area between the plastic tub & metal tub is accessible. Check for small articles of clothing, like socks or underwear. Inner tub can be removed by: snap up plastic cap (small slot for tool to slip in and pop up). Remove 7/16 nut and remove agitator (may require to be rocked back & forth, sits on a splined shaft). Remove 5 small phillips screws, being careful not to drop any, and pull inner metal tub up (may require it being shimmied back and forth). Removing this tub will give full access to any debris or articles of clothing that may be under it. Please keep in mind that if you're challenged in reassembly
Jun 16, 2017 | Maytag Atlantis MAV6000 Top Load Washer
Plastic in clothes after wash
not generally this occurs when an oversized load did a blanket get washer with other items if so was over loaded and scrapped the tub ring
Aug 29, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Clothing in between tub and will not spin at high speed on spin cycle i think i need to remove agitator to remove whatever is stuck around shaft and tub
Remove the cabinet.
Remove the plastic ring snapped to the outer tub.
Use a wire coat hanger to remove the garment.
Replace the plastic ring and the cabinet.
Mar 09, 2009 | Kenmore 22422 Top Load Washer
Funky smell from working Whirlpool Ultimate Care II
run the washer then smell the motor or see if anything has jumped the tub and causing the clutch to pull harder
Mar 24, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Plastic pulley melting
Whatever the pulley is attached to has seized. Either the water pump or tub drive, or something else has stopped spinning. The belt continued to run because the motor kept pulling it, and the friction from the belt melted the plastic pulley. Hopefully its the water pump, as its the most inexpensive. You should change the belt along with this fix, it has also got hot and probable will not last as long as it should.
Mar 15, 2008 | Maytag Atlantis MAV9750A Top Load Washer
Kenmore 12502100 white plastic dusty residue
Sounds like washer mites. Put some cheese on the top of the washer after the load finishes. Then leave for at least 60 minutes. The mites will eat the cheese, be satisfied, and your wash will be good next time.
Jan 08, 2008 | Kenmore 12502 Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
79 people viewed this question
Dan Webster
Dan Webster
Sal De
