Scott 370r stereo receiver suspect deffective capacitor.
Am wondering where i can find the wiring diagr so i can diagnose a problem
Need a stereo wiring diagram
Hiya,
Here's the wiring connections for the Kenwood KDC-3025.
Black: Car chassis (-) ground wire
Yellow: Battery (+) wire (must connect to retain memory settings)
Red: Ignition/Accessory wire
White (w/black stripe): Front Left speaker (-)
White: Front Left speaker (+)
Gray (w/black): Front Right speaker (-)
Gray: Front Right speaker (+)
Green (w/black): Rear Left speaker (-)
Green: Rear Left speaker (+)
Purple (w/black): Rear Right speaker (-)
Purple: Rear Right speaker (+)
Blue (w/white): Power Control wire (used with ext. amp only). Do not expose this wire, if no amp is used.
Blue: Antenna Control wire
Brown: Telephone Mute wire (used with handsfree carkits).
Hope this helps,
Cheers,
Scott
Feb 01, 2013 | Kenwood Sirius KDC-3025 CD Player
No display
open and clean your car stereo receiver and check it again
May 22, 2012 | Kenwood Used Kmr-440u Car Stereo Receiver
When i power up my kenwood ka 893 amp/reciver it does nothing i have replaced all 3 fuses but it does flash bars on the panel
Can you elaborate on this, "I'm wondering if it has to do with a speaker not being in correct post./negitave place"? --- What did you see or do that makes you wonder?
You didn't answer if the fuses were blown or if you just changed them for lack of anything better to try, like checking the manual, which says to suspect shorted speaker wires if "- - - - - - -" is blinking on the display.
Disconnect the speaker wires and see if that helps the receiver boot up, then diagnose the short.
If it doesn't come back to life I'd suspect it got fried by a power surge or static. I hope not.
Apr 01, 2010 | Audio Players & Recorders
I am looking for a wiring diagram for a 2000 Chevy Cavalier Z24...I believe I have a ground wire problem because the drivers side headlight is very dim (new bulb) and my stereo has been shutting off...
spend 18 dollars and get a tear down manual at autozoe or advanced autoparts, or your local car store. i has awesomewiring diagrs in te back of the book.
Oct 20, 2009 | 2000 Chevrolet Cavalier
Do you have a complete wiring diagram for a triumph triple 1050cc
No, but you might seriously consider a service manual for your bike. buy from your dealer, or a bookstore. You can also go to your local library reference section. Look for auto n motorcycle repair in the 646 area. But I suspect you'll mire likely find yer elec diagr in the service manual.
Oct 17, 2009 | 2005 Triumph Tiger
No power to stereo.
use wiring diagram back of stereo. check 12volts supply by multitester dc.
May 30, 2009 | Kenwood KDC-5011 CD Player
I have to reset my channels on my sendai car stereo every time i turn engine off
I would suspect that the radio is not installed correctly. There should be 12V present on one wire for retaining memory. There is a capacitor inside the radio that will retain memory for a short time (less than 5 minutes), but you should not have to reset the system after each start. If the wiring is correct, then the internal memory system may be defective and require replacement.
Dan
Mar 17, 2008 | Audio Players & Recorders
Clock set
You can download the manual below: http://inform2.kenwoodusa.com/manuals%5CKDC-MP3035.pdf
Aug 06, 2007 | Kenwood KDC-MP335 CD Player
249 people viewed this question
 Grubhead
Grubhead
