Receiver puts up PROTECT message
When the receiver is turned on it is OK for about 30 seconds. Then the message"PROTECT" comes up.
Not enough information provided - problem is likely impedance / load related. Receivers / amplifiers usually self-protect when the resistance they expect to see as provided by a loudspeaker is too low, or bypassed by a shorted circuit. Check your loudspeakers' impedances - impedance is measured in ohms. The loudspeakers' native impedances, as-built, may be too low for the amp. You can check the amp's requirements in the spec's section in the manual. If the numbers check-out, then put a multimeter on each loudspeaker to check their impedance. A failed loudspeaker can have a tanked impedance, thereby cascading instability to the amp. If you are driving a dynamic arrangement of loudspeakers with room-borne volume controls, a multi-meter won't likely reveal accurate impedance, you will need an Impedometer to test. And, most importantly, make absolutely certain that there is not a single strand of conductor errantly shorting at all terminations.
Posted on Oct 05, 2008
Sony Receiver STR-DE325 is saying protect
If the unit does turn without protect without the speakers,
then you just found the cause.
If the unit is still in protect it needs servicing.
Have a tech to guide you if you need to DIY.
Board level troubleshooting is the next thing to do.
these may take some time, but i do hope youll make it.
Oct 03, 2012 | Audio Players & Recorders
I have a Sony STR-DE 597 reciever. I have been using it fine for a few years with no problems and it sounded great. I turn the unit on recently and a message was displayed on the unit that said PROTECT....
Protect will usually show up if the receiver was turned up too loud to the point where the speakers will crackle, the receiver will switch to protect to not damage anything. Unplug it for about 30 seconds and check all the audio wiring in the back to make sure everything is plugged in good and tight and no loose cables or stray pieces of copper audio wire and plug it back in.
Aug 21, 2011 | Sony STR-DE595 Receiver
I turn on my noise and it says video 1 for a few seconds then keeps saying protect
The receiver has an output load problem, turn the unit off, remove the speakers and wires, now! turn it back on and reduce the volume right down, if the word protect stays off you have a short in the wires or one of the speakers. However! if the word protect comes back on "with the wires and speakers dis-connected" there is a short in one or more of the audio output ic's in the receiver, this will require a technician to troubleshoot the extent of damage and cost involved.
Jan 29, 2011 | Sony STR-DE845 Receiver
I just bought a new Sony STR-DH510 reciever, I connected a sub woofer and 2 surround sound speakers to it and it worked perfectly. The next day I go to turn it on and it will turn on for about 30 seconds...
Problem is in the amplifier output stage...there is probably a shorted component...the short could have come from a bad speaker..or the speaker wires getting touched together while it was on...you could return to store if it is new and get a new one...maybe it was a return and accidentally got put back into stock
Jan 20, 2011 | Sony STR-DG510 Receiver
My Sony XMGTR2022 goes into protect mode at
I discovered that there is a compatiblilty problem between the Bose receiver and the Sony amplifier. If I disconnect the receiver from the amp then the amp starts up normally. Apparently the receiver sends out a dc offset or a "thump" that the amplifier doesn't like and goes into protection mode. I solved the problem by putting a 1 second delay circuit between the receiver startup and the amplifier startup. A simple RC delay on the remote input to the amplifier solved the problem.
Sep 03, 2009 | Sony Xplod 1200W Class AB Bridgeable 2-Ch....
Audio protect keeps turning off my receiver (sony STR-DE597)
That is the common symptom of the defected STK-IC in power amp.section that busted already or just a loose connection.First try to resolder the pins of STK-IC and also all component parts joint in power amplifier section if its works! if not that is the time you replace it, so it works normal again.
Hope it may helps you...
Jun 08, 2009 | Sony STR-DE597 Receiver
No sound in DVD mode
when i turn on sony receiver it will not play it just says protect on the screan
Dec 21, 2008 | Sony STR-DE445 Receiver
TX-DS555 Audio Video Control Receiver
Get it serviced. It apparently has a circuit problem
Apr 22, 2008 | Audio Players & Recorders
Receiver shuts offs automatically
Mine did same thing-when I put on my strongest reading glasses,I discovered ONE STRAND! of speaker cable was touching (-) speaker output terminal....felt like a fool....Worth taking a second look! attitudeRN@gmail.com
Jun 21, 2007 | Yamaha RX-V1600 Receiver
Amplifier/receiver switches off systematically after a few second of use
Sounds like a bad output channel is causing it to go into protect mode. Time to see a repair tech.
May 01, 2007 | Harman Kardon HK 3480 Receiver
129 people viewed this question
 Grubhead
Grubhead
