Question about Maytag Kitchen Ranges
Need to unlock Sabbath mode from Maytag MGR4452BDW
I have a Crosley gas oven and I had the same problem. According to my manuel it will shut off automatically after 72 hours OR Press the CLOCK pad for 5 seconds - no beep will sound. The Sab will flash and then the time will be displayed.
I hope this helps.
Posted on Mar 08, 2009
I went to a Maytag store and they were kind enough to explain the oven was possibly in the SABBATH mode, because my oven was locked up and displayed only "bATH". It seem the oven came out of this mode all by itself after 4 days, about the 72 hours.
Now is work fine as before.
Posted on May 13, 2009
How do i unlock the touch pad with an error code on my maytag gas range
It looks like you have accidentally set the Sabbath mode.. This is set by pressing one of the pads too long. try giong to the Maytag website and check customer service. You should be able to look up the owners manual and it will show the process for resetting the control back to normal mode. You will need your model number.
Oct 06, 2014 | Maytag Kitchen Ranges
My maytag gemini oven has been stuck in sabbath mode for months and holding the clock button does not help. It does this everytime we lose power and it stays off for months and will turn on when ever it...
This is from the Maytag website it explains how to cancel the sabbath mode;
To cancel the Sabbath Mode:
Press the Clock pad for three seconds.
Or
After 72 hours, the Sabbath Mode will end.
  • "SAb" will flash for five seconds.
  • The time of day will return to the display.
NOTES:
  • Sabbath Mode can be turned on at any time with or without the oven on.
  • Sabbath Mode cannot be turned on if the keypads are locked out or when the door is locked.
  • Most prompts and messages and all beeps are deactivated when Sabbath Mode is active.
  • If the oven is baking when Sabbath Mode is set, the Bake icon will go out at the end of the baking cycle. There will be no audible beeps.
  • If the oven light is desired while in Sabbath Mode, it must be turned on before the Sabbath Mode is started.
  • When the Sabbath Mode is started, the temperature display will immediately show the set temperature, rather than the actual oven cavity temperature. No preheat beep will sound.
  • The self-clean cycle and automatic door lock do not operate during the Sabbath Mode.
  • Pressing the Cancel pad will cancel a Bake cycle, however the control will stay in the Sabbath Mode.
  • If power fails, the oven will power up in Sabbath Mode with 72 hours remaining and no cycle active.
I hope this helps to return it to normal mode,
GENE
Oct 13, 2011 | Maytag MER6772 Gemini Electric Kitchen...
Display is showing 5 ab on panel. model maytag MER5751BAW
It is actually displaying Sab, stands for Sabbath mode. Check your user manual and see how to turn the Sabbath mode off. This should solve your problem. Hope this helps
Sep 01, 2011 | Maytag 30" Self-Cleaning Freestanding...
Maytag performa code: 5Ab
Your range is probably in the Sabbath mode. The error code shown on the display is"Sab", not "5ab".
Press and HOLD the clock pad for 3 seconds to disable the sabbath mode. The range will return to normal functions.
Keep us updated and remember to rate and comment this answer.
Jul 05, 2011 | Maytag Performa PAV2200
THE OVEN WILL NOT HEAT UP WHEN I PRESS TOUCH PAD MODE TO BAKE OR BOIL. INSTEAD IT SHOWS 5 A 6.
Hello & Welcome to FixYa
5A6 is not a error code and is displayed when the unit is set up to Sabbath mode. To reset this error code you can press and hould the CLOCK pad which is located below the display for around 15 seconds. If the problem returns then it is recommended to leave the unit unplugged for 72 hrs so that the problem is solved. Please get back to me if you have any other questions.
Kevin
Jan 02, 2011 | Maytag MGR4452BDW / MGR4452BDQ /...
Still got a problem with mfI2568aeb water and ice don't work
I was wondering if maybe the ice box was in sabbath mode?
Sabbath Mode (SAb)
When the Sabbath Mode is on, all control lights,
interior lights, and the night light will be disabled until
the feature is turned off. Press the Door Alarm pad
for three seconds to restore the lights.
Nov 21, 2010 | Maytag MFD2561HE Bottom Freezer French...
Maytag oven says sabBATH what does it mean?
My Maytag oven also has a "Sabbath" mode and you can check your manual to see how to turn it on/off. I have a different model than yours, but to turn the "Sabbath" mode off on mine, the manual says to press and hold the CLOCK pad/button for five seconds.
Sep 16, 2009 | Maytag 30" Built-In Single Electric Wall...
Maytag single electric built in with a display saying sab bath
It is in Sabbath mode, used for Jewish holidays. Anyway, hold the cancel button for 3-5 seconds and it should revert back to normal operating mode. It will still bake in Sabbath mode but will not display anything due to the laws regarding observation of the Sabbath
Jun 16, 2009 | Maytag MEW6527DDS Electric Single Oven
Sabbath display makes oven inoperable
Hold the clock button "in" for 5 seconds to disable Sabbath mode.
Mar 14, 2009 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Kitchen Ranges Logo
862 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
