We have a pioneer flat screen HD and as of yesterday the only color seen is Green (which is is the dominant color) and blue. Everyones faces is green. Is this simple problem? Would you recommend we get it fixed or just get a new one. This was a $5000.00 TV so I really hope it can be fixed. We purchased it from Best Buy about 41/2 yrs ago. Thank You, Heather
  • heatherao Oct 09, 2008
    we have a pioneer flat screen HD and as of yesterday the only color seen is Green (which is is the dominant color) and blue. Everyones faces is green. Is this simple problem?
    Thank You, Heather
    Thank You, Heather
    President:
  • 2,712 Answers
Try a hard reset first - unplug the TV from power source and remove any cables from TV. Wait about an hour or two and redo all cable and plug into power.
Should that not work, the red module has most likely gone kaput. It will have to be replaced. It is a good idea to replace the blue and green ones as well, as generally all three are replaced at the same time. I wouldn't recommend you opening the set and tinkering around if you have no TV repair experience. You will only make things worse if you do not know your way around...There are voltages inside that can KILL even with the power off.
This is an expensive set and not very old. It is worth getting it repaired. Shop around for various prices, or try the Repair Service box on the right of this window. Enter your Zip code and that will throw up a number of repair centers in your area. Just mention you were referred by Fixya, and you may just get a discount :)
Hope that helps! Please don’t forget to "Accept" the solution if it helped you in any way, or leads you to a fix.
Thank you for using FixYa!
IrishDruid
Posted on Oct 09, 2008
    Scholar:
  • 116 Answers
You can easily do it your self if you know how to use multimeters, solderings irons.
what tools you require is given in the link below
how to do is given in the link below.
how to check is explained in the link below
so please click the link and do it your self
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
if you find hard to be done by yourself you can call a technician and get it done as the same problem is faced by many clients and the problem is repairable.as this is not the time for the new $5000unit.its the time to get it repaired in less then $500.
if you do it your self less then $200.
keep us updated as where you reach..
  • 1,879 Answers
3 guns fire inside the tube the red green ans blue. if one dies, colors go off.
Try getting an estimation then decide if you to buy a new one.
I go for a nice new Plasma.
Posted on Oct 05, 2008
    Genius:
  • 1,146 Answers
Well it could be one of two things, you could have a tube gone out , that would be the red one,,Because tvs are made up of three colors, red ,green, blue,, another thing you could try is ,, check the menu it could be under settings,, its called conversion,, it realines the colors,,a lot of projection tvs have it,,your soposed to do it every now and then ,,or when you move the tv,, but if not , i think its still worth takin it to a tv shop,, because it still works,,fixin it ,,cheaper than a new one ,, well good luck,, let me know if i can be of any assistance,,thanks
  • 10,594 Answers
As its 4.5 years old and pretty expensive too so it has worth to be repaired.
Please call Paioneer Service for its check up.
Washed out colors dominated by green and purple
There is fault on the chroma section and can be related to the board . Also a proper alignement cannot be ruled out unless the fault is seen in detail and so it is best to seek a consensus and estimate before you proceed , not to tamper unless there is a clear direction from the observation.
Dec 03, 2011 | Toshiba Televison & Video
The color was off on the tv i took the bottom back off and there was a box with three screws on top and three screws on bottom that adjusted the colors when i turned the top left screw a little the three...
turn the center dial ( for green) down slightly then turn the other two the red and the blue up slightly to get the best screen without a dominate color screen.
Sep 02, 2011 | Philips 50P8341 50" Rear Projection...
Rca d52120 need more green and red color
sounds like the Blue CRT drive has an issue which causes the blue to become dominate thereby limiting the red and Green CRTs from projecting normally. Is your screen full of blue?
May 23, 2011 | RCA D52120 52" Rear Projection Television
It has blue and green arc colors showing up with duplicate words at the lowest part of the screen-just showed up yesterday It is a Pioneer Elite projection monitor receiver PRO-710HD
Replace Both of Your STK ICs They are Big Black ICs will have STK392-110 on them upgrade ICs to 120s-150s,or 180s Call Mat Electronics for parts
1-800-628-1118 ICs will be on the Left hand side of Chassis Mounted on The very First board,there are screws holding board on Fame/ board also plugs in bottom of chassis.
Jan 21, 2010 | Pioneer PRO-710HD 64" Rear Projection...
Bad color suddenly appeared on Maganavox 437S 52 " Flat Screen HD
it should have a year warranty get it in for warranty repair before the warranty runs out or someone tells you the wrong thing to go and the tv ends up as a big paperweight...
Dec 28, 2008 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Rca d61w20 dominate red & blue screen also very blurry picture
Red and blue present, but no green = bad green CRT is
best guess.Remove lower front panel = adjust screen and focus
controls for best pix..................T.
Oct 30, 2007 | RCA P52926 52" Rear Projection Television
Hdtv/ direct tv service
more then likely you are using component input if you are check to make shore they are hooked up correctly red to red green to green and blue to blue if they are you might have a bad cable I have not seen a color stream board bad yet
Oct 16, 2007 | Toshiba 50HX70 50" Rear Projection...
Color problem
Did you try alignment of color convergence in setting up. Try this
1 Press MENU
2 Select SET UP
3 Select CONVERGENCE
4 Select screen mode ZOOM this accesses the center convergence adjustment.Press set/enter
5 Use arrow keys to aline the red cross to the white cross.Press set/enter
6 Use arrow keys to alingn the blue line in the same manner. Once adjustment is complete press MENU to turn the menu off.
I hope this helps if you cant move the red or blue lines you face the same problem I face. I still havent gotton any solutions to my post about being unable to adjust the red line.You could also call Pioneer's help line 800-421-1404.
Oct 04, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
Electro Med Services...
