Hello. I have a Zenith DLP Projection TV that I bought new from the store (possibly the display in the store) that has been working fine for 2 years. Just only a few weeks ago, the color seemed a little dim and dark and a steady yellow indicatoor light came on accompanied by a prompt at the bottom of the screen that read: If you change the lamp you wil have a better image. The TV, though still very dim, was working fine until I turned it off last night. Upon trying to turn it back on this morning, the power light flashed as it normally does, it sound like the motor was starting (I guess, forgive my ignorance) and then it shut off. I did notice that the lamp indicator button is no longer lit. Would this cause this type of problem going ignored as it did? Would not replacing the lamp and allowing it to die completely prohibit us from getting a picture at all? Thanks in advance for all of your help and support. I. MissTV
  • Anonymous Oct 28, 2008
    I have no light blinking to allert for future problems, How ever I am experiencing issues with the dim look and the clors are not as vibrant,
    I am wondering if these DLP are anything like the older rear projections?
    and occasionally need to have the back side of the screen cleaned, and do these DLP's have a mirror as well?
Sounds like you need to replace your lamp and the tv will work fine until the new lamp goes out. I have had three lamps since Nov 2006 in mine and I have a notice coming up on my Panasonic saying I need to change the lamp right now. Which is strange, because before there was no warning, it worked fine and then when we went to turn it on again, it just did not work until the lamp was replaced.
Posted on Feb 09, 2010
How to replace the lamp i my zenith dlp projection tv
the lamp can be accessed there is a panel held in by couple of scews. Should be easy find the lamp if you had the owner manual, which should be avaible on-line. make sure you don;t touch the new lamp without wearing gloves.
Sep 07, 2014 | Zenith Televison & Video
Zenith z56dc1d dlp tv picture works for about 1 minute then starts shaking and tv shuts off
You may want to get it in a rather warm room and or remove rear cover and use a hairdryer to warm everything up inside the Cabinet--with rear cover off look to see if the fans are dirty etc and if they all come on, if a DLP especially look at the lamp itself and the fan that cools it.
Dec 18, 2012 | Zenith Televison & Video
Tv wont turn on... light blinks yellow as if its going to power on.. and just shuts off... for my zenith dlp 52 inch tv
I had this same problem. The Zenith rep told me to unplug the TV, hold the power button down for 30 seconds, plug it back in and then turn it on. It worked and I haven't had a problem with it since. I hope this helps. Good Luck!
Mar 06, 2010 | Zenith D52WLCD 52" Rear Projection...
I have a 1994 zenith big screen the picture is showing really dar
It could be that the picture tubes have gone down on emission, there is a prcedure that can be tried to bring up the overall brightness but it is just possible that you will loose some picture quality. If it's a 1994 projo tv i am thinking of the three crt system, a gray scale alignment would probably correct the dark condition in your picture, again depending on how far gone is the emission in your picture tubes, if your projo tv is the dlp system, the bad news is that you could be needing some light engine repair. The color adjustment is possible with the availability of a service manual or in the case of the dlp system, light engine repairs or replacement are available from some on line stores.
Jan 12, 2010 | Zenith E44W46LCD 44" Rear Projection...
Zenith E44W48LCD will not power on
I would suggest a bad lamp then...This is a DLP projection correct?
Aug 14, 2009 | Zenith E44W46LCD 44" Rear Projection...
Zenith 52'' dlp tv won't turn on
after an hour tv shuts off and you have to wait to turn it back on
Jun 12, 2009 | Zenith Televison & Video
Zenith DLP-Projection tv 42"
Try this solution which I found on Fixya
This solution is for the zenith 56" DLP. Unplug the tv, either from the wall socket or the TV. While the TV is unplugged hold the power button on the TV for 40 seconds. This lets the excessive power drain from the TV. If this does not work call 1-800-243-0000. This is the number for their help line. This is the fix the tech gave me and it worked right away. Hope this helps and have a great day.
Zenith dlp projection model z52sz80 turns off randomly
Further advice here. If the bulb is over a year old it is suspect.
LG DLP TV wont power up Red indicator lightjust blinks when
and where I got all this information frlom
zenith dlp projection tv blinking red light Google Search
Jan 09, 2018 | Zenith Televison & Video
Z44SZ80/Z52SZ80 | DLP PROJECTION service codes
1. Press and hold the MENU button on the TV.
2. Press and hold the MENU button on the REMOTE
(Hold both until the service menu pops up)
3. Press and hold the ENTER button on the TV
4. Press and hold the MUTE button on the REMOTE
(Hold both until the LAMP LIFE HOURS appears on the screen)
5. To reset the lamp counter and turn off the orange light press select on the REMOTE.
6. Press Select again to con firm the operation.
Jul 09, 2008 | Zenith E44W46LCD 44" Rear Projection...
Televison & Video Logo
109 people viewed this question
Top Televison & Video Experts
