Question about Hotpoint Ultima WF860 Front Load Washer
Dryer tumbler dryer not drying clothes and not heating up Hi my tumble dryer drum spins round as mormal with noise but has lost all heat for drying. Please any help would be grateful im in a flat with 2 young children and baby on the way,so need a soloution as cheap as possible? look forward to any replys. Kind Regards Ange
  • alenange Oct 05, 2008
    thanks for the quick reply ginko, ill look into all options asap x
  • Hotpoint Master
  • 19,396 Answers
When dryer does not heat, or heats too slow, that means that there is a problem either with the heating element, the thermal fuse
Unfortunately the only solution is testing and eventually replacing either the heathing element or the thermal fuse. Both jobs must be performed by a technician.
If you insert model number here you can get replacement parts and exploded view.
See the following suggeations from Repairclinic:
There's no heat If your dryer doesn't heat, check these:
Power from the house
Heating element
Thermal fuse
Wiring
Power from the house Checkto see whether there's power getting to the dryer. Is it plugged in?Check for blown fuses or tripped circuit breakers--your dryer uses twofuses or circuit breakers. The dryer could tumble but not heat if onlyone of the two fuses is blown. If you have circuit breakers, one of thetwo circuit breakers can trip, even if the two for the dryer areconnected.
Heating element Oftena dryer heating element burns out, but doesn't trip the circuit breakeror blow a fuse. The heating element is simply a long coil of specialwire. You can check it for continuity with an ohm meter. No continuitymeans the element is bad and you need to replace it--electric heatingelements aren't repairable.
Thermal fuse Onmany dryers, there's a thermal fuse mounted to the exhaust duct insidethe back cover panel. The fuse--which is about an inch long--is usuallyembedded in black resin and mounted in a white plastic housing. If thefuse has blown, you need to replace it. (You can't re-set it.)
Wiring Acommon problem is for the main wiring connection from the house, at thedryer, to burn and break its connection. Because the dryer can stilltumble with partial power, the connection may be only partiallydefective. You may need to replace both the power cord to the dryer andthe terminal block inside the dryer that the wire is attached to.
Posted on Oct 05, 2008
Hi. My tdvcw bush dryer is turning but not heating up. The temperature light is flashing. There is no reset button on back of dryer. I have a child and need clothes dried. Thanks in advance
My tumble dryer is not heating up! - 24'7 Home Rescue
https://www.247homerescue.co.uk/my-tumble-dryer-is-not-heating-up-2/
My dishwasher won't fill with water! ... My TV will not turn on! ... If your tumble dryerdrum is not heating up, but the drum is spinning normally, then you might be ...
Tumble dryer not heating - White Goods Help
Jan 25, 2016 | Dryers
E15 error code on hoover tumble dryer
Controls
  • The control unit on the tumble dryer will vary among different makes and models. The main purpose of the controls is to allow the user to select the drying cycle. You can choose the time and temperature setting on most units, while others allow custom settings such as moisture sensors and end-of-cycle alert signals. The controls may include a dial or a touch panel and LED screen display. Some tumble dryers allow you to independently select the appropriate time for the load you are drying and separate programs for temperature.
Motor
  • The motor inside the tumble dryer spins the basket to allow the clothes to tumble while being dried. The tumbling action allows the air to pass through the clothing to dry them faster. Heating laundry that is stagnant will likely dry the clothing on the outside while leaving damp clothing inside the pile. The constant motion, along with the heat and steam created by heating the clothing, reduces wrinkles. The motor also powers the fan that delivers the heated air to the basket of laundry. The heater can be an electrical element or gas powered.
Jan 15, 2013 | Dryers
Does not spin/tumble
sounds like a broken belt.remove two screws at lint filter .pry top up at front and lid should lift and hinge back.should see belt or mark on center of drum.remove two screws holding front panel from inside cabinet.lift the front panel off two clips on front of unit belt probably laying in bottom.change idler pulley too.hope this helps please rate my solution:)
May 31, 2009 | Dryers
IT IS POSSIBLE THAT YOUR DRUM SUPPORT & BEARINGS HAVE GONE, WAS IT SQUEEKING & HAS DRUM DROPPED SLIGHTLY??
IF SO ID SAY THAT IT IS THIS MINE WENT WRONG A FEW MONTHS AGO, SO I TOOK IT TO BITS & IT WAS THE ABOVE PROBLEM, JUST AN IDEA OR YOUR MOTOR HAS PACKED UP, OR YOUR DRUM BELT HAS SNAPPED..
May 22, 2009 | Dryers
My electric dryer is heating the clothes, but not tumbling the clothes. It is making more of a grinding noise. Clothes are not drying.
chances are your pullies are gone
this is a cheap fix but a bit complicated to get to the tumbler -Hey you will find lots of change on the process
Apr 21, 2009 | Dryers
Gas dryer's start button doesn't stay engaged
bad start switch on motor, rare. that model # came up as maytag range not a dryer.
Jul 19, 2008 | Dryers
Clothes dryer
washer dryer and dryer ony machines differ in a huge way. the big diff. is the drums on each are completly different sizes. the conventional dryer has the bigger, giving better air flow and tumble to clothes. the w/d has a smaller drum thus less air flow and less tumble between clothes. the best way to see this effect is remove half the clothes after a wash and then select a drying cycle. u will see that by giving the clothes more room to tumble free of each other rather than tumbling in a large ball will dry them. washer dryers are really only a marketing tool.
(ex main brand engineer)
Nov 12, 2007 | Candy DQW150 Front Load Washer / Dryer
Hotpoint Ultima WF860 Front Load Washer Logo
191 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
