Question about Pioneer CDJ-800 Turntable
Cdj800 jog wheel stops working after 45mins
Hi, i've had my cdj800 for about 8 months now but recently it has developed a fault..
After approx 45mins the jog wheel platter won't work in regards to pitch adjustment- ie if a turn the platter wheel anticlockwise the speed of the cd remains the same whereas it should slow. the same goes for i turn it clockwise. rob
  • 68 Answers
Sounds like the jogwheel sensor sheet,if you havent had it repaired you can send it to us.
thanks.
http://www.audiovisualservices.info/
Posted on Dec 03, 2008
  • 515 Answers
The drive motor on this unit is probably about to die, or the contact pad underneath the platter is damaged. In either case, you'll have to take it to a qualified service technician for diagnosis and repair.
- Optic
Digital Analog Therapy
www.repairny.com
www.1200s.com
Posted on Nov 04, 2008
I have an Inglis washing m/c mod. #IL42000. It stops cycle (varies what position) then suddenly starts up again (time varies) What is wrong or needs to be replaced. I changed the tmer approx. 3 months
Something is possibly overheating and cutting out? Or due to recent timer change it may be wire connection that's come loose or a wire has got trapped underneath something and cut through the wire causing an intermittent fault.
Jan 02, 2015 | Washing Machines
Scooter moves approx 10 feet then stops led flashes 8 times then stops
Hi. 8 flashes is a fault code for a motor fault. It will be either worn brushes in the motor or faulty connectors to the motor. This fault code means that there is no circuit through the motor. Probably time to overhaul the motor. Most mobility scooters have plugs and sockets that are really to small to carry the amount of current that they do. Because of this, they sometimes fail.Good luck. Neil.
May 21, 2010 | Invacare Supply Group Invacare Lynx Large...
Plastic over the outer edge of jog wheel on cdj800 is peeling
The jog wheel assy' is in several parts. email me a picture and I'll get you a price for the part you need.
mail@technicsdjuk.com
http://stores.ebay.co.uk/methleykev
Jun 27, 2009 | Pioneer CDJ-800MK2 Turntable
Jog wheel is blocked and hard to spin
Hey, the vci 100 out of the box has the problem of sticky jog wheels, Im not sure how long you have had the interface, but mine took a bit of use to start spinning freely. These jog wheels are definately the weekest link and degrade rapidly, the case is easy to remove there are about 8 screws including one one front and rear edge, you will notice the grafite lubricant used on the jog wheel mechanisim, a fine grade grafite would not go astray when maintaining this moving part
May 06, 2009 | Vestax Vci 100 Midi Controller
Pioneer CDJ-1000 CD Player jog wheel display
The only way of solving this is to bring it to repair shop and get a replacement screen.
Jan 30, 2009 | Pioneer CDJ-1000 CD Player
Displays gone on CDJ800
It sounds like a power supply to the both display pcb's is missing, unfortuanetly i wouldnt recommend attempting to fix this yourself, if you havent had it repaired then you can send it to us.
Regards.
Dec 11, 2008 | Pioneer CDJ-800 Turntable
CDJ800 vinyl modus
Hi Mate
My last post was a CDJ with a separate fault, causing a similar type fault.
99% of the time, this particular fault is the Flac switch under the platter jog wheel, take the jog wheel apart clean the plastic strip that runs around the jog wheel, the one with rubber feet that activates as a pressure switch.
Often there is air bubbles, liquid, condensation in between the two layers - causing it to stay in touch mode. If that doesn't fix it then you need to replace that strip (pressure switch). They are about £30 quid.
All the best and good luck
Dec 04, 2008 | Pioneer CDJ-800 Turntable
LCD won't work
sounds like a jog dial pcb fault or power supply fault to the jog dial, if you havent had it repaired you can send it to us.
Regards.
Sep 23, 2008 | Pioneer CDJ-1000 CD Player
Hi. i have an LG 42inch plasma, approx 18 months old. about 2 months ago, a green stripe developed down the right hand side of the screen, approx 1.5 inches wide. last week a 2nd stripe the same width...
Sadly, the plasma screen is failing. The green strip is no longer functioning properly and the failures will continue to progress.
If still under warranty, get it exchanged.
Jun 12, 2008 | Computers & Internet
Pioneer CDJ-800 Turntable Logo
134 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
