Question about Philips GoGear HDD075/17 MP3 Player
Go gear wont turn on
I only just got it and i charged it up and it light up and flashed really fast so after 4 hours i unplugged it and connected it to my laptop but it says it isnt connected and i cant turn the mp3 on. when its plugged into the computer it doesnt light up and it says its not actually connected what do i do? i cant find the reciept to take it ack :S x
  • dberry569 Dec 06, 2008
    I went to charge it up,cause I have not used it in awhile,when I plugged the charger in, the light lights up but blinks really fast but doesnt seem to charge. when I hook it up to computer it says device not plugged in. can anyone please help
  • 8,596 Answers
Make sure the hold/lock is not engaged first.
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Posted on Mar 07, 2009
24 v ryobi battery won't charge
Minimum FAST charge is 2 hours if it has a fast charge setting. If not, 6 to 8 hours to charge fully. I leave mine on overnight so about 10 hours..
May 22, 2016 | Ryobi Drills
My 2004 Ford F1 50 super crew cab truck or not crank and the landline only - flash is really really fast
When you turn the key does nothing happen at all?
Can you hear relays clicking?
Have you got headlights power?
Does the lights on dash come on?
Is the flashing really fast the alarm/immobiliser LED and is there a sequence to the flashing like 5 flashes then a pause?
Jan 02, 2015 | 2000 Ford Focus
Fast flashing green light when trying to charge
usually fast flashing charge is faulty battery its trying to get volts in to the battery. you see the battery has a charging board on the battery not in the camera the camera sends the volts to the battery and the battery tells the camera its voltage, and when at the right volts stops charging. but these batteries can only be charged to around 10000hrs depending on the type of battery. you see when you get a new battery you need to charge it before use, now this can be 6hrs to 12hrs for fist time use if you interrupted the charge or have a power cut while it charges it can damage the charging chip in the battery. if this does the flashing light on other batteries then the signal is not being read by the camera and the camera can be faulty on the charging circuit, usually (sometimes) removing the battery for a few hours can fix this but it will rest the camera. hope this helps you.
Mar 24, 2014 | Nikon Coolpix S6300 Hd Digital Camera
Have dell d610 battery light flashes 4 times red then one green, can't unplug
I would take note of the message you are getting and buy a new battery. I believe the red flashing lights mean that one or more of the cells in the battery are dying, and it's best not to turn off alarm lights like these. Did the battery hold charge for a longer period than one hour before you started to see the flashing light warning?
Apr 22, 2013 | Dell Latitude D610 Notebook
YT-9014A1 will not sync
i just sync both of mine to my ps3 it was giving me difficult at first, but i noticed the when u first put in ur usb wireless thing it starts to blink really fast and when u push the p3 button on the controller twice it flashes really fast. so i took out the wireless usb thing then put it back in so the light on it would be flashing really fast like it was searching for somthing, then press the p3 button twice to make the lights flash really fast aswell so it will sync with it. Thats how i got both of my controllers synced we my ps3. the lights on on the wireless usb thing and the controller lights must be flashing fast at the same time to sync.
Mar 06, 2010 | Sony Wireless Controller for PS3
02 Chevy Cavalier - Fast Clicking Noise When I Turn Key
your battery isnt holding enough charge to crank the starter.thats what the clicking is. try charging you battery for a good 8-10 hours, if it still does the same thing you'll need a new battery.
Nov 02, 2009 | Chevrolet Cavalier Cars & Trucks
My glowbouy flashes green and red...what does this mean
According to the owners manual for these swimming pool lights, this is what each colored indicator means. Hope this helps.
Solid green
The battery pack is fully charged.
Slow flashing green
The battery pack is almost fully charged.
Slow flashing yellow
The battery pack is half charged.
Medium flashing yellow
The battery pack is less than half charged.
Fast flashing yellow
The battery pack has almost no charge.
Fast flashing red
A charging error has occurred and the light should be unplugged and then plugged back in. If the Fast Flashing Red persists after several attempts, the battery condition is questionable.
Also in the trouble shooting guide, it mentions this:
Problem: Red Indicator Light Is Flashing While Charging
Solution:
A red flashing indicator light when charging indicates a selftest
error condition. Unplug the product and plug it in again.
Try this several times; if the indicator light continues to flash
red, unplug the GlowBuoy and take it to an authorized service
depot.
Oct 22, 2009 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
Nokia 5800 wont charge?
Use different charger. When charging leave the phone off. Fully charged after 4 hours.
Jun 10, 2009 | Nokia 5800 XpressMusic Smartphone
Pearl 8100
let it charge till the light stop flashing
May 21, 2008 | RIM BlackBerry Pearl 8100
Camera wont turn on!!! i hear gears turning
Fuji Technical Support team website is the place to ask for further advice. But if the camera is more than a ear old - replacement is the only remedy.
Jul 01, 2007 | Fuji FinePix E510 Digital Camera
Philips GoGear HDD075/17 MP3 Player Logo
95 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
