Question about Philips bSure SV2 Brilliance Multimedia Projector
Yellow spot in the middle of the screen/picture
Philips bSure SV2 Brilliance Multimedia Projector. Lamp has 1568 hours in it. Should I replace the lamp assembly?
  • ltito Feb 11, 2009
    The spot on my projector is more of a light green stain. Can this be cleaned?
  • damery4 May 14, 2009
    I work in school. I have replace the lamp and I have a yellow tint in the screen, how can you remove the dust from the inside of the projector??? Instruction for opening the projector.
SOURCE: Philips bsure SV1 , LCD multimedia projector
Pl try M. R. nterprises Mumbai +91 22 23802513/23856204
Posted on Nov 25, 2007
  • 75 Answers
SOURCE: Lost remote control
Hi - if you can't get an original the Logitech Harmony universal remote may be able to do want you want - Google on that and contact Logitech's help phone line in your country.. I may have to do the same with my lost Panasonic Proj'r remote.
Posted on Dec 31, 2008
SOURCE: Philips bsure sv1 projector
press menu, then picture, select mirror, then choose the "Aa" which appear to be the right way up for you, then press ok.   Done!!
Posted on Jan 04, 2009
SOURCE: lamp light flashing
hi during my investigating i found that the eletrorode surge arrester was causing the problem epcos component 800 083 number i found a device from a projection tv and it worked i also checked epcos web site but could not the accurute device number . they will ask u to use a ruler to measure the device size of the component thanks
Posted on Jan 12, 2009
SOURCE: Philips Hopper SV20 Impact Multimedia Projector doesnt power up
hi the power supply of your unit is burnt refer service personnel
shyam
+919867355202
Posted on Feb 08, 2009
Is compatible with windows 7??
Should be. More depends on your computer's output options matching the projectors input options. Also, you may have to adjust your Windows resolution settings to accomodate the projector.
Nov 09, 2013 | Philips bSure SV2 Brilliance Multimedia...
My laptop is not working without driver. Where can I get it FREE?
Look up the manufacturer on the web for your laptop. They should have drivers in "support" or customer support. Most sites want to sell you a driver checker or updater so sometimes you will have to wade through a lot of ads and information to find the driver you are looking for.
Aug 02, 2011 | Philips bSure SV2 Brilliance Multimedia...
Phillips bSure XG1 LC3141 Projector. Images are dull in colour, and also has yellow tinge all over. Have replaced lamp but this did not fix the problem. Unit ~ 7 years old.
Try opening the unit and cleaning the LCD and lens, and also clean the outer lens- it sounds like this unit may have been stored or used in a smokey environment!
Jun 20, 2011 | Philips bSure XG1 Multimedia Projector
My bsure multimedia projecter has gone yellow. the bulb has only done 174 hours. how do i find out if it is still under warranty
It's not the problem with the lamp. The lamp either beams or not. This is the common problem with the blue LCD from tri-color (RGB) LCDs inside of the projector. It may be burnt totally if the whole screen is yellow or just partially (or covered with dust) if there is a yellow blob on the screen. Perhaps it's time to visit a technician.
Apr 28, 2010 | Philips bSure SV1 Multimedia Projector
Lamp light flashing
Jan 10, 2009 | Philips LCA3123 Projector Lamp for Bsure...
Philips sv2 lc4431
Hi there
Did you reset the lamp timer ?
Apr 16, 2008 | Philips cBright SV2 Multimedia Projector
Lamp blinks on bSure XG1
Same here with the bSure SV1. Want to find solution as well.
Feb 24, 2008 | Philips bSure XG1 Multimedia Projector
Oct 29, 2007 | Philips bSure SV1 Multimedia Projector
Lamp light
That light is there to tell you that the lamp is close to the end of its useful life. It simple monitors the amount of current that the lamp is drawing, so if the lamp stops drawing a preset amount of current, the lamp light will come on, indicating to you to order a new lamp so you have one when this lamp finaly burns out. Good Luck
Jun 07, 2007 | Philips bSure XG2 Brilliance Multimedia...
Philips bSure SV2 Brilliance Multimedia Projector Logo
123 people viewed this question
Top Philips Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Philips Office Equipment and Supply Expert? Answer questions, earn points and help others
