Question about Kitchen Ranges
Very noisy operation
Dear Sir,
My Technika D3/900 ragnehood is very noisy. Took down to inspect. Found several fan blades of the centrifugal fan's rotating drum broken. Will this caused the motor to rotate noisily when used at highest fan speed? Where do I get spares or a fan motor drawing to identify the part so I can quote the spare part number to the appliance parts distributor.
Please help.
Al
  • 146 Answers
Yes....this will throw than fan unit out of balance almost the same way the tires on your car get out of balance. The wobble effect at high speed makes tons of noise.
Posted on Oct 06, 2008
Minka f502 is noisy - how do you tighten the screws that attach the fan blade to the motor hub?
With a screw driver? And perhaps you also clean all blades. Sorry if you already did that.
Mar 16, 2015 | Minka Aire Ceiling Fans Gyro Traditional...
Blower fan noisy
there may be a foreign object found it's way into the blower and touching the blades of the fan. it will need to be pulled apart unless you can remove a hose to inspect
Apr 25, 2014 | 2003 Hyundai Santa Fe
Band saw very noisy
This could be several things. To find the noise, unplug it, open the covers and turn the wheels by hand to see if you cand find where the noise is coming from - this might help you find the source of noise if it the blade is hitting something it's not supposed to. If that doesn't find it, you might try removing the blade entirely and running the motor to see if the motor is the source of the noise. If that doesn't find it, you might try putting a different blade on. Good luck.
Oct 21, 2012 | Saws
Marvin Model 1220. I have several of these fans and each one has issues with fan blades either not turning or slowing down and eventually stopping. I took one of the fans apart and found that the bearings...
I own a Marvin model 1220 box fan since 10 years ago. The stand broke on the hooks part. I need the buy the same, please help me on this. It is out of stock in the Internet. This fan is fantastic, but need to keep it clean so the blades don't slow down do to dust
Aug 12, 2011 | Marvin 1210 Floor / Box Fan
My mom's Kenmore HE3 Elite electric dryer vibrates rapidly while operating. She was cleaning out the lint catcher area with a toothbrush and dropped it inside, then decided to run it after several failed...
yes u have to now replace the blower fan housing u may be able to take apart and remove broken piece byt may not run properly or circulate heat and air as it suppose to
Mar 22, 2017 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
How to remove fan motor
Fan
When a fan malfunctions, the problem is usually loose or dirty blades. If the fan won't operate or if it's noisy, cleaning and tightening will usually fix it. Here's how to repair a room air conditioner's fan:
Step 1: Open cabinet and locate fan.
Step 2: Clean away any debris with vacuum and soft cloth.
Step 3: Check fan blade on motor shaft for looseness. Blade is fastened to shaft with setscrew at hub of blade.
Tighten setscrew with screwdriver or Allen wrench. If air conditioner has round vent fan, tighten fan on motor shaft by inserting long-blade screwdriver through port in fan.
Fan is installed in its housing with bolts, and vibration can loosen these fasteners. Then tighten them with wrench.
Step 4: If fan has oil ports, apply several drops of 20-weight nondetergent motor oil (not all-purpose oil) to each port at beginning of cooling season. Step 5: If you suspect fan motor is faulty, test it with VOM set to RX1 scale. Disconnect terminal wires from terminals, and clip probes of VOM to wires.
If meter reads between about 3 and 30 ohms, motor is functioning properly. If meter reads either zero or an extremely high number, replace motor.
To remove the fan motor, remove the fan, the power wires, and several mounting bolts. Install the new motor with the reverse procedure. However, if the condenser coil must be moved to get the fan out, do not try to remove the motor. Call a professional service person.
Mar 30, 2010 | Heating & Cooling
Noisy evaporator fan
A noisy fan is caused by several things. The fan can have the blade touching something behind the shroud (the back wall in front of the fan). It could be the bearings on the fan are no good - try oiling with Triflow oil. The fan blade could be out of balance. Try cleaning any dirt or grime off the blade. Fans are cheap (relatively). Tried a new one?
Some fans are just noisy. Try thin rubber between the fan and the screws that mount it (bicycle tire patches work good for this).
Mar 28, 2010 | Kenmore Refrigerators
My blower motor stopped working, front and back of van.
My rear blower motor stopped working and my Brother took the unit apart. He found out that the fan blade had seized up the unit. After he took out blade and sanded down blades, it worked fine. However, I am not sure about your front unit. Good luck.
Jan 18, 2009 | 1997 Ford Econoline
Noisy whirlpool condensor fan motor
These motors with the plastic fan are apparently failing so often that when I went to the parts store, the owner told me on guy bought 4 replacement motors for his condo complex. Buy the old version of the motor with a metal fan blade. You have to clip off the white connector on the wiring harness and then wire to the new motor using wire nuts (easy). It's a lot cheaper too - $49 for the motor and blade vs alost $100 for the crappy plastic one. Running llike a champ right now!
Nov 17, 2007 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kitchen Ranges Logo
546 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
