Question about Nikon D100 Digital Camera
Nikon d100 cf card not recognized
My d100 was working fine last week. all of a sudden, i have the message
"E" where the remaining exposures are usually at.
i removed the cf card and installed a second card. No luck. "E".
i removed the battery pack and reinstalled it. no luck.
my camera hasnt been dropped, or shocked in any way.
this problem came out of nowhere.
help
Throw it away and be pissed at the guy who sold it to ya ;-)
Posted on Oct 05, 2008
  • 3 Answers
Yes i know about this problem. basically its your sensor reading chip which has burnt out. it can be replaced at a cost of about £40/ so not expensive.
hobble@iol.ie
bye
The compact flash shows only 15 pictures available
If you erased the card in the computer, the camera doesn't recognize what you did and only shows the remaining space. To regain the full use of the card, you need to format the card in the camera.
Jun 06, 2010 | Nikon D60 Digital Camera
Do the Nikon D100 and the D70 share the same in camera Compact Flash unit - not cards - but the hardware to accept and read the CF card? I have a bent pin in the D70 and want to know if I can change out...
I understand what your're looking for.
The D100 is basically an N80 with digital guts. It doesn't share the same chassis as the D70, although it does share the same excellent battery.
Other than that, the D70 was a new design, so it doesn't seem too likely that they would have the same CF sockets.
That being said, unless I had them both stripped apart on the table in front of me, I wouldn't make any bets. It just seems like there would be slight differences in mounting holes and configuration.
Oct 02, 2009 | Nikon D100 Digital Camera
NIKON D100 LCD DISPLAY FLASHING CHA ERROR WITH ANY CF 1 GIG
I had the same problem and thought I had looked closely at the pins in CF slot but after finally taking it to a repair shop, the tech showed me a bent pin. It really wasn't that apparent first time around. He told me its a common problem as long as they use the CF cards. I had the pins replaced and my D100 is working great. Best of luck.
Mar 21, 2009 | Nikon D100 Digital Camera
Nikon D100: suddenly all the pictures are black
Ellen,
When shooting with the D100 do you have the dial on top of camera set to 'Auto'? If so, then most likely you have some how adjusted to the exposure compensation, so your photos are underexposing.
To reset your camera to the factory default settings:
Hold down the bracket and flash button for two
seconds.
These are the buttons marked with a green dot
Take a test photo and see if that works.
Mar 18, 2009 | Nikon D100 Digital Camera
Nikon D100 shows # of pictrues left - on the display -
This is normal. Page 17 of the D100 manual says when the main battery is inserted the display will show the number of exposures remaining. If no CF card is inserted it will show E.
Nov 25, 2008 | Nikon D100 Digital Camera
My D100 will not accept CF cards
You can always try the reset button. It is under the flap where the USB/Video out/ and power connector is. It is just above the power connector.
Oct 01, 2008 | Nikon D100 Digital Camera
Stuck shutter D100 Nikon
The R06 is the buffer indication, not part of the error. It would appear more work is required. Other components may have failed, or the shutter itself may be bad.
I'm afraid this one is not a DIY. Nikon is pricey on repairs, you may fair better checking the repair service search here on Fixya.
Mar 31, 2008 | Nikon D100 Digital Camera
Card error or camera error?
I am having the same issue with every CF card I put in the camera. But when I put the CF cards in other card readers, the pictures are able to be viewed. Not sure why the camera isn't recognizing the pics on the cards???
Sep 05, 2007 | Nikon D100 Digital Camera
CF Error - Card cannot be used
Your problem sounds as if there's a bent pin in the CF card holder inside the camera. To fix it you will have to be very careful with a long blade fine screwdriver. Remember you'll have to straighten it in one go. If you bend them twice you can bet they'll break. A powerfull light to see the bottom where the pins are is needed too. If you're not willing to do the job yourself there's a guy on Ebay USA who straightens them. BMW
Jul 04, 2006 | Nikon Coolpix 5700 Digital Camera
Nikon D100 Digital Camera Logo
309 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
