Question about Konica Minolta magicolor 2300DL Laser Printer
Can not get this to recongize toner?
Low toner and won't go away after I replace. How do you clean contact points
    Champion:
  • 214 Answers
Did you change toner from printer menu or rotate toner rack manually ??? this printer toners must be changed from printer menu, because printer counts toner there is no chip on toner.
Posted on Nov 12, 2008
After refilling my cartridge , it is shown Error light and on display that check toner cartridge.
Dear
Pl. realign the toner cart. clean all high voltage contact points and assure that all contact points gets in touch with the base contact.
Thanks.
Mar 03, 2015 | Office Equipment & Supplies
How do I get rid of the toner empty stop message after replacing cartridge with a Samsung cartridge and turning printer off and back on?
the contact points at the beneath of toner gear may dirty-clean it. if it a refilled toner it needs to replace the toner chip.
thanks
Oct 01, 2014 | Samsung Office Equipment & Supplies
Hello - my Lexmark E120 will print a test page, but won't print anything that I send to it. I just get an error message. There is a green light next to the 'lightbulb' on the printer. The...
The light next to the lightbulb on the printer Toner low/replace PC kit. The printer is ready to receive and process data. In addition, the toner in the toner cartridge is getting low.
Solution:
? Press continue button to clear message and continue processing job.
? Remove the toner cartridge. Gently shake the toner cartridge from side to side and front to back several times to redistribute the toner, and reinsert it. Repeat this procedure multiple times. If the print remains faded, replace the toner cartridge.
For further assistance, please contact Lexmark Technical Support
Sep 12, 2011 | Lexmark E120n Laser Printer
I can ping ok but can;t get a test page. Only suspicious thing is a low toner light that won;t go away even if I shake and bang the cartridge. Does Low toner disable the printer? Thanks
If you go into the CONFIG MENU and drill down to LOW TONER.
If it is set to STOP, that's what the printer will do.
If it is set to CONT*, it will display the message but continue to print.
Hope yours is set to STOP and you can change it.
Jun 08, 2011 | HP : HP4 Laserjet Printer
Simplicity Sno Away Snow Thrower Briggs 6hp engine No Spark
Check engine oil.
Remove wire from low oil sensor and the start.
Replace low oil sensor.
Hope this tip help solve your problem.
r/David
Dec 28, 2009 | Briggs & Stratton Ignition Kit 2-8 HP...
FO3150 HEATER LOW MESSAGE
the heater low message is referring to the fuser temperature. The fuser is what melts the toner on to the paper. It sounds as though you might need the fuser replaced. This should only be performed by a skilled techician. Fusers are very hot in some cases. Contact your manufacturer to find a local repair center
Sep 21, 2009 | Office Equipment & Supplies
Samsung ml-2150 - invalid toner
There are 4 spring contacts in the printer that contact the front of the toner cartridge. There are also 4 contact points to the left side as you look into the toner bay. all must be clean and shiny. also look at the toner cartridge and clean all places where these connect. Good luck!
Apr 07, 2009 | Samsung ML-2150 Laser Printer
3" wide swath no toner laid down
Try replacing the toner cartridge. They will exhibit those symptoms when the toner is low.
Nov 30, 2008 | HP LaserJet 1200 Printer
Printer Says Toner Low, even when I just changed the toner
If this was an OEM cartridge, you may have received a defective one.  I'd suggest contact Brother for a solution.
Nov 26, 2008 | Brother MFC-9420CN All-In-One Laser...
Samsung Lazer Printer CLP-300N will not print
clean the contacts on toner and in printer, shake the toner before putting it in. Reset printer via the html menu!
Feb 22, 2008 | Samsung CLP-300N Laser Printer
Konica Minolta magicolor 2300DL Laser Printer Logo
275 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
