Question about HP Compaq Presario V6000T Notebook PC
Memory card I have inserted a Sony Pro Duo card into the 5 in 1 reader. It works fine but I am now unable to eject it. Is there a release mechanism hidden somewhere? Appreciate your advice.
  • divedude Oct 07, 2008
    had tried that but it did not release
    Problem Solver:
  • 15 Answers
Usually, just press in on the card, & it will pop out. It is a spring loaded release.
Posted on Oct 05, 2008
  • Terry L. Freeman
    Terry L. Freeman Oct 08, 2008
    Maybe I wasn't too clear.
    The same way that you insert the card is how you get it to pop out. Push the card deeper into the slot, & it will pop out, so you can remove it.
    You, also, may be able to go to windows explorer and right-click on the card reader & use eject.
  • Terry L. Freeman
    Terry L. Freeman Oct 09, 2008
    I forgot something, if you are using an external card reader, all you have to do is pull straight out to remove. There will be some resistance, but that is usual.
    What I gave you above is for a laptop... Sorry about that because I assume that it is always a laptop with these type of card readers.
My memory stick duo unable to format?
1. Insert the Pro Duo into the computer's slot. If you are using an external reader, plug the Pro Duo into the reader, then plug the reader into an available USB port.
2. Click the circle in the bottom left-hand corner of the screen to open the "Start" menu. From there, click "Control Panel."
3. Left-click the "System and Security" option. Click the icon labeled "Administrative Tools." Double-click "Computer Management."
4. Left-click "Disk Management." On the right side of the screen, locate the Pro Duo. Right-click it and left-click "Format."
5. Click "Format." This will format the card to its original settings.
Aug 19, 2012 | Sony 8gb Pro Duo Mark2 Memory Stick Card...
My Sony Vaio Laptop computer doesn't acknowledge when I insert the Sony Memory Stick Pro duo with the correct adapter in the slot. I used to be able to used this on my laptop; what happened? I can still...
regarding with the issue that you are having with your sony vaio card reader here are some things you can do
- try to perform a system restore and try to restore the computer to a date that the computer is working fine
- try to reinstall the driver for the memory stick pro card reader
- the website for the driver is www.esupport.sony.com
- as far as i understand your issue you are using the card reader port for the memory stick pro
Dec 12, 2010 | Sony 2GB Memory Stick PRO Duo Memory Card
I want to download photos from memory stick pro duo of sony company
Use card reader and insert your cams stick pro duo memory card/chip into it. Then insert card reader into Pc usb and copy your photos from memory stick pro to your pc.
Aug 19, 2010 | Sony Cyber-shot DSC-S700 Digital Camera
1GB Memory Stick PRO Duo Memory Card: i have a memory stick pro duo card .... but now we...
Hi sir
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • May 17, 2010 | SanDisk 1GB Memory Stick PRO Duo Memory...
    I have a memory Stick PRO Duo 4GB
    YEAH, YOU MAY NEED A MEMORY CARD READER to read your memory stick. because some compters have not all type of card slots. the card reader will solve your problem.
    Feb 10, 2009 | Sony 4GB Memory Stick PRO Duo Memory Card
    Memory stick card reader won't read
    have you installed the driver for the 5-in-1 card reader?
    check hp for your model.
    Jan 23, 2009 | Sony 1GB Memory Stick PRO Duo Memory Card
    I have a simple question. How do I insert my scandisk memory stick pro duo card into my laptop to read? MY laptop has open slot 5 in 1 media card reader. I can insert all my other card and able to read....
    You need an adapter that will convert it into a regular pro duo card. They usually come with the card when you buy it but else should be availabe at you local electronics store.
    Dec 03, 2008 | SanDisk Memory Media
    Ejecting Memory Stick Pro Duo card out of notebook card reader
    Hi, the memory Stick Pro Duo card is (micro), half size as you have noticed you need to buy an SD adapter card. You put your Pro Duo card into the SD card & than put it into your card reader.
    Once you see the SD adapter card on the web site you'll understand. You can buy this at a local BestBuy. Most web sites sell the adapter as a combo, you'll get a micro card & adapter.
    Click the link below.
    http://www.google.com/products?hl=en&q=Stick+Pro+Duo+adapter+only&um=1&ie=UTF-8
    Look at SanDisk 2GB Ultra II Memory Stick PRO Duo w/Adapter
    & you will understand.
    Have more questions? Just ask.
    Good Luck & Have a Great Day!
    Mar 21, 2008 | Computers & Internet
    Just got an ACER Aspire AS5720Z notebook. It has a 5-in-1 card reader. I have a memory Stick Pro Duo card that is extremely small. The manual says the card reader will read it. There is NO eject button...
    HP Compaq Presario V6000T Notebook PC Logo
    73 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
