if u talking about disc games probably doesnt work because the laser is bad or emulators is cause probably the emulator doesnt have games or the psp doesnt apply the requiredments of the emulator.
Does it work when you go to the "game" submenu and scroll down to the disc option? If this works then the autoload game setting is turned off in your settings menu
Ok, let's explain this. RAM does not necessarily make your pc faster. Your pc can be faster if you upgrade your CPU or graphic card(only graphic application will make you notice the increased speed in graphics). RAM can be a bottleneck for application that need a lot of memory like photoshop when working on multiple very high resolution images or 3D cad when working on large assemblies, or VMWare. Vista manages the RAM in such a way that you might notice a slight performance increase and less disk usage during standard desktop activities, but XP doesn't. if you don't use very many applcations at a time and/or you don't use memory consuming applications, the added RAM is not used at all and your computer won't be any faster than it used to be. Video memory is basically the same. you will notice a difference in performance from a large video memory(512MB-1GB-2GB) only if you game at high resolution like 1080p or higher, usually supported only by large monitors like 20" or larger.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Transfer the files in your cell phone jad and
jar. Then type the code *#9998*52824678255# . It will show the code as *#9998*------------Then go to the jad file and
open it. It will install the application. To remember more easily the code is *#9998*javainstall#.
maybe the game doesnt work clean the game with a clean cloth and try again or the version doesnt suport the game if none of dis works contact the store where you buy the game or the console
