Question about Acer Aspire 3610 Notebook
Wireless adaptor not showing default gateway - Acer Aspire 3610 Notebook
    Sergeant:
    Champion:
  • 310 Answers
Are you useing the windows program to configure this? if not switch to the windows program
Posted on Nov 17, 2008
How can I open the page
Locate your router. There should be a label which displays your default gateway. The Default gateway displays a number. It should show a number like
  • 192.168.0.1
  • 192.168.1.1
  • 10.0.0.1
Open your browser (Internet Explorer, Chrome, ETC..) Type the default gateway number into the search engine text box on top of the screen press enter or return (mac). The page should now show user name and password. Locate the router and locate the default credentials. For example. most routers requires the user name to be blank and the password is password. Routers very.
About obtaining an IP address. Routers are usually set to option the IP address automatically unless you manually set a static IP address which is not recommended.
Sep 24, 2016 | TP-LINK TPLink TLWA5210G 24GHz High Power...
My gateway wireless adaptor is not working I cannot get onto internet
FGo to hardware.devices and check for a yellow mark next to any device and in particular your Network Devices. Open the submenus. all of them one at a time and there will be one screen that will show the status. If if states working properly, then that isn't your problem. You still may update the driver from the mfr's site, write down the software version number and date along with the mfr and model number and any description to locate the proper driver. The software version and date should be newer than the one you currently have to install it using a CAT 5 (RJ45) cable connection into your modem. (All wireless modems have at least one CAT 5 (RJ45) port on them to use a cable into your PC.
Aug 13, 2014 | Gateway Computers & Internet
Wireless adaptor show to be turned off but can't turn it on. There is no button on this model. How can I restart the wireless?
Try installing the latest wireless driver. Once the driver is installed it will automatically switch on unless it was disabled in the BIOS setting.
Mar 02, 2012 | Gateway NV53A24u Laptop
Asking for password on itouch when trying to connect to WL-520G. I cannot remember the password.
HI! I bliv u are having some issue setting up ur router.. I will be more than glad to assist u. . here are the steps u need to do:
1. pull up ur browser then type at the url:192.168.1.1.or 192.168.0.1 or u can check the routers default gateway by right clicking the network icon on the lower right of your task bar and click on status and it will show the ip address of the computer, subnetmask and default gateway, the default gateway is the routers ip address, once u type in to the url, it will ask u the username and password, by default the username is admin and the password is 1234 or just leave it blank
2. Then it will show the setup pageof the router, select on the wireless settings, once you ar eon the wireless settings, you will see the wireless security type and the password.
if you have any query pls feel free to get in touch.. good luck
Dec 05, 2009 | ASUS WIRELESS ROUTER |WL-520G - RT...
I have achieved an unsecure w/less network and want to make secure my router is a d link dl 524 with belkin adaptor
1. connect the ethernet cable to port1 of the router and the other end to the lan port of your computer..
2. pull up ur browser then type at the url:192.168.1.1.or 192.168.0.1 or u can check the routers default gateway by right clicking the network icon on the lower right of your task bar and click on status and it will show the ip address of the computer, subnetmask and default gateway, the default gateway is the routers ip address, once u type in to the url, it will ask u the username and password, by default the username is admin and the password is 1234 or just leave it blank
3. it will show the setup page of the router. u can set the router on the specific internet setup that u have.
u can setup the wireless settings, u need to create a ssid or wireless name and a security..on the setup page you will see there, wireless connection settings, you can set your wireless security by using the wep, wpa or wpa2 / tkip
8. once all is set. save the settings and to check if your laptop can access the wireless network that you did, turn on the wireless switch of your laptop, once its on, it will show the wireless network icon on the lower right of the taskbar, right click it and select on view available network, the network name that u did should list, just select it and connect and it will ask for the password, just type the password and connect, you should be connected to the wireless network and have internet access..
4. If you are going to hook up your desktop to the wireless connection, you need to install a wireless network adapter, install the driver and do the same thing as u did to the laptop, for the desktop no need of turning on the wireless switch, once you install the driver correctly, it will show a network icon..
Sep 29, 2009 | D-Link DI 514 Wireless Router (DI-514)
Wireless network adapter keeps disconnecting from router upstairs
Hi
Adaptor has nothing to do with signal strength.
Its the router .
Steps
1. Start -> Run -> CMD -> Ipconfig
( You"ll see default gateway which will be something like ex : 192.168.2.1 )
It is router specific
2. Type that default gateway (only the numbers )
in your brouser tab or run .
3. This will open up your router setup page
4. On the left hand side under wireless you"ll see channell and ssid . Change channell to 11 or 6 click save and then reconnect to your network on the wireless computer.
5. Also i would advice you to update the firmware on the router as it has become old so there may be some discrepency.
6. Dont keep any wireless devices near the router as it will interfere with the wireless signals .
This will certainly help
And let me know if the problem is solved .
Feb 16, 2009 | Computers & Internet
Wireless adaptor xbox 360
make sure that your modem acctually has wireless capability, enter a manuel ip address and gateway that should do it you can find out ur ip address and router settings at routerlogin.net and you should be connected to youre router if a username and password are required then there are websites conntaining all default passwords, most will be admin and password
Jan 18, 2009 | Microsoft Wireless Network Adapter Xbox...
Wireless network adaptor
You can get your WEP Key or WEP Encyption Key on your Wireless Router's Configuration Page.
Open your Web Browser like Internet Explorer or Firefox or Safari, type the IP Address of your Router on the Address Bar (e.g. 192.168.0.1) log in to your router and check the wireless settings and look for your network key.
If you dont know the IP Address of your router, try checking it on the command prompt.
Click Start, then click on run, on the run windows type in cmd for command, a black screen will pop up, in the blinking cursor type in ipconfig for Internet Protocol Configure it will show you the IP Address of your computer and the router's IP Address which is the Default Gateway
Hope this helps
Jul 13, 2008 | Microsoft Wireless Network Adapter Xbox...
Install prob
I suspect these devices by default may be set to either the same IP address or exist on the same subnet. If you know how to configure the devices you can check. Possibly you can connect a computer to each (when not router and modem are not connected to each other) and issue use the open the DOS or command prompt type ipconfig and press enter to get the default gateway address for each device and report the contents back here. Otherwise you may need someone to lead you through those checks and reconfigure the devices as appropriate.
As a new owner of a wireless router you may also want to consider this as you are installing it.
for general wireless security see
http://www.fixya.com/support/t281214-wir...
Dec 06, 2007 | ASUS WIRELESS ROUTER |WL-520G - RT...
Netgear wireless connection
Check the wireless IP address on the XP computer. try to ping default gateway and see whether its giving succesfull reply, after that do ping yahoo.com and check successfull pinging. if it pings successfully the yahoo website , then you should go online.
Oct 24, 2007 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Acer Aspire 3610 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
