Question about Bosch HBL 5056 Electric Double Oven
Programming Bosch Double oven
We have recently bought and installed a Bosch HBN13N521B double oven and are generally very happy with it. One query we do have is whether the two ovens can be individually programmed at the same time - i.e. both cooking separate dishes, but each starting at a different time, for the same meal. The manual is not quite clear about this, and although it appears that the two ovens can be programmed separately, only the bottom oven can be set to start at a specific time - the top oven does not appear to be programmable if the bottom one has already been set. Your help in clarifying this query would be very much appreciated.
    President:
  • 1,462 Answers
Not separately programmable
Posted on Oct 05, 2008
Tip
Common heating faults with Bosch HBL 455 Stainless Steel Electric double oven
For all Free appliance repair videos visit our VIDEOTUTORIALS 1, If the Bosch fan motor in the back of the oven is going round andthe temperature light is on (normally little red light), but there is no heatthen you will probably need a new oven element, these are generally very easyto fit and readily available from our website these can be tested with aelectric meter.
To gain access to the BOSCH element you willhave to remove the back plate from inside the oven. Once removed you will seethe fan and element, if youlook closely at the element you willprobably see a small hole burnt in it where it has blown. Sometimes howeverthere is no evidence of a fault but the element is open circuit ie:broken inside the element casing, either way it will need replacing. Someelements will are fixed from inside the oven and some are held in place by nutsfrom the rear of the machine.
2, If your BOSCH fanoven is getting warm but takes a very long time to cook or is burning the foodmore on one side than the other, then you need to check if your oven fan motor is working you willsee the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven thenyou need To replace the oven fan motor is a little moreexpensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heatingand burning everything then you will need to replace your BOSCH oven thermostat
4, A quite common and easily overlooked answer is if your BOSCH oven is not working at all ie: noheat and no fan then the chances are that someone has put the oven timer into AUTO mode,simply put oven back to MANUAL mode and all should be working again.
on Jan 19, 2010 | Bosch HBL 455 Stainless Steel Electric...
Tip
Common heating faults with Bosch HBL8750UC double oven
on Jan 19, 2010 | Bosch HBL8750UC Electric Double Oven
My bosch double fan oven has cut out and has blown the fuse
there is a little control board that might be defective on .
Feb 24, 2010 | Ovens
Temperature fluxuates constently on our double
The problem is obviously due to a faulty thermostat.
It could be the main oven stat, or an external thermostat that is the cause of the trouble.
Jan 18, 2010 | Bosch HBL 455 Stainless Steel Electric...
Bosch Double oven - top oven will not open - seems like it is locked
i am not aware of a bosch oven that locks the top door usually only main oven will lock if self clean pyro oven,the small oven never has this feature sounds more like a hinge problem check nothing is fouling the lower part of the oven door.
Dec 30, 2009 | Bosch HBL 755 Stainless Steel Electric...
Bosch HBL 5056 Electric Double Oven Logo
300 people viewed this question
Top Bosch Ovens Experts
ashburton
reliableservice
Are you a Bosch Oven Expert? Answer questions, earn points and help others
