Slightly high pressure in C24 Heatline Boiler
The pressure in our boiler is slightly high (should be 1-1.5 and it is around 2-2.5) - it is only 2 years old and we have had someone in to look at it recently as the thermostat was not behaving correctly - so I am confident there is not anything wrong with it - but now that we are starting to use the heat again, the pressure rises up into the 'red' area (3-4) when the heat is turned on. Is this something to be worried about? And is there anything that we can do to release the pressure?
Thanks for any assistance!
  • riversidebab Feb 22, 2009
    hi i have a heatline boiler c24 and the temp keeps going on to the red numbe 4... we keep bleeding it and setting it back to one and a quater...butit goes backup HELP...please
My heat line capriz 25 boiler is flashing that i have flam or gas falure and has stoped workin? what do i do?
Posted on Feb 11, 2009
    Problem Solver:
  • 13 Answers
You should have a filling loop built in to the boiler or external make shaw this is not letting water in to the system, also being a sealed system hot water will expand. so on your boiler you will have a expansion vessel which has to be filled with air so that the water can expand in to it. undo the valve which will be like a tyre valve off a car and quickly press the pin if u get air spay out with quite alot of pressure u should be ok. if empty you need to top it up to the manufactures instructions normaly about 1 bar. if both the above are ok the expansion vessle is broken
Posted on Sep 12, 2009
    President:
  • 1,462 Answers
Crack open any joint in the system like a joint to a radiator and let a little water drip out. you should not use when in the red
Posted on Oct 05, 2008
Red boiler light will not go on. The boiler does heat up.
Open the steam valve when you turn the machine on that will vent out the boiler, keep it open until it starts to hiss slightly and produce small steam bubbles, then close and machine should heat to temp. If that solves your problem then the vent valve needs to be replaced, until then you can turn using the steam valve open trick.
May 31, 2010 | Isomac Tea Espresso Machine
To get heat downstairs i have to turn raiators off
Hi check the water pressure in the boiler check the setting / speed of the pump see if this helps
Feb 07, 2010 | Desa International CBN30T Central Heating...
My boiler lights up,stays on for 1 minute then cutts out...
You could check the flame sensor is clean and the connections are tight . check the pressure switch as well. also get the over heat could be shutting off too soon ,
Check the rads for air lock ,
May 11, 2017 | Water Heaters
Heating pressure gauge goes up
yes tami
there should be a pressure rellief valve fitted.
it also sounds like the heat exchanger is blocked if the hot water is not as good as it used to be and the boiler reaches temperature too quickly then there is scale in the heat exchanger and needs to be cleaned or replaced
Mar 27, 2009 | Water Heaters
Hot water
there are two main faults with combi boilers not giving hot water. one is a faulty flow sensor, the other is the most common which is a blocked heat exchanger caused by debris and scale in the system. this needs to be flushed out or may require a new heat exchanger depending on the age and condition of the boiler some plumbers may suggest a new boiler.
Mar 02, 2009 | Water Heaters
Very Hot water coming out of overflow pipe
Is your boiler heating your domestic hot water if so i would turn water off to water maker and see if your boiler pressure stays down below 20 psi. If so water maker is bad. The other thing that could cause this problem would be the boiler pump is out.
Jan 22, 2009 | Protech Systems FasNSeal FSWMKE4 4" Vent...
No hot water from combi boiler
i have a combie bolier when i turn the hot water taps on only cold water comes out central heating working fine can any one give some advise ?and can i fix it myself.
Jan 03, 2009 | Combi Centre DX - Mango
Heating & Cooling Logo
1,541 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
