Question about Sanyo PLC XU32 Multimedia Projector
Video output goes blank after 10 mins or so. Pressing reset brings it back but after 10 minutes it goes again.
Ok the subject heading just about sums up this recurring problem. Every 10 or 15 minutes or so the screen just goes bIank (except for lines down). Sound is normal and everything else is fine, menu and all other on-display messages are normal. I can hear the fans working and the machine does not appear to be any hotter when the image disappears. There's no blocked ventilation and the filter is clean. Any ideas?
  • CUbill Oct 05, 2008
    The subject line did not display the whole message so just let me clarify the problem. After displaying an image, input source DVD player, for somewhere between 10 and 15 minutes the image goes blank. If I press the reset button the image returns but again after 10 to 15 minutes it disappears.
    Top Expert:
  • Sanyo Master
  • 24,726 Answers
I would check for bad solder joints alongside the Pixleworks Chip.
Posted on Jul 25, 2017
  • 3130 Answers
SOURCE: Screen split with black bar through center, top of picture shows in bottom
It sounds as you desribe, the vertical output IC and or the b+ feed capacitor off the Hi voltage transformer feeding the vert. IC its required voltage. Not a really hard job to replace, but not for a handi person to do. This should be left to the professional, as there are no user serviceable parts inside this set and with the HI voltage and the safety issues its best to call somesone to assist you with this repair. Good Luck
Posted on Jun 14, 2006
  • 3130 Answers
SOURCE: Sound cuts out periodically
Sounds like a poor or cold solder connection in the sound circuit. If your not a tech, this repair really should not cost an arm and a leg to repair , but maybe your first born??LOLOL No really if you have no solid state repair experience please seek out a local repair person to assist you in this repair.
Posted on Sep 24, 2006
  • 18 Answers
This would appear to be a bulb that has reached end of life -- or the projector thinks that it is because of hours. Usually most bulbs are 1000 or 2000 hours. Depending on your projector there are different ways of checking bulb life hours -- if you Google your projector model number and "bulb life" you will usually get a post on how to check these hours. Also, if it is a new bulb and you haven't reset the hours counter, it may need to be reset (however you also don't want to wait too long before changing a bulb that has reached EOL since they can and do explode sometimes taking out the projector with it).
Posted on Jan 26, 2008
  • 75 Answers
SOURCE: TV only shows line across middle of screen.Still have audio.
Sounds like you have bad solder joints on the vertical ic which should be numbered IC501 on the board.also there are capastors that coud be going bad but i would look for bad solder joints on ic frist.
The capastors numbers on board are C502 / C516 also need to check R 483 which is a resistor.
resolder the ic if you know how to solder. That is a comon problem a lot of tvs out there have. The only thing is the tv has high voltage on it even if it is unpluged from the wall. Some of the capastors hold there voltage for a long time. Be sure and unplug tv before you try anything if you are going to do it yourself and stay away from the capastor in the AC line should be marked 200 V or moor.
Posted on Mar 12, 2009
  • 318 Answers
SOURCE: Sanyo 68cm. AV1 is Black and White. AV2 and normal Tv is OK
the two AV1 and AV2 have different inputs on the IC,
the first port has a disconnection,
take your tv for a check up
Posted on Apr 24, 2009
Insignia tv. After 10-15 minutes sound becomes distorted and volume goes to almost a whisper.
Check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
If audio output IC overheat, this type of fault can occur. Check the screwing firmness to this IC to its metal heatsink.
Sep 13, 2014 | Insignia Televison & Video
Monitor goes black - green light stays on
My screen is black, why do I not have a picture?
Answer Antenna is not hooked up to television.
  • Make sure that the antenna cable is correctly connected to the television. If it doesn't work there appears to be no signal.
Problem is caused by television broadcast
  1. Push 'INFO' button.
  2. If the screen shows channel number (1, 2, 3, etc) try another channel. Not all channels broadcast at all times.
  3. You may have a signal problem. Contact cable provider or local broadcaster regarding the specific channel.
Television is in EXT or SIDE mode, and there is no external source provided, so screen mute (black screen) is activated.
  1. Push NEXT SOURCE button on the remote.
  2. On the screen appears all sorces.
  3. Press the UP button to switch to the TV mode.
If you are using an accessory device (DVD, DVR, or VCR), be sure the device is on and running.
Blank screen when connecting to the accessory (DVD, STB, PC) device via HDMI to HDMI.
  • Make sure the cable is well connected .
  • To check which connection is selected, Press the i+ button on the remote control.
  1. When you see Blue mute / blank screen and the i+ display does not indicate any video resolution indication then there is no valid signal detected.
    • Make sure the HDMI output of the accessory is valid by changing the video output resolution to a resolution which the TV can handle.
  2. When you see a blank screen and the i+ display shows a video resolution indication then the connection is correct.
    • The blank screen is caused by the accessory device and not by the TV.
    • To detect and remedy the problem caused by the accessory device, check the instruction manual of this device.
  3. If the problem remains : reselect the HDMI external source input by changing to the other HDMI input and back to the connected HDMI :
    1. Press AV on the remote
    2. Press up and then ok
    3. Press AV again
    4. Press down and ok
    5. The compatibility check process between TV and accessory device will start over again.
  4. Reset (switch off and back on) the TV and also reset the accessory device.
Mar 05, 2008 | Philips 42PF9630A 42 in. Plasma Television
Issue with Samsung LE32B450. After the TV has been on for about 5 minutes, when you change channel the screen goes blank and the sound goes off. However, the TV is still on as pressing the power but
Just do a hard reset to this set and check. Unplug the TV from AC mains wall socket, and re-plug it back after 10 minutes or so. This must make it a hard reset.
Jan 12, 2013 | Samsung LE32B450 32 in. LCD TV
TV won't show cable input...
Turn OFF, Unplug everything from the WALL, wait a few mins, and replug all back in again. Now Re-setup it all again, Now the doing of this should Reset anything done to the TV.
R - Restore: Restore default settings E - Environment: Change your environment, remove from media cabinet, try different media, try different equipment (TV, router, hotspot, etc.). P - Power Cycle: Power cycle by unplugging your networking equipment from wall for 2 minutes to reset. A - Access this Knowledge Center for useful articles to resolve issues. I - Install the latest System Software Update. R - Resolved: In most cases these steps can resolve your issue.
If necessary, adjust the video input on the TV to match the input connector that is being used to connect to the system. Check that the cable is securely inserted. Try disconnecting the cable from the system or TV and then reconnecting it. There may be a problem with the AV cable in use. Try using another cable that is compatible with the PS3™ system. If the video output settings on the system do not match those of the cable or TV in use, there may be no picture. If the screen goes blank, turn off the system. Then, with only the system and the TV connected, touch the system’s power button for more than 5 seconds to turn the system back on. The video output settings will automatically be reset to the standard resolution. If the resolution of the video content is not supported by the TV in use, when the video is played the screen may go blank. If this happens, go to the screen for selecting the resolution in the system’s video output settings, and then select all the resolutions that are supported by the TV.
Apr 16, 2010 | Polaroid FLM-3201 Television
My Sylvania flat screen sound keeps going off
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. The most probable cause is with its audio output IC itself; overheats.
May 11, 2017 | Sylvania Televison & Video
Pressing reset doesn't go to zero. sweep second hand goes to 57 seconds
Pull out the crown and use either a combination or one of the cronograph buttons, this will allow you to adjust the hand positions
Nov 20, 2009 | Baume Et Mercier Baume & Mercier Hampton...
Curtis DVD 6500 Blank Screen
Sounds like you have accidentally gone into the scanning mode. Press and hold the subtitles button for 5 seconds to get out of this.
Apr 03, 2008 | Curtis Televison & Video
Oven stopped 5 to 10 minutes after pressing START
sounds like a wiring problem check your power source
Nov 29, 2007 | Whirlpool RF262LXS Kitchen Range
Screens works for 5 mins then goes blank!!!!!
It could also be that the video card is not compatible with this monitor. After the pc boots up, can you get into windows? Does the monitor always go out at a specific time on boot? Say for example; you boot the pc, windows startup splash screen comes on; screen does a quick flash and goes blank. Then it maybe the BIOS setting for the video. Try changing the IRQ setting. You could also try putting the video card in another slot. Do you have the manual for the motherboard? Ray
Jun 20, 2007 | Relisys TL565 15" LCD Monitor
Sanyo PLC XU32 Multimedia Projector Logo
Top Sanyo Office Equipment & Supplies Experts
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
