Question about Microsoft Xbox Console
No picture my xbox has power but when pluged in to tv i have no picture.do i need a new scart lead
Maybee....but guessing you havnt tryed to mod it in any way and not having opened the box or played with it in the bath ..yes but id check the connections for green oxidization but in most cases it would be the plug end (yellow) thats if you can hear sound if there is no sound as well as picture I would be checking the plug ends for a resolder job.If they look all intact id be suspect to looking deeper into the box for a fan failure,hard drive faliure, power supply or verry dusty Id clean and inspect the inside by blowing out the dust with compressed air being carefull not to lift any tracks but this would be a resort only after id have borrowed and tested another av leed,you can pick up an av leed from cash converters for about $2 or drop it into your local mod shop for a free quote and test
Posted on Oct 12, 2008
When xbox is pluged in you can hear the sound but no picture is showing
Try jiggling/ twisting around the yellow av cord lead. I have the same problem with mine but you just need to spin the yellow av lead around untill you get a picture. If you still cannot see the xbox screen then i recomend you try on another T.V as it might be the av imput is not working. =]
Nov 07, 2010 | Microsoft Xbox 360 Console
Cant tune tv in to use xbox 360
Check the scart lead by substitution, try another source of input, (game machine or dvd player,) it,s not uncommon to find bad solder joints on the print, where the scart socket is soldered to the mother board of the telly. there is no tuning as such for scart sockets, but you can get them in the wrong mode? S-video etc? but you should, in that case, get some sort of picture. Good luck! Nick
Mar 23, 2010 | Televison & Video
I HAVE NO PICTURE WHEN I TURN ON XBOX I HEAR SOUND I GET LINES ON TV
sounds like a scrat connection problem.
try using a new scart lead (not R,Y,W lead)
could also be tv scrat connection.
Nov 17, 2009 | Video Game Consoles & Games
HAS SOUND BUT NO PICTURE, IT IS NOT THE TV CAUSE THEY ARE PRETTY NEW. ALSO HOOKED UP A PLAYSTATION AND IT WORKED.
I had a similar problem. Don't worry, it's probably something really simple.
1) First check you component HD AV cable:
Is it properly plugged into the back of the XBOX? Push it in with a bit of force until it snaps into place
2) Check the Red, White and Yellow leads. Are they going to the right connections?
3) If you are using the Scart connection or a connecting your XBOX to your TV via a DVD player check all the Scart connections to see if they haven't come loose and if they have, push them firmly back in.
One of those is likely to be the problem.
Oct 05, 2009 | Microsoft Xbox 360 Console
Where do i plug the different leads in the back of my tv i havn,t got a yellow port for the yellow connecter
What sort of tv do you have, is it new? If its new it may well have an Hdmi connection which gives you the sweetest graphics....
If your tv is older you probs have a scart connection, the yellow lead carries the video signal, some tv's have three little socket that the red yellow and white leads plug into if you cant find anywhere to plug it in you will need one of these , a scart adaptor
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=120439215212&category=11319&refid=store
(thats just an example of what one looks like, you can buy them all over)
THe red white and yellow cables plug into the scart adaptor which usually plugs in the back of your tv, done
Jul 29, 2009 | Microsoft Xbox 360 Console
My xbox wont show on my tv,cant hear sound but no
It's possible that your Xbox is sending out a picture that's higher resolution than your TV can display. Try reducing the resolution of the Xbox video output.
May 12, 2009 | Microsoft Xbox 360 Elite Console - Black
XBOX 360 NO PICTURE
if using hd tv then use the cable with the blue lead, if not using hd tv then use the red, white and yellow leads. If using the scart connection to put the leads into make sure that you have it set to the correct av or ext channel
Dec 28, 2008 | Video Game Consoles & Games
I am Unable to connect my Aduio cables from the xbox 360 to my TV
1) Connect the red, white & yellow audio leads in to the 360 scart adapter and then plug this in to the scart socket on the tv
2) change the xbox 360 selector at the back of the console from HD to TV
2) Select the input of scart on the tv
You should now get pictures & sound.
Dec 28, 2008 | Televison & Video
Xbox/TV
Try using a scart switch, therefore you only have to use a basic scart lead from the TV to the switch. then plug your xbox scart into the switch and it should work
Nov 03, 2008 | Televison & Video
Audio but no video when i turn xbox 360 on
hi MC, power off unit unplug av cable from back of xbox.. then power up unit.. after a couple minutes the xbox will shut down.. plug the av cable back in and power up.. Good Luck
Jun 30, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox Console Logo
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Mike Neath
Mike Neath
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
