Question about Nikon CoolScan V ED Film Scanner
Edge Of Scan Overexposed
Using the the SA21 film strip adaptor on the Nikon CoolScan V ED I am finding that the right hand side (trailing side) of the scan is overexposed (brown dis-colouraton).  It is a fairly low level on the first 3 slides on a strip of four but on the last slide is pretty strong.  It probably only covers a couple of milliimetres of the slide.
Has anyone else seen this and is there anything I can do about it?
DD
  • downinoz Oct 05, 2008
    Thanks for the information. I thought originally it was getting light from an external source but it became evident this was not in fact the case. It has actually been doing this since I bought the machine. This seems to be a very plausible explanation.
    downinoz
  • Nikon Master
  • 19,396 Answers
If the slides are ok , and not overexposed themself, brown discoloration on the side means a problem with the scanner lamp.
Posted on Oct 05, 2008
  • Ginko
    Ginko Oct 05, 2008
    Dirt on the mirror, on the lamp, or or on the glass screen can cause this problem. Check if you can see any dark area on the bulb ( the lamp must be off), if you see any , replace the lamp. If glass or mirror are dirty, then you will need to take apart the scanner and clean it from the inside.
    Also, if the brigh side is at the end side or at the begiining side of the
    slide, parallel to the direction were the lamp moves, then the problem
    is with the mirror or with the lamp traction.
    It the overexposed area is in a side perpendicular to canner lamp
    motion, then the problem is with the lamp slightly out of place or with
    the mirror
  • Ginko
    Ginko Oct 05, 2008
    Generally, dirt can cause overexposion, only if you scan from negative into pictures.
    If you scan slides, and not negatives, bright area on the scan means that there is a problem with the lamp or with the mirror.
    If the phenomenon is only on few slides, and occurs always with same slide positions on the loader tray, then it can be related to the position of the slide in the tray. If the slide is not orthogonal to the lamp r light beam and to the mirror, then you can get brighter areas on the scanned picture.
Nikon coolscan 5000ed, film stuck, will not eject
If you switch off the scanner you should then be able to remove the grey film holder, even though the film strip will still be inside. Then, press the small button above the film entry slit to open the front of the holder. Pull up the top cover, ease the bright metal holder strip forward then lift the metal flap that holds down the film strip. At this point you should be able to remove the film strip. Re=assemble and try again.
Good luck.
May 18, 2014 | Nikon CoolScan V ED Film Scanner
Nikon Coolscan 5000 ED not scanning
Have you tried resetting the scanner itself?
Jul 09, 2008 | Nikon COOLSCAN 5000 ED Film Scanner
Tip
Nikon Coolscan V ED Jam Solution Do you find your older slides, cardboard...
Do you find your older slides, cardboard slides, or irregular slides jam in the Nikon SF-210 Slide Feeder for your Nikon CoolScan V ED?
Try this solution:
Take a AAA battery and place it in rear, left side of the slide feeding tray as pictured below:
The slides will fan out nicely, and your Nikon CoolScan V ED will no longer try to load more than one at a time. Instead it will load them one at a time, 50 per tray, and you can actually walk away from it and let it do its job, just the way you intended to when you bought the SF-210 slide feeder attachment!
I hope that helps.
on Apr 09, 2010 | Nikon CoolScan V ED Film Scanner
Nikon Super Coolscan 5000 ED
The scanner is only 24mm wide and 36 mm long, so rotate you slide by 90 degs.
May 03, 2010 | Nikon Super Coolscan 5000 ED Film Scanner
Nikon cool scan 8000 How to load 2 1/4 by 2 1/4 negs on this tray
There is a lock on the oper side. release the lock and the other side also opens like a door
Apr 01, 2009 | Nikon Super Coolscan 8000 ED Film Scanner
Need driver for Nikon super coolscan LS 5000 ED
Go to Nikon's official website, then search for support. You'll be able to download all the drivers and Nikon Scan software. Hope this helps.
Jan 15, 2009 | Nikon Super Coolscan 5000 ED Film Scanner
Launch Nikon Coolscan, but browser/scanner window doesn't open
I think the scanner may have got confused and be expecting another adaptor to be connected. If you slot in the single slide adaptor, wait until all the scan functions become active on-screen, then remove that and insert the SF-210, you might find it works OK.
Jeff Underwood 1scan.co.uk
Nov 16, 2008 | Nikon COOLSCAN 5000 ED Film Scanner
Wrong alignment in batch scan
Try scanning these strips with the FH-3 accessory. It may be the negatives aren't being sensed correctly at the frame boundary. This unit overcomes this problem and can often be found at a reasonable price on eBay.
Jeff Underwood 1Scan.co.uk
Jul 21, 2008 | Nikon COOLSCAN 5000 ED Film Scanner
NIKON SCAN IV ED
connect after PC start up
May 29, 2008 | Nikon Coolscan IV ED Film Scanner
Nikon CoolScan V ED Film Scanner Logo
184 people viewed this question
Top Nikon Office Equipment & Supplies Experts
Doberman
Jerry Greenberg
Jerry Greenberg
Tanvi Thakur
Are you a Nikon Office Equipment and Supply Expert? Answer questions, earn points and help others
