It sounds like the display kit AP4929088 is bad and will need to be replaced. It will cause the problems you are having with the unit. Hope this helps. If you have purchased in last year, it may still be under warranty
Hello Walter Buford - Try resetting the range by either unplugging it or flipping the household circuit breaker off. Wait approximately 30 seconds and turn on the unit. Select the self-clean option or bake/broil option. If it does not turn on, then the temperature may have tripped the internal sensor of the unit and needs to be reset. This usually has to be done by a professional since the back panel needs to be taken off and the power reset inside. Possibly the unit may have a communication problem with the EOC (Electronic Oven Control) or faulty element(s). Personally, I would recommend contacting a professional for further evaluation.
