Do you mean the Bernina Activa 145? If so, you can press and hold the Reverse button. The button is to the right of the needle bar; it's to the left and below the needle stop Up/Down button. The button is indicated with a raised U with an arrow at the top of the right side of the U. Note: this "quick reverse" will only work if the stitch length is <= 3mm. If you want to sew in reverse without holding the Reverse button, quickly press the button twice. Press the Reverse button once more to sew forward.
Not sure that statement is always true, but:
o Turboprops are generally less expensive, which means that they have a wider market of potential buyers. Look at aircraft like King Airs and TBM and Pilatus - all used as corporate aircraft, but also often owner flown and within the reach of the non-corporate buyer.
o Turboprops are typically much less expensive to operate. The fuel burn is much MUCH less. The insurance is much less, and that insurance usually does not require a two-person flight crew.
Basically, pure jets (Citations and on up) usually go faster, go higher (out of weather), and cost more to own and operate.
transmits pourly can i have that repaired
Holt, Searched this quite a bit, it looks like the transmitter is none adjustable.Check the attached Bendix link and use there support or contact page, they also have a trade up page,,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info." Home BendixKing by Honeywell
