Question about Lexmark X5470 All-In-One InkJet Printer
Cannot send a fax
Paper won't scan so the fax can be sent.
Is there an error message on the computer screen or on the printer LCD? what is it?
Posted on Oct 10, 2008
Lexmark X4270 won't send out a fax
If you have DSL. you need a filter on the line you are trying to fax through.
Mar 24, 2012 | Lexmark X4270 All-In-One InkJet Printer
MFC-490cw Color Inkjet Multi-Function Printer: how to send a fax...
Most of these will send a fax without even using the PC. Just connect a phone line, place the document in the proper position, usuallu print side up on newer models, and push the fax button, it should prompt you for the number. Once dialed,, the paper will feed into the scanner portion of the multi, and you will see it on the menu bar saying sending page 1, 2 etc, after if is done sending, it will dial and connect, yu should hear the typical noise a fax makes. then it will say fax sent or end or something similar, that's it, try sending one to a friend to make sure it's working. Now some simpler machines require you to open the scanner portion and lay the paper down in the glass manually, mine does it both ways. In that case just skip the feeding part, and dial wait for it to scan and send.
May 16, 2010 | Brother MFC 490cw Color Inkjet...
Thick line when sending a fax
Open the document feeder, there should be a narrow, long scan glass underneath. Clean that glass. Sometimes whiteout (liquid paper) or other foriegn matter will stick to the scan glass causing a "shadow" (line) on faxes being sent out. Hope this helps.
Aug 24, 2009 | Brother Office Equipment & Supplies
Sent documents are received black
I bet if you make a copy for yourself, the same thing is true.
The scanner bulb (or led array) is dead - meaning there is no light coming on when you scan your originals to send a fax or copy. You would normally be able to see the light(s) light up, if you peek under the auto sheet feeder as your originals are scanning, if not, then it is dead.
Jul 16, 2009 | Sharp UX 340LM Plain Paper Thermal...
Distorted copy quality in the sent faxes
Make sure the rollers that pull the paper through are clean and that the glass is also clean. Clean the rollers with a cloth dampened with alcohol.
Apr 20, 2009 | HP LaserJet 3050 All-In-One Printer
Can't send or receive fax
Your product must be accidently set to copy mode instead of fax mode and when it is, it actually expects a document to be loaded in the tray to "scan/copy" so change to fax mode again and try to sent the document. This should fix your problem.
If you do want to make a copy, make sure a doc. is loaded and press start copy to do so.
Jan 06, 2009 | Canon FAX L-120 Plain Paper Laser
Faxing
you can see job confirmations under job list, there you see, whats ok and whats not. also paper format you can choose under fax sending screen, before sending fax. probably you caan choose a default page format from utility - user/ admin settings
Apr 17, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Document sent is blank for recipient
Hi there check the machine scanner light by putting the original in the feeder and doing a copy. If the printout comes out OK then it either could be the other fax machine you are trying to send it to or you have a intermittent fault with your scanning lamp (Section).
You also must make sure that the original is text face down.
Hope this helps you
Thanks J
Jan 08, 2008 | Panasonic KX-FP121 Plain Paper Thermal Fax
Faxes sent are too light to read
respected sir the camera or scanning unit of your machine is dusty only clean it from any technical person
Sep 19, 2007 | Brother IntelliFAX 885MC Plain Paper...
Lexmark X5470 All-In-One InkJet Printer Logo
18 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
