Question about Bosch Classixx WFO 2466 Front Load Washer
The rinse is flashing and cannot get the start button to operate
This is not even twelve months old and did not receive user guide with machine
I had this problem, Un plug machine, I took the filter cover off (flap/door at bottom right of machine, then undo the round filter cover,turn anti clockwise) impeller was jammed (2 nails out of someones pocket!) freed impeller (should turn with finger) once free,put cover back on and away it went!. Hope this might help. John.
Posted on Nov 10, 2008
Fisher & Paykel WL80T65CW1 - Washing machine keeps saying unbalanced.
Yes the shop you bought it from. At only 12 months old the warranty should still apply.
Nov 03, 2017 | Fisher and Paykel Aquasmart wl80t65c
Hoover hed6612 1 80 salt level light remains on all the time even after correct salt is added. machine is just a few months old no problems untill recently. please help : mike.....
Ascertain from the devices manual user guide on the espectation once in operationalities. For example, devices may remain on once powered on until were unplugged from power outsource unless were malfunctioning. Also ascertain from the devices user guide from where customer support is attainable.
Apr 14, 2011 | Dishwashers
Hi, I have a W526 Novotronic Miele
rinse light flashing is an indication the is a problem within the motor circuit. Brushes,motor or electronic.
Dec 24, 2010 | Miele Novotronic Premier 500 Front Load...
Ge front load washer won't go into rinse cycle.
Check the cold water hose. My brand new machine had this behavior until I discovered a kink in the cold water hose - works great now.
Jun 03, 2009 | GE WSXH208A Front Load Washer
BEKO DE 2431 FW - fails to start
Dear LizzyL,
If your machine is only 5 months old it is still in warranty and you should go back to the shop you purchased it from and get them to send in a Service Engineer. It is not fit for purpose.
May 17, 2008 | Dishwashers
Wf000
whare the option buttons are if you number them 1 to 5 from top to bottom if led 2 and 4 are flaching this is a time out draining and you will need to check your waste hose for twists traps and kinks also check Filter if there is a user servicable one on the applionce and check plumbing. This is a comman fault and if you get hotpoint out to it even if it is only a day old they will charge for the call out as it is classed as user error or faulty instalation this works on all WF,WD & WT modles with 5 option buttons on the left habnd side the applionces with digital displays will show F-05 insted but it all means the same
Jan 21, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius wf 541
Check your drain pipe behind. This is supposed to be approx 3 feet above ground level; then the hose goes into the stand-pipe without being too tight. If this does not work, click "thanks for trying"; your prob will be back for someone else to solve.
Jan 14, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Aeg 76669 oko lavamat machine not starting all six lights [pre wash, main wash, rinse, rinse , spin, and end] flashing machine three years old just successfully completed wash cycle, loaded up for next...
I have had the same problem. If you switch the machine to off and then to cotton/linen 95, then press at the same time prewash, soaking, qick wash and stain buttons for 10 seconds switch it off. When I switched it on it worked.
Jan 10, 2008 | AEG Washing Machines
Bosch Classixx WFO 2466 Front Load Washer Logo
79 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
