Question about Porter Cable 3" x 21" Electronic Variable Speed Sander
Burt out sander.
My sander overheated and stopped working. I cleaned it up and found it to be clogged with sawdust which led to overheating the motor. When this happens what generally needs replacement. There are plenty of parts for the 352vs, just need some guidance. Thanks!
    New Friend:
  • 55 Answers
I would start with the carbon brushes they are easy to replace and you should be able to pick them up at any lowes or home depot
Posted on Dec 04, 2008
Dewalt dw625e intermittent power fault
Some power tools have a thermal reset switch built in. It sounds as if the thermal overload is faulty, or the unit has overheated. Check to insure the cooling ports of the motor are not clogged with sawdust.
Oct 18, 2014 | Dewalt Tools & Hardware - Others
Delta unisaw stops running
Probable overheating problem. Take it apart clean it and put it back together. Sawdust still can get into the machine and becomes an insulator which in this case keeps the heat in. Take caution cleaning around the electrical areas. I suggest using rubbing alcohol in combination with que-tips for electrical parts. If it is just overheating and there has been no lasting damage caused this should fix the problem. There probably has not been any lasting damage caused by this issue if you have never smelt anything burning but for extra reassurance when you open it look at the sawdust before cleaning for burnt marks.
Mar 25, 2014 | Delta Saws
Ryobi BE318-2 dust bag don't work
The pathway that the dust follows to reach the bag is most likely clogged. Take the bag off and look inside to see if there's sawdust plugging the orifice. If there is then you could vacuum out the dust or simply start up the sander and let the machine clear itself. If you do the latter just know that you will create a cloud of dust so do it in the proper environment.
Jan 03, 2014 | Ryobi BE318-2 3 X 18 BELT SANDER
My Electric saw works intermittently
Could be it's overheating. Clean out all sawdust from the vents on th e motor body, and wherever else you find sawdust. Check that you're using a sharp blade. Check all wiring connections are secure. You maay need to remove the cover behind the on off switch to check thatb all the push on connectors are pushed on tight.
Jan 21, 2013 | Makita 7 1/4" Circular Saw 5007NB
Oscillating drum sander runs a few minutes and stops
This usually occurs if the motor is overheating and the internal circuit breaker is tripping. After it cools down, it self resets. This can be caused by bad bearings or parts dragging the motor down, making it work hard enough to over heat and trip the breaker. If you are running it on an extension cord or circuit that isn't able to provide it with the amps it needs the motor will overheat and trip the breaker also.
Dec 02, 2012 | Delta 17-960 Oscillating Spindle Sander...
Sawdust is not going into the dust bag, could the sander be clogged?
that would be my first guess, also look for pieces of sanding belt that might have clogged the passageway
Sep 11, 2011 | Black & Decker 3 x 21 In. Dragster Belt...
The sawdust is not going to the bag. I've completely blown my sander with air and tried to unclog anything without taking the sander apart, but still all sawdust stays on the belt and not going up the...
The dust bags on most sanders are only marginally effective. They work OK on random orbit sanders with the holes in the sanding pad, but are next to useless on belt sanders. You might try attaching a vacuum cleaner hose instead of the bag. On the other hand, if the the belt is clogging up, that's not going to be helped by attaching a vacuum hose. The belt is "loading" up probably because the material you are sanding is damp, or maybe you are sanding paint, which tends to melt then stick to the belt. If you are just trying to keep the belt from clogging (or unclogging it), rather than keeping the dust contained, try running the belt against a wire brush after every couple of minutes. Good luck, Al K
May 03, 2011 | Black & Decker 3 x 21 In. Dragster Belt...
Stopped working might have overheated it does nothing now
have you checked the fuse first.
possibly worn brushes on the motor, remove the brushes and check the length of them , also look to see if they are pitted or burned.
Jul 18, 2009 | Dewalt 3" X 21" Belt Sander
Porter Cable 7800 Drywall Sander- Head overheating/motor laboring
the drive shaft is probably going bad. If all the greese is gone then it will cause it to heat up. you can find parts and diagrams to fix it at www.deltaportercable.com. search for modle number 7800 under the parts section.
Mar 08, 2009 | Black & Decker Black Decker/ Porter Cable...
Porter Cable 3" x 21" Electronic Variable Speed Sander Logo
256 people viewed this question
Top Porter Cable Tools & Hardware - Others Experts
John Trevino
T bone 1963
Are you a Porter Cable Tool and Hardware - Other Expert? Answer questions, earn points and help others
