Either with an Ethernet cable from your home internet router to the TV, or wirelessly. The 4200 series require an optional wireless dongle (PTA127) to enable wireless functionality.
You can use a 3rd party wireless or Ethernet over Power devices (Homeplugs) to bring an internet connection to the TV that can then be connected to the TV's Ethernet port.
In this guide I will go over the steps you need to take in order to connect your Ps3 to the internet either wired or wireless.
Wireless Connection -Your home router should be configured for wireless and you should know your wireless routers security information. Make sure an Ethernet cable is not connected to the PS3. -Turn on your console and select Network Settings under the Settings option in the main menu. -Select the "Internet Connection Settings" tab and then select Yes when prompted. -For the installation type select "Easy" -Select "Wireless" when prompted for your connection type. -Select "Scan". Your system will scan and show all available wireless access points within range. -Select your home access point from the list. -Select your security settings and enter your encryption key. Save your settings Make sure to select Test Connection to make sure the connection is working properly. <iframe src="http://rcm.amazon.com/e/cm?t=boobsbeerandg-20&o=1&p=12&l=ur1&category=videogames&banner=1P92M72BVQ4PVPEF0E02&f=ifr" width="300" height="250" scrolling="no" border="0" marginwidth="0" style="border:none;" frameborder="0"></iframe>
Wired Connection
You will have the same steps as a wireless connection, except once you select "Easy", you will be prompted for your wired connection settings. Normally, in a home environment, you are using DCHP and the IP address as well as DNS information is all obtained automatically from your router.
Be sure to select Test Connection afterwards
Ok. You should now be connected to the internet. Enjoy!
Your question is not so clear. For giving the proper solution I need to know something. As per my knowledge
a fiber optic cable doesn't connect a router directly without a Media
Converter. Secondly please tell me the model number and the brand name of your
television. Third do you configure your internet connection on your television
through IP address??
It is likely that the problem is your AV cable. This cable has one plug that connects to your Playstation 3 and a red plug, a white plug, and a yellow plug that connects to your television.
Follow these steps to get your PS3 up and running again
Unplug your AV cable from your PS3 and T.V.
Plug in your AV cable to your PS3 and T.V.
When plugging your AV cable back into the T.V. make sure that the red plug is in the red socket, the yellow plug is in the yellow socket and the white plug is in the white socket.
If problems persist try using a different AV cable.
It sounds to me like there is a noteable delay due to a combination of things: your Bluetooth wireless controler (primary reason), and the cable connection from your PS3 to your TV. Now, to determine what the problem is specifically, you'll need to check a few things:
1. Make sure your PS3 is updated to the latest software
2. Check to make sure your cable connections from your PS3 to your TV are firmly in place. I personally have noticed that I got delayed reactions when my HDMI cable was not firmly secured to my HD TV. Weird, but as soon as I unplugged and re-plugged in the cable at both the TV end and the PS3 end, it cleared things up for me. If that does NOT work (btw, this can also be the case if you use a composite or component set up too).
3. Check to make sure that your PS3 controller is fully charged. Controllers that are partially charged occasionally do demonstrate really weird results, like the delay you're talking about. So, make sure that your PS3 controller is fully charged.
4. If the controller is fully charged AND your PS3 to TV cable is plugged in properly, then try to plug the USB cable to connect your PS3 controller to your PS3. Sometimes, for reasons I don't know about yet, this could solve the delay problem.
It's a semi-long process. Do you have a wireless router hooked up to your computer? If so just go to settings then network settings in your ps3 menu. If you have the wireless router then put wireless connection and its straight forward from there. If it is a wired connection and hooked to your ps3 than put wired connection and again its straight forward from there.
you can set your playstation 3 online by two ways, 1- by a wired connection, and 2- Wireless,
1-Wired Connection: Plug an ethernet cable from your highspeed modem to the back ethernet input on your ps3 system, and follow on your ps3: Network Connection > Internet Connection Settings > Easy > Wired Connection. and follow steps
2- Wireless Connection: You must have a Router connecting ethernet cable from your intenet modem to the router, and follow on your ps3: Network Connection > Internet Connection Settings > Easy > Wireless Connection and follow steps,
hope this helped you on setting up your ps3 connection :)
you could try getting a wifi adapter and creating an access point, you can connect that way if your ps3 has wifi I have a laptop with windows XP Pro and have been trying that my desktop PC with Vista Home can see it. MY Components: -Desktop PC with Vista Home (Main PC, connected to Internet with Ethernet to a Linksys Wireless Router B and G). -Get internet thru cable TV (broadband),from this cable modem plugs to router and from router to PC Vista(desktop) -Linksys Wireless G/B Router -G-Card for my Laptop Windows XP Pro and -Playstation 3 capable of sharing info and use printer
At the moment all of them have internet w different IP's (000.000.0.001, 000.000.0.002,etc.). What I want to achieve is that I can use the Printer that is connected via USB to my PC Vista (desktop) and share files. Right now the only thing been able to do is that my PC Vista see my Laptop but Can't find my PC on my laptop. Anybody, Help? -When I turn On my media sharing in my PS3, my internet on Laptop loses it while PS3 search and find,then, because laptop lost wireless,the PS3 looses the laptop and I get wireless back. I knowis a stupid setting but tired of workin back n forth. Thanks
