Question about HP Compaq nx6110 Notebook
Booting Failure When i turn on my computer, the cooling fan starts but no video on the display. help me please!
    Scholar:
  • 107 Answers
Try removing the HD, then boot. If this doesnt work, then try the RAM, wireless card, and any other device. If this doesnt work, then it is something to do with the motherboard or LCD monitor.
Hook the lapto up to a VGA monitor. If it shows video then your LCD screen is toast, or one of the connections. If no video comes out at all, then your mobo is probably gone and you need to replace it.
Posted on Jul 24, 2009
  • Aaron Fox
    Aaron Fox Jul 24, 2009
    Note: I also know that hp has done a recall with laptops that are having video problems, you might want to check to see if yours falls under this repair/recall.
Computer will start up but screen will stay blank
do you get a 'NO Signal' display on monitor, or anything when booting?
if not check to see if you can see lights on inside the frame? if not, do you hear fan spinning or beeping? sometimes the fan on the heat sink over the processor will stop spinning. the chip needs cooling so if fan won't spin an error will not let pc boot up to save it from getting too hot.
if you can take frame off and find the processor chip on motherboard to see if it is spinning. if not that would stop it from booting. if it is spinning then it is something else like the graphics card failure.
Dec 17, 2012 | Gateway One ZX4800-07 20 inch All in One...
I have a Fujitsu Lifebook LBS6120 notebook
Turn on as you did before and leave on for 10 minutes. Then, try turning OFF the computer by keeoing the POWER button pressed for 7 secons. If the computer goes off, then your screen is fried and the computer is actually booting up normally... you just can't see it ;)
Mar 17, 2010 | Fujitsu LifeBook E8010 Notebook
Proliant ML370T02 boot problem
Sounds like the CPU fan has gone bad and needs to be replaced
Sep 24, 2009 | Compaq (173907001) for ProLiant DL380 /...
Not properly booting,and no display
your ram have moved remove it and place it again it works
Jul 27, 2009 | Intel AAVID Pentium III Dual Cooling Fan -...
Dell Inspiron 9400 display goes blank after a few minutes
If the issue occurs in the safe mode, then I'm suspecting a failure of the LCD backlight. (It warms up and quits) Also see if video stays on using an external monitor. If it does, then the LCD is most likely failing.
If video goes out on an external monitor as well, then the Video card is failing due to overheating. Make sure all vents are free of dust (Clean with canned compressed air) and the all fans are functional (Run the fan test in diagnostics) If fans check up, then video card is failure point. If fans fail diags, replace affected fan 1st
May 21, 2009 | Dell Inspiron 9400 Notebook
Laptop getting unusually hot in operation
Re: "the FAN runs only when the booting is being done.but it stops as soon as the booting is completed".
That would be normal, as the variable speed fan comes on only when the computer is under load.
What is not normal is that the fan is not coming on when the computer overheats.Or that the fan is not cooling enough when computer is overheating.
Monitor computer temperature using a software, check if Fan is coming up when temperature gets critical.
If fan comes up but does not cool enough, then replace the fan, it is not efficient anymore because of a bad bearing or dust. ~Also ensure that fan is well mounted, if fan has poor contact with CPU surface , cooling will be poor.
If fan does not come up, and critical temp is not detected, then the sensor on motherboard is bad, this is very uncommon.
If fan does not come up and temp is critical, then fan is faulty, replace it.
There are also more than one fan on many laptops, check that one of the fans (CPU fan, video fan) is not completely ded, and therefore cause for the problem.
Here is the software to control your fan and temp state:
Download SpeedFan - Access temperature sensor in your computer
Download SpeedFan 4.38
SpeedFan - Free software download
May 05, 2009 | Acer Computers & Internet
My Laptop is not working
If your computer no boot, respond to a motherboard failure, (video, memory, hard drive) - Try to boot with a boot CD and see what happen.
Sep 24, 2008 | Acer Aspire 1800 Notebook
Pavilion DV 9005 issue
Please Reviewe all connections care fully. Its Very sensitive issue. If you do not find any open connection. Once again fit the fan with all connections. No display is nothing with Display do not touch that area. See only cooling Fan.
Best Regards
Rafique
Mar 15, 2008 | HP Pavilion dv9005us Notebook
Blue screen display
Check the memory of your computer. this could cause blue screen display. Be sure to check also the cooling fan for microprocessor and video card cooling fan if it is working. Sometimes it cause blue screen and needs to re-start your computer. If you have two slot of mem that is occupied then, you can remove one and leave the other one. Be sure to power off your computer before doing this. Then turn on your computer and try to observe it. If the problem still exist then do the same with the other memory and check it again. I hope that these could help your problem.
Aug 25, 2007 | Microsoft Broadband Networking MN-520...
HP Compaq nx6110 Notebook Logo
127 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
