V27DMCX-ZE 27 inch Evesham LCD TV. Bought Feb 2006. The Power light does not come on . I have changed the fuse in the plug. but it still does not work.
  • bishandi Oct 06, 2008
    Is it worth paying to have is fixed or shouldI just get rid of it.
    I will try to get someone to help me do as you say and will get back to you
    Guru:
  • 1,894 Answers
When you dont have proper expertise it is best to pay them and get it fixed.
this is a good unit
dont junk it so soon. you can get lots out of this wonderful unit
thank you
Posted on Oct 06, 2008
    President:
  • 2,712 Answers
1. Try this - hold the menu button down for 10 seconds. TV should power up; you will have to turn off front panel buttons on menu.
2. You can also try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and re-plug to AC power and redo the cabling. Switch on the TV and see if it works..
3. Powering down the set or putting it in standby may have allowed the power supply to cool. Weak capacitors often go out of spec when they cool, thus preventing a section of the power supply from firing up properly again. There is a simple trick...just warm the back of the TV with a hair dryer for 5-7 mins after you have unplugged the TV. Look for the little areas of holes in the back panel of TV. Use these as your guide at where to use the hairdryer, but don't hold the dryer too close (say 5-6inches away). (Make sure the dryer is on High heat). If the TV doesn't turn on after you have heated it up (like it tries to come on but then turns off) you need to unplug the TV again, this resets it. And repeat those steps till it works. Resetting the TV after it fails to turn on is the key. Also, just leave the TV on. Don't turn in off. Since it is LCD, it doesn't take much power...only a few bucks extra a month for your utility bill.
4. A circuit board may crack about some of the larger components mounted on it. You can inspect the PCB's for fractures, and then repair them. It may also be poor soldering that has failed. I would be checking for these things first.. If are unsure how to do this, try to get a friend who knows this kinda stuff to do it for you, or get a qualified technician.
Warning: If you do not have a background in electronics repair, or are inexperienced, get a qualified technician to do it for you.
REMEMBER there are very dangerous voltages inside a TV that can KILL. Be sure to work SAFE when dealing with electricity. DISCONNECT THE POWER BEFORE YOU DO ANYTHING.
Should none of that work, then its best you take the TV for servicing. Ask around for prices, and if you feel the cost of repair is justified, get it done. If not, you'd probably be better off buying a new set.
Hope that helps!
    Sergeant:
    Champion:
  • 200 Answers
Hi
check whether power is coming in the socket.
If ok means then u have problem in the power circuit...
  • 13,433 Answers
There may be a fault in the power board, possibly a thermal fuse that would require a professional to replace it.
  • Ekse Oct 06, 2008
    27inc.. I personnally would atleast get a repair estimate. if your out of warranty, a local tv repair should help you with that also on the right side here. Is the repair service locator ->>>>>>>
    You might have to browse this page up or down to see it.
Tv wont turn on, changed .5 amp fuse but nothing, its a 47 inch tevion lcd tv
hello have you check the fuse inside the tv glass type it will be in the power supply
regards
shaun
Jun 14, 2010 | Televison & Video
I have a Samsung LE40M87BD which has stopped working
Sounds like the power supply has failed.
Apr 23, 2010 | Televison & Video
Dear, I have a Toschiba lcd-TV 42X3000PG. In the power-supply(V28A00036500) their are 2 diodes in short circuit and the main fuse is broken. The 2 diodes are marked with "GA78" ,but i can't find them in...
If it is in Bridge rectifire then replace with 1N4002 Diode and it available in the market.. If in auxilary section better use BA159 ... Replace the fuse with same Amps..
Jul 10, 2009 | Toshiba 50H81 50" Rear Projection...
27 in.lcd tv ilo power wont come on using remote, or set button?
lcd tv 27inch wide screen, mo. 1lo lct27ha36, no power, power lite stays red, if i hold power on lite just flickers. this type set has no on off pulling the wall plug is the only way to kill the power to the set.
Oct 01, 2008 | Televison & Video
My Panasonic ct30wx54 was bought in feb 2005. When I try to turn it on there is no power coming into the tv. The tv will not turn on. The tv and dvd player are plugged into the same power bar and there...
Are you trying to use the power button or the remote? I have the same TV and the IR seems to have stopped working, the front panel controls still work.
Aug 18, 2008 | Televison & Video
We bought a 20 inch 2006 tv second hand. There is a password on it that we have no way of knowing. How do we over-ride this? TV won't allow us to scroll to change pasword option It is password for...
Call the company, they usually have a back door route. We had a nice Viewsonic 42" LCD TV at work and they had us push something like vol + power to remove password, then we could put in a new password.
Apr 24, 2008 | Televison & Video
AKAI LCT2715
I replaced 19 filter caps in LV power supply.
There were pruffed up on top
Mar 11, 2008 | Televison & Video
Xenius 27" flat panel tv
i just got a brand new xenius flat tv on pay as you view 1 week old and watching it and it just switched it self off the power light is there but wen i switch it on the power button only flashes no picture then switches it self str8 to stand by again well not happy any 1 no wats wrong be sides its fooked lol
Feb 27, 2008 | Televison & Video
Televison & Video Logo
332 people viewed this question
Top Televison & Video Experts
Electro Med Services...
