Question about Bosch Dishwashers
My dishwasher SMS 448 works up to the point in the cycle when the dispenser is supposed to dislodge the Powerball detergent. It doesn't, and the machine stops. If I open the door and click the dispenser, the Powerball falls into the dishwasher unit itself. But when I close the door, the machine doesn't operate until I turn the knob a bit farther on in the cycle. Then, no water comes out, but the knob moves on in the cycle and the heating pipes heat up
Buffalo12980
  • 625 Answers
SOURCE: re: Maytag dishwasher
does the timer advance the control knob? check to see that nothing is in the way of the center spray tower. does it sound like any water is spraying around inside?
Posted on Sep 01, 2007
SOURCE: miele G575 Dishwasher
Watch also for how you load the upper rack. The flap opens inward and the rack has an opening to permit full opening. If this is blocked by your dishes, the flap won't open properly.
Posted on Dec 18, 2007
  • 351 Answers
SOURCE: soap door won't open during wash cycle
its either the dispenser or the timer/pcb.
Posted on Mar 02, 2008
It could be jammed with old and hardened dishwasher detergent which dries like cement, preventing the little door from opening up. Clean the soap dispenser area with warm water and a toothbrush, especially underneath the area where the cover springs open.
Posted on May 09, 2008
SOURCE: Dishwasher not pumping water
Hi, I have an ASKO 1606 and it stopped turning on. This happened after the sink drain got blocked. All that would happen when switched on was the sound of the pump trying to pump water out. I opened up the panel on the back and found the tray inside full of water. As I started scooping the water out I heard what sounded like a switch clicking on and off. I think there must be a safety float switch or something. Once the water in the tray was cleared everything worked fine again. No more hand washing dishes!! WOOHOO
Posted on Jul 29, 2009
I have a whirlpool gu2400 dishwasher. The spring loaded soap dispenser door does not open during the wash cycle to release the soap.
Whirlpool dishwashers use a wax motor or a solinoid to release the door at a specific time during the cycle. So for proper cleaning the soap cup is nessesary . The part isn't that expensive and fairly simple repair.
Dec 30, 2014 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher LG ld-2120wh has a F on the Auto switch, what does this mean
it means that is testing the washing cycle , It uses only what it needs to use of your powerball dishwashing detergent by testing the water . The F is displayed while it tests the water in the dishwasher to determine how much detergent it needs.
Apr 15, 2014 | Dishwashers
I have a fairly new Fisher and Paykel double drawer dishwasher. A problem has developed all of a sudden whereby the Finish powerball tablet does not completely dissolve during the cycle (top drawer only),...
The water temperature is not coming up to the required level. The heater might be failing. Will need a technician to fix unless you are very savvy with technical repairs. Have you tried using the detergent powder in the dispenser to find if results are different.
Feb 05, 2014 | Fisher Dishwashers
Dtergent dispencer does not open
Dispenser Lever
If the dispenser is broken and doesn't open or close properly the dispenser lever might need to be replaced.
Detergent Dispenser Cover
If the detergent dispenser cover is broken and the detergent dispenser doesn't work, the dispenser assembly should be replaced.
Wax Motor Actuator
If the dispenser will not release the detergent the actuator connected between the wax motor and the dispenser might be broken. Check the wax motor actuator and replace it if necessary.
Detergent Container
If the dishwasher dispenser doesn't work the detergent container may need to be replaced.
Dispenser Lid
If the dispenser is broken and doesn't open or close properly the dispenser lid may have to be replaced.
Detergent Dispenser
If the dishwasher dispenser doesn't work the problem is often related to the release mechanism. If the problem is with the dispenser itself, it may be easier to replace the entire dispenser.
Dispenser Door Spring
If the dispenser is broken and doesn't open during the wash cycle the dispenser door spring may have to be replaced.
Dispenser Latch
If the dispenser is broken and doesn't open or close properly the dispenser door latch may have to be replaced.
Dispenser Door Pin
If the dispenser is broken and doesn't open or close properly the dispenser door pin may have to be replaced.
Enter your model number to see parts for your dishwasher.
Dispenser Actuator
If the dispenser is broken and doesn't open or close properly the dispenser actuator may have to be replaced.
Dispenser
If the dispenser is broken and doesn't open or close properly the entire dispenser assembly may have to be replaced.
Wax Motor
There is an electrically powered device called a wax motor which opens the detergent dispenser. If the dispenser is broken and will not open to release the detergent, the wax motor might need to be replaced.
Bi-Metal
If the dishwasher dispenser doesn't work the bi-metal actuator might be burned out or defective. The bi-metal is a simple metal loop which acts as a latch for the dispenser door. As electricity is applied to the metal loop, the loop deforms and bends away from the latch, releasing it. If the bi-metal is burned out it won't deform or release the detergent door.
Dispenser Slide
If the dispenser is broken and doesn't open or close properly the dispenser slide may need to be replaced.
Dispenser Repair Kit
If the dispenser is broken this dispenser kit may need to be replaced.
Main Control Board
The main control board provides power to nearly every component of the dishwasher including the detergent dispenser. If the dispenser will not actuate the main control board might be defective. You should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
God bless you . see the photo attached.401f2962-5d22-48f3-89be-c1db11d8eabe.jpg
May 23, 2013 | Hotpoint-Ariston FDD914 24 in. Built-in...
Customercare
Generally what type of detergent you use depends on what is recommended for the dishwasher. I am not sure which model of fisher and paykel dishwasher you have. But my opinion is that dish drawer type dishwashers work better with normal Finish powder detergent. It is not designed for tablets. The size of the wash space is small and it works on the principle of short and quick wash cycles. So the powerball is an overkill. Now about the streaking, this could be linked to the powerball but also you need to check if the rinse aid is present in the dispenser and also that you have selected the appropriate meter level for it being dispensed. 0 means no rinse aid and 5 is too much.;
May 01, 2013 | Fisher and Paykel Dishwashers
Soap dispenser doesn't open during wash cycle
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Jul 23, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
Why does a lot of detergent remain in the soap dispenser after a washing cycle is complete
Was the dispenser cup wet when you added detergent?
Make sure the dispenser cup is dry before adding powdered detergent. If dispenser cup is wet, the detergent can clump.
Is the cycle incomplete?
If the previous cycle did not complete, the detergent can become caked in the dispenser cup if it is left sitting in the dishwasher.
Is the detergent old?
Older detergent exposed to air will clump and not dissolve well, which will cause the dispenser door to stick to the detergent. Replace detergent if necessary and store the detergent in a tightly closed container in a cool dry place.
Is the water temperature too low?
For best washing and drying results, water should be 120oF (49o C) as it enters the dishwasher.
Were items blocking the dispenser that kept it from opening?
Items blocking the detergent dispenser will keep it from opening. Make sure water action can reach the dispenser.
Detergent guidelines
  • Use automatic dishwashing detergent only.
  • Other detergents can produce excessive suds that can overflow out of the dishwasher and reduce washing performance.
  • Store tightly closed detergent in a cool, dry place.
  • Fresh automatic dishwasher detergent results in better cleaning.
  • Add detergents just before starting the cycle.
  • The amount of detergent to use depends on the hardness of your water and the type of detergent.
  • If you use too little, dishes won't be clean.
  • If you use too much in soft water, glassware will etch.
  • Suggested fill amounts are for standard powdered detergent. Amounts may vary if you use liquid or concentrated powdered detergent. Follow instructions on the package when using these detergents.
  • Water hardness can change over a period of time. Find out your water's hardness by asking your local water department, water softener company, or county extension agent.
Nov 25, 2010 | LG Washing Machines
Detergent Dispenser does not open
I had this problem - the dispenser only opens if there are small items in the rack in front which don't come up to the same height.
Jan 08, 2008 | AEG 23 in. Favorit 86070Vi Built-In...
Dishwashers Logo
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
