Question about Konica Minolta magicolor 2400 Laser Printer
Paper Jam caused by inkjet gloss photo paper!
Stupidity on my part. The laser cooked the paper so that it couldn't be removed in one piece. How can one get at the back behind the rollers to clear up. What is the best way to clean the rollers and with what. If cleaning is not practicable what is the procedure for changing the rollers?
  • 1,031 Answers
You can check the Konica Printer Knowledge base,at the link below select your product from the list it will take to faq page this explains in details the process on a .pdf and with a video, how to clear the basic fuser roller jam with a piece of card.etc
http://crm01.konicaminoltaeurope.com/openmind/technic/engineer/qmspubkb.nsf/start
and work your way through the links.
and your problem solved hope this helps pls do appreciate by rating as fixxyaa.thanks and godbless
Posted on Oct 05, 2008
I am positive there is no paper jam with my printer (Z2420) but message of paper jam still appears and it won't let me clear it.
Sometimes a very small piece of paper can still be in the printer paper path after clearing a jam especially if the paper tears while removing the jam. The piece of paper may be too small to notice. Try blowing out the paper area with compressed air. Other causes could be the thickness of paper you are trying to print on, ie photo paper, thicker bond paper. Make sure the print settings match the paper thickness. I have a Lexmark laser printer, and I will get feed problems if the settings are not set for the correct paper type.
I hope this helps.
Alex
Feb 10, 2015 | Lexmark Z2420 USB 2.0/ 802.11g Wireless...
Paper jam probleme
There is a chance that you have some bits of paper in the paper feed. This can cause the jam. Take the paper feed out and with a straw simply blow out and paper dust and pieces. Turn off machine first. There is something physical in the way causing this and not software related.
Jan 07, 2015 | Brother DCP-J315W Inkjet Multifunction...
When I hit print when the paper starts to feed the pushbar paper feed does so fast causing the paper to start slightly off caqusing a paper jam.. Is there anyway to adjust the feed
When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper.The rollers may be dirty or sticky and causes the paper tonot feed straight.
Try cleaning the rollers with methylated spirits.
Nov 03, 2011 | Canon Pixma iP2600 InkJet Photo Printer
Hello i have a canon mp250 printer and when i put paper in it i takes it at an angle and says paper jam what could the problem be and how can i fix it
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper. The rollers may be dirty or sticky and causes the paper tonot feed straight.
Jul 15, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Paper Jams if I use a high gloss Laser printer paper. Looks like an accordian before the fuser.
Good day Sir, If you are using high gloss laser printer paper I suggest load up to 25 sheets.
  • make sure the glossy or the printable side of paper faces you.
  • the paper is loaded against the right side of the paper support.
  • the paper guide rests against the left edge of the paper.
Note: photos require more drying time. Remove each photo as its exits, and allow it to dry to avoid smudging.
have a nice day, hope this will help you.
Jul 30, 2010 | Lexmark X500n Color Laser All-in-One...
My hp 3940 had a jam. I removed the paper now it
Hello there
i know you have cleared the jam but i would go back and really look closley at the paper path and the internals a small piece off of a paper can cause this to claim it has a jam also if you turn off the printer and use canned air to blow out the whole insides this will help too also clean offf any lenses with a eyeglass cleaner ok ?
best regards mike
Aug 06, 2009 | HP DeskJet 3940 InkJet Photo Printer
Paper Jam lite is on ( no paper jam )
give this a try
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
May 28, 2009 | Brother HL-2040 Laser Printer
Paper jam flashing rx 425 did me best no paper in jam cant p0rint nothing
alternative :
Apr 22, 2009 | Epson RX620 All-In-One InkJet Photo...
No paper fed
Brother printers dislike photo gloss paper, even if it is only 110gsm, they just don't seem to be able to feed it around the rollers. I suggest using a Matte paper, but no more than 140gsm
Jul 02, 2008 | Brother Multi-Function Center MFC-240C...
Printer Jam
Its probably stuck wrapped around the fuser.
It WAS glossy Laser paper and NOT glossy Inkjet paper wasn't it ??
Glossy Inkjet paper could cause a proplem like this, as inkjet paper just isnt made to stand the temperature of a fuser (the fuser cover reaches a temp of just under 180 Celcius) and it melts !!!
Dec 12, 2007 | Samsung CLP-510 Laser Printer
Konica Minolta magicolor 2400 Laser Printer Logo
55 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
