Question about Dell Inspiron 6000 Notebook
How do i use my built in wireless connection to connect to the internet,please.
Hi
I have a Dell Inspiron 6000 laptop. It has a built in wireless router but i do not know how to connect it to my network that i use ( Virgin ).
I have tried to go on to Network Connections, and all that is showing is , 1394 connection and local area connection.
Please could you help me,step by step .
Many thanks.
    Champion:
  • 208 Answers
Funny what is virgin is it virginmobile ? cellphone ? you need usb cable to pc from cell. also its nto a router thats built in its a wireless card for 802.11g not for cellphone companies.
Posted on Oct 05, 2008
  • Arnold G
    Arnold G Oct 06, 2008
    wow shows your mentality level when you rate this inapropriate LOL. im not guru from being wrong always.
    lets try again....to make things simple for you.. wireless 802.11g reaches about 200 yards average. it connects to a ROUTER from the wireless card in pc. in otherwords. you need a wireless antenna to send signal to. that antenna must have signal from an internet service provider modem like verizon or comcast. (verizon usualy has antenna built in to modem.)
    heres a video how to do it. (hope they dont explain too much for you to understand)
    www.associatedcontent.com/video/18043/how_to_connect_xp_wireless_laptop_to.html
Dell inspiron 6000 laptop will not connect to my Dlink wireless router. The IP address will not change to allow a connection to the internet
tredmond1929
If you are having trouble connecting to the Internet you may need refresh your connect. The link below will help do this.
http://www1.fixya.com/support/r6915776-fix_limited_or_no_connectivity_message
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Sep 18, 2011 | Dell Inspiron 6000 Notebook
My inspiron 6000 will connect to my wireless
Several resoning behind this one. One check your firewall setting, and make sure your wireless card have permission. Two, make sure that your mac filtering is turn off. Your wirless network has it own mac address and it is not in the router as to be aloud, it will block it. Three if your wireless network has a password, make sure you enter in right, it is case sensative. Four make certain that you have your wireless device is connected to the modem, or modem wireless combine. Finally, if you were running wired, try to clean the temperary ineternet filess off.
Aug 09, 2009 | Dell Inspiron 6000 Notebook
Just put a new hard drive in my Dell Inspiron 6000 laptop. I get an excellent signal when connecting to the wireless router, but I get a limited or no connectivity error and cannot access the internet on...
is it only in one location or everywhere, if only at home reset wireless router. if evrywhere, then uninstall wireless driver and llet windows reinstall it by rebooting
Jun 19, 2009 | Dell Inspiron 6000 Notebook
Wireless network connection not working
For some reason known only to Dell, the default setting for the Inspiron 6000 built-in wireless network adapter is 'off' or 'disabled.'
If you used Dell's restore disk to reinstall XP, the radio button is turned off. Go to control panel/system/device manager, find the wireless LAN device, right-click on it and choose 'Properties.' Under 'Wireless radio' check 'on' or 'enabled.'
Go back to Windows network setup wizard and go back through the steps using the 'restore network connection' button. You should be good to go.
There's an EXCELLENT network manager from Cisco named 'Network Magic' that takes all the guesswork out of setting up your internet connection. I highly recommend it. They offer a free trial and I think may even have a 'Lite' version that helps with simple connections without the bells and whistles of the full blown program. I'm not sure about that, but I can't tell you how much time it's saved me troubleshooting and setting up networks for my clients.
Jun 11, 2009 | Dell Inspiron 6000 Notebook
Dell inspiron 6000 i cant get the red X off the wireless icon?
If you're using wireless internet and should be connected, you'll have to make sure that you're in range of the wireless network and have the proper network key if it's required.
If you're not using the wireless internet and just want the notification to go away, you can double click on the icon itself, and then select 'properties' in the next window that opens. Then just remove the checkmark next to 'notifiy me with this connection has limited or no connectivity'
May 08, 2009 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 won't connet wireless network after reinstall
check DEVICE MANAGER if the wireless card have the right driver installed. if you found that the wireless card have yellow exclamation point on the right it means, you installed a wrong driver.
check also in BIOS if the wireless card is enable and the switch is turn on.
press Fn+F2 to enable wireless radio/anthena (funtion key with wireless icon in blue color)
some dell laptop have hard switch located right side check this and turn the switch on.
if you want to see the icon n task bar, go to control panel....network connection...right click on wireless adapter...select properties...check Show on taskbar
Apr 03, 2009 | Dell Inspiron 6000 Notebook
My wireless internet isn't working on my Dell Inspiron 6000.
try launching An Internet Explorer, Or web-browser Page.
Also You could look in the device manager, for any problem-devices. Then check that you are getting A receive as well as Transmit signal. ( bytes sent/received ) Check settings In Internet Connectivity.
Mike @ compurepair.
Jan 21, 2009 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 with network card Intel/Pro Wireless 2200 BG
So u can connect to the router, but you arent allowet to access the internet?
The router gave your dell a new ip-number, but it dident gave you access to the net. You ned to do the settings in your router manual, let the router give your dell full access.
Good luck
Dec 05, 2008 | Dell Inspiron 6000 Notebook
make sure that your wireless or wifi light is on,you may try to press Fn and F2 at the same time to enable or swith on wireless..if wifi is already on,try going to start >> control panel >> network connections,go to wireless network connection and double click it, it will give you a list of wireless network,or right click and then "view available wireless network", if you get an error that windows cannot configure wireless connection,go to start >> all programs >> loo for either dell wlan utility or intel pro wireless, by opening that app,it will also search for wireless network in range,just double click on the network name where you want to connect and you sould be connected provided that "wireless network" doesnt have encryption like wpa or wep key..if your connecting to your home network,you should have wireless router at home and wireless is enabled on the router.
Oct 05, 2008 | Dell Inspiron E1705 Notebook
Home wireless network
A wireless router of course :-)
Az.
Sep 17, 2008 | Dell Inspiron 6400 Notebook
Dell Inspiron 6000 Notebook Logo
422 people viewed this question
Alun Cox
