Goodmans 42" plasma tv Model NR GTV42P4
Both speakers work on the tv if you swap them over - but will not work on one side when connected. Also tv screen now shows multi coloured vertical stripes, so there is no picture but still have sound - can you advise if tele is repairable - thanks Geoff
  • Anonymous Nov 14, 2008
    Exactly the same symptoms on mine. I would add that when the Menu button is pressed, there is a noticable change to the stripey appearance, so there is a degree of 'picture' input being fed to the screen, but something is wrong with the data to the screen drive. The screen is fully driven with data across the entire screen, so it is not a failure of the screen drive, I think.
  • 121 Answers
Not sure i can solve this but you could try tapping the bottom of the set's case or back cover to see if its dry jointed. as you said both speakers are working so the fault lies with one of the outputs of the sets amp.if you have a headphone socket check to see if both channel's work . dry joints are quite common. also have had this problem and it turned out to be a faulty scart lead always check the obvious first good luck ..colin
Posted on Apr 27, 2009
How do I connect external speakers ??
You cannot connect external speakers directly to the TV. You can connect a receiver to the TV and then connect your speakers to the TV.
Oct 14, 2013 | Panasonic 42 TCP42X3 42 Plasma TV
Can I replace a broken Samsung 42" plasma PN42B450B1D screen with a Samsung 42" plasma SP-S4243 screen? Are the screens interchangeable?
No, you cant. I have 2 tvs just like yours but the LN model is newer than the SP model tv. I have the same problem, my LN tv has a cracked screen and the other SP model is good
Sep 13, 2010 | Samsung SP-S4243 Television
How do i connect speakers to my samsung ps42q97hd plasma tv
The model in question does not have standard speaker outputs, so there is no way to "directly" wire the speakers up.
Presumably because the TV has built in speakers.
However, you can use the audio outputs on the rear of the TV, Red RCA plug and White RCA plug to drive the speakers connected to a hi-fi system, Surround amp or similar?
The cables are very cheap, available from Argos and the like.
You will notice the improvement in sound.
Does that help?
Sep 04, 2009 | Samsung PS42P2S 42 in. Plasma Television
Connect home theater to tv
Do you have the cables connected to line out on tv ? Do you have the correct source and audio type selected in the home theater (analog/digital/coaxial).
Jan 18, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Speakers for Dell 42 inch plasma TV
yes
i have them in stock.
how manny do you need.
see my web site
allrepair dot us
regards,
daniel.
Jan 12, 2009 | Dell W4200 42 in. HD-Ready Plasma...
Speakers for my Dell 4200 Plasma TV
in stock at allrepair you have to call them
1-719-687-6997
No sound from daewoo 42" plasma
This particular model doesn't have internal speakers. It has two removable external speakers mounted on the left and right side of the tv. If you didn't get the external speakers with the tv, you won't have sound unless you use a surround sound setup.
May 23, 2008 | Daewoo DTS42 42 in. HD-Ready Plasma...
Daewoo 42 Plasma - Model DT4280NH
I have a samsung 42 in plasma television which is three years old, it has a blue flickering light to the right of the television, sometimes can see some at the top in the middle, hope you can help with this problem, is it repairable.
Sep 02, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Televison & Video Logo
346 people viewed this question
Top Televison & Video Experts
