Question about Hoover H130E Front Load Washer
Water not getting to powder dept
I have a hoover quattro 1300 washer , the problem i have is that washing powder is not rinsing away and it also happening with the conditioner compartment, but water is going into the pre-wash compartment only .
SMALL SPRING HAD COME LEVER THAT IS CONNECTED TO WATER RELEASE VALVE , RECONNECTED SPRING AND EVERYTHING SEEMS TO BE WORKING OK .
Posted on Oct 09, 2008
Hi I am experiencing a problem with my hoover washing machine, when the machine is turned on it is not taking the powder from the drawer or filling with water?. It is a Family 1300 mega load hope you can...
There are a few reasons that you are having this problem.
It's possible that the hose that supplies the water is blocked. If the drawer and powder are totally dry, the solenoid that supplies the water to the detergent drawer may be bad. Some machines use hot water to dispense the detergent and cold water to dispense fabric softener, so both must be available to that type of machine regardless of the wash/rinse temperature selection.
I'm not familiar with Hoover. If you open the drawer and see a tab that stops the drawer, depressing the tab may allow the drawer to be removed and cleaned at a sink. They are not dishwasher-safe and must be cleaned by hand.
If this does not help, please repost your question.
Good luck from Detroit, MI, USA.
Jul 19, 2011 | Hoover Washing Machines
Hoover six 1300 washing machine what do I put in the tray?. and in what order?.
Methinks you could do with a manual- for now and probably later ;-
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
What goes where
A quick and easy way to find out which tray is which is to pull the detergent drawer out just so that you can see into it. Start a pre-wash (if the washjer has one) and see where the water runs in- that's where the pre-wash powder goes. Advance to the main wash and observe- that is for the main wash powder. Finally start a rinse cycle and where the water goes in is where the conditioner/softener goes.
In a few cases I have come across, the pre-wash tray shares with the conditioner/softener part but the pre-wash powder goes in the front and the softener in the back.
You can put them all in at the same time before you start the wash cycle.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Jul 19, 2011 | Washing Machines
Need User Guide for Hoover washing machine
you can download manual from hoover.co.uk
Mar 27, 2009 | Washing Machines
I have a Hoover Performa ECO 1300. The washing is not being rinsed properly and there is washing powder residue still on the clothes.
For low water volume - or "Trickling" effect...
1. Turn off the water supply to both hoses.
2. Remove hoses (one at a time so you don't get them confused)
3. On the washer side - look for a removeable screen inside wher you just removed the hose.
4. Using a small screwdriver - pop out the screen and reverse-flush it/clean it. It will likely be full of sediment and calcium deposits from your pipes.
5. Replace the inlet screens.
6. Re-fit the hose to the machine.
7. Turn on water supply valves.
8. re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 15, 2009 | Washing Machines
Hoover quattro system 1100 ab power jet as 110
I had the same problem when i got my machine, if you slide out the powder and softener tray just behind the face of it on the right hand side you will see a white plastic tab about 2 inchs wide! That plastic tab slides out and has all the programme settings on it!
Aug 08, 2008 | Hoover HC6 110M Front Load Washer
Hoover washer dryer saver 1300
I have inherited a hoover saver 1300 in new flat, the dials have worn away and it goes onto drying mode after wash, how can i have it on wash and spin only - NO DRYING? Thanks
Apr 12, 2008 | Hoover H120M Front Load Washer / Dryer
Hoover six express wdm130 1300 washer dryer
Click on your model number above, (below FIXYA) on this site, & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
And dont forget to rate me on this great site.
Aug 14, 2007 | Hoover AL130 Front Load Washer
Hoover 1300 spin 5+5 washer dryer
you don't say which cycle it will start on. however, could be cold valve open circuit which also means no rinse or cold inlet hose kinked etc. can you give more info?
Apr 09, 2007 | Hoover H120M Front Load Washer / Dryer
Hoover H130E Front Load Washer Logo
174 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
